Question about Liquid Video L17LCD2 17" Flat Panel LCD Monitor
Liquid video monitor trouble
Hi
I have a new hard drive and now some of my websites appear too large for my screen.
I have tried to fix this problem by changing my screen resolution to 1024 by 768 p but I just get a black screen with an error box reading "out of range".
The only screen resolution that seems to work on this pc now is 800 by 600?
What can I do to fix this problem? Do I need a new driver?
Thanks for your help :)
  • 36 Answers
Hi, the way your describing the problem it sounds like you don't have any video drivers installed in your machine, hence the computer is using a generic video driver with very limited resolutions. Try using Windows Update, when it asks you to do express or custom, choose custom and under hardware you should see your video drivers there. If not post the make and model of your PC and I'll help you find the drivers.
Posted on May 18, 2008
When turned on, it shows the picture for a second
stays on 5 mins screen turns black i push screen power on and stays on 2, 3 mins and turns off again
Dec 31, 2009 | ViewSonic VX715 17" LCD Monitor
If i open the laptop the illuminated lines appear on the screen and i cant see a single thing and i hear the sound of hard disk which is spinning but the blank screen irritates me what i do
It's possible your laptop screen is going bad. Here's something you can try. Get an old monitor from a desktop. Power it up and hook it into the video port in the back of your laptop. Hit the Fn key and the F7 key at the same time. This tells your laptop to send the video signal to the port in the back of the laptop. If the computer works with this new monitor you may want to take your laptop into a computer repair store to have the screen replaced, or if you want to replace it yourself I can give you some advice on how to do that. If the computer doesn't work with the new monitor you may have a hard drive or mother board problem. The first thing I'd try then is to reboot the computer from your CD rom drive using a recover disk. If you can get it to boot ok from the CD rom it's probably a hard drive problem. You might be able to fix this problem by reloading windows.
Jul 04, 2009 | Dell Latitude D630 PC Notebook
Tower turns on and cpu fan is running cd drives all respond and open. Monitor comes on then appears to go into sleep and will not show any screen, recently tried installing a new hard drive after have...
Have you tried another video card? Or even another monitor? If not, could be the motherboard especially if the video card is integrated into the motherboard.
Jun 23, 2009 | Compaq Presario 5000 PC Desktop
Monitor issues Acer 5610-4621
sounds like a bad video card honestly. I doubt the monitor was bad.
May 29, 2009 | Acer Aspire 5610-4648 Notebook
E173FP monitor fix
Depending on when you bought it. There should be at least a one year warranty. If its still under warranty have dell replace it.
Mark
Mar 25, 2009 | Dell E151FP 15" Flat Panel LCD Monitor
Objects appearing on my screen are larger
Right click on the desktop and go to Properties or Personalize and find the display settings. The resolution bar on the botton should be all the way to the right generally, at the highest pixel resolution.
It makes things appear smaller and essentially makes it so more stuff can display on your monitor.
If you don't have an option to make it any larger (this also depends on screen size) then you need to identify your video device and install a new driver.
Mar 19, 2009 | Dell Computers & Internet
Can't change monitor display settings
no drivers are needed for monitor. Its the video card drivers that you should look for at the dell drivers and downloads website. make sure that you have the right driver installed so that you may be increase your screen resolution.You may also use your Dell Resource CD Drivers and utilities. Install the Resource cd, On the TOPICS dropdown box, select drivers,You'll know which drivers needs to be installed because they will have a check mark infront of the correct device driver. Clicke extract button after you have chosen the video driver. You may need to scroll down.Restart the computer.
Feb 15, 2008 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
IBM MONITOR ON SCREEN DISPLAY
This is a problem in the monitor itself. The computer has absolutely no control over the On Screen Display. Most likely the button that controls contrast is stuck. You might try blasting the button with canned air. Sounds like it might be time to buy a new or used monitor.
Jul 31, 2007 | Samsung SyncMaster 551 15" CRT Monitor
Liquid Video L17LCD2 17" Flat Panel LCD Monitor Logo
73 people viewed this question
Top Liquid Video Computers & Internet Experts
Rommel Balcita
Mark Gough
Are you a Liquid Video Computer and Internet Expert? Answer questions, earn points and help others
