Question about Whirlpool WED5300S Electric Dryer
Not drying. don't think it's the heating element because dryer is warm to touch.
  • Whirlpool Master
  • 43,501 Answers
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
Posted on Sep 21, 2010
My Maytag MEDX700XL1 gets very hot to the touch. The heating element heats even on air dry settings. The top of the dryer is much hotter than it has been in the past. I found very little lint and the vent...
the element is grounding out,a part of the element is touching metal and grounding out keeping the heat on all the time,replace the element
Aug 20, 2017 | Maytag Dryers
Dryer overheating on timed dry/no heat settings
Replace the thermostat. A very inexpensive thermocouple that is not sensing the heat anymore and caused the element to overheat. In the UK the part will cost less than five pounds!
If the element had touched the ground, your safety earth leakage breaker in the fuse box would have tripped.
Mar 20, 2014 | Frigidaire Electric Dryer
Clothes don't dry or get warm
Ether a bad heating element,or an obstructed discharge vent. The bad element will prevent heat production, a blocked discharge will not allow humidity to escape, resulting in wet clothes. Hope this helps.
Sep 11, 2013 | Dryers
Dryer is taking way longer to dry than normal
Does it feel warm to the touch? (you did not make mention of that) If not then it more than likely is not heating at all and there could be a number of reasons why it does not heat.
1. Open heating element
2. Open thermostat
3. Defectrive motor switch
4. Damaged wiring
5. Defective heat control switch
6. Defective timer.
7. One of the 2 power circuit breakers is partially tripped. (turn them off and back on again to reset them)
If it is warm to the touch then check around the lint filter for lint buildup. Also go outside and check the dryer vent flapper where it exits your home for obstructions. Aditionaally check the vent tubing itself for kinks or obstructions. You may have to remove the vent hose from the dryer to check the tubing.
Jan 03, 2010 | GE DVLR223 Dryers
Dryer fails to dry clothes fully, but the clothes feel warm; could this be an element issue?
If the clothes are warm I wouldn't think the problem is the heating element. Check the venting from the machine to the outside and make sure you do not have a blockage somewhere. If it is clear, you probably need to replace the thermal cut off.
Nov 09, 2009 | Roper REX4634KQ Electric Dryer
Kenmore Elite dryer heats but does not dry
Make sure that your vent tube is not kinked or crushed behind the dryer and it all this is ok then you need to change your cycling thermostat. is it gas or electric
Mar 12, 2009 | Kenmore Dryers
Dryer Run too long
MAKE SURE YOUR LINT TRAPS AND DUCTS ARE NOT PLUGED.EASY REPAIR.YOU CAN DO IT.
Jan 16, 2009 | Maytag PYE2300AY Electric Dryer
Dryer Run too long
check the complete ventillation duct( in and out of the machine.) Sounds like its not moving any air. No flow
Jan 16, 2009 | Maytag PYE4558A Electric Dryer
Fisher and Paykel DEGX1 Electric Dryer Stays Warm
Yes, get a new element. The reason it's on all the time is because the element coils have broken and one of the coils is touching the canister that encloses it. This creates a direct short to ground. By the way, the element has 120 volts to it all the time. It will only HEAT when 240 is applied through the centrifugal switch of the motor. Your 120 volts is shorting to ground... not enough amps to trip the circuit breaker, but enough to glow the element.
Aug 23, 2007 | Fisher and Paykel DEGX1 Electric Dryer
Whirlpool WED5300S Electric Dryer Logo
49 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
