Cannot get printer to either delete item in queueor print it it says is deleting but does nothing whe ni switch off system completely and then switch on again does test page .. then nothing
    Guru:
  • 1,082 Answers
Deleting an item in the print queue often doesn't seem to work until the system is restarted. I've had this problem with both XP and Win7.
The test page sounds like you have requested it. Try just cancelling a document, then when it hangs in the print queue, restart the computer.
I've researched several "fixes" but am convinced it is a Microsoft problem that they need to fix.
If this answers your question, I'd appreciate 4 thumbs. I do this for fun and do not get paid.
Posted on Sep 17, 2010
Printer aio 926 communication error
hi aweintra,
you can do the following steps:
1.Check if the firewall is blocking any printer services
2.Check what port the printer is using (reenable the bi-directional support) and if it's on online mode
3.Disable all the firewalls
4.Uninstall the printer driver and software, then unplug the usb cable of the printer.
5.Delete any items under the ff keys:
HKLM\System\CurrentControlSet\Control\Print\Environments\Windows NT x86\Drivers\Version-2
HKLM\System\CurrentControlSet\Control\Print\Environments\Windows NT x86\Drivers\Version-3
HKLM\System\CurrentControlSet001\Control\Print\Environments\Windows NT x86\Drivers\Version-2
HKLM\System\CurrentControlSet001\Control\Print\Environments\Windows NT x86\Drivers\Version-3
Optional***
6.Delete any non default items under the ff keys:
Note: ONLY THE NON DEFAULT ITEMS SHOULD BE DELETED
HKLM\System\CurrentControlSet\Control\Print\Monitors
HKLM\System\CurrentControlSet001\Control\Print\Monitors
Default items are as follows:
AppleTalk Printing Devices
BJ Language Monitor
Local Port
PJL Language Monitor
Standard TCP/IP Port
USB Monitor
Windows NT FAx Monitor
7.Delete any items under the ff keys:
HKLM\System\CurrentControlSet\Control\Print\Printers
HKLM\System\CurrentControlSet001\Control\Print\Printers
8.Completely remove drivers by doing the ff: (Option for comm failure because of the upgrade from xp to vista)
Ensure there are no documents in queue.
Disconnect printer’s USB cable.
Click the Start pearl, then click All programs, Printers, Dell xxx (where “xxx” is the printer model number) and then Uninstall. Complete the uninstall utility.
From the start search box type spool and press .
The spool folder located at c:\windows\system32\spool opens.
Rename c:\windows\system32\spool\drivers\w32X86 to c:\windows\system32\spool\drivers\backup.
Rename c:\windows\system32\spool\prtprocs\W32X86 to c:\windows\system32\spool\prtprocs\backup.
9.Restart the computer.
10.Check th services status
Start-Run- Type Services.msc and Click on Open
You will see long list of services
You need to make sure following 4 Services are set to Automatically start
Remote Procedure Call RPC
Remote Procedure Call RPC Locater
LexBce Server
Print Spooler
11.Reinstall the latest printer driver
just send me an update if the issue won't be fixed. have a great day.
Oct 18, 2009 | Dell 962 Photo All-In-One InkJet Printer
Dell AIO printer prints only portion of page then stops! Sometimes up to 30%
hi normel_brabs,
you can try these steps:
4.Uninstall the printer driver and software, then remove the usb cable of the printer.
Optional***
BJ Language Monitor
Local Port
USB Monitor
From the start search box type spool and press.
NOTE: IF YOU HAVE ANOTHER PRINTER INSTALLED, DON'T DO THESE STEPS, JUST RESTART THE COMPUTER.
LexBce Server
Print Spooler
Oct 16, 2009 | Dell 810 All-In-One InkJet Printer
Using Windows Vista, documents remain in the print queue after printing necessitating that the computer be restareted between every print job. Is there a fix?
Hi jonty143, you can try these steps.
Optional***
BJ Language Monitor
Local Port
USB Monitor
LexBce Server
Print Spooler
Oct 13, 2009 | Dell A940 All-In-One InkJet Printer
Dell 926 does not print...."communications with computer and printer not present"....tried reinstalling driver....no luck....Jeff
hi jeffhup,
Optional***
BJ Language Monitor
Local Port
USB Monitor
LexBce Server
Print Spooler
Oct 11, 2009 | Dell 926 All-In-One InkJet Printer
Printer can't communicate with computer
Hi rcamp3,
You can try these steps:
Optional***
BJ Language Monitor
Local Port
USB Monitor
LexBce Server
Print Spooler
Oct 05, 2009 | Dell 924 All-in-One InkJet Printer
Printer not printing
if your printer is giving you an error msg saying printer communication not available.
Optional***
BJ Language Monitor
Local Port
USB Monitor
LexBce Server
Print Spooler
have a great day :)
Oct 01, 2009 | Dell 962 Photo All-In-One InkJet Printer
My printer is not printing everything else works, computer says that the printer is not connected.
hi there,
1.Check if the firewall is blocking any printer services 2.Check what port the printer is using (reenable the bi-directional support) and if it's on online mode 3.Disable all the firewalls 4.Uninstall the printer driver and software 5.Delete any items under the ff keys: HKLM\System\CurrentControlSet\Control\Print\Environments\Windows NT x86\Drivers\Version-2 HKLM\System\CurrentControlSet\Control\Print\Environments\Windows NT x86\Drivers\Version-3 HKLM\System\CurrentControlSet001\Control\Print\Environments\Windows NT x86\Drivers\Version-2 HKLM\System\CurrentControlSet001\Control\Print\Environments\Windows NT x86\Drivers\Version-3 Optional*** 6.Delete any non default items under the ff keys: Note: ONLY THE NON DEFAULT ITEMS SHOULD BE DELETED HKLM\System\CurrentControlSet\Control\Print\Monitors HKLM\System\CurrentControlSet001\Control\Print\Monitors Default items are as follows: AppleTalk Printing Devices BJ Language Monitor Local Port PJL Language Monitor Standard TCP/IP Port USB Monitor Windows NT FAx Monitor ***** 7.Delete any items under the ff keys: HKLM\System\CurrentControlSet\Control\Print\Printers HKLM\System\CurrentControlSet001\Control\Print\Printers 8.Completely remove drivers by doing the ff: (Option for comm failure because of the upgrade from xp to vista) Ensure there are no documents in queue. Disconnect printer’s USB cable. Click the Start pearl, then click All programs, Printers, Dell xxx (where “xxx” is the printer model number) and then Uninstall. Complete the uninstall utility. From the start search box type spool and press . The spool folder located at c:\windows\system32\spool opens. Rename c:\windows\system32\spool\drivers\w32X86 to c:\windows\system32\spool\drivers\backup. Rename c:\windows\system32\spool\prtprocs\W32X86 to c:\windows\system32\spool\prtprocs\backup. 9.Restart the computer. 10.Check th services status Start-Run- Type Services.msc and Click on Open You will see long list of services You need to make sure following 4 Services are set to Automatically start Remote Procedure Call RPC Remote Procedure Call RPC Locater LexBce Server Print Spooler 11.Reinstall the latest printer driver
have a great day :)
Sep 30, 2009 | Dell 922 All-In-One InkJet Printer
Trying to print on my aio 926 printer but wont print i hook it up to my laptop and prints fine but not on my desktop
do you receive an error msg saying, printer communication not available?
if yes you can try these steps:
have a great day :)
Sep 26, 2009 | Dell Photo 964 All-In-One InkJet Printer
My Dell Photo Printer 720 has stopped printed, no response at all to print jobs. I have unplugged the printer, no change. I have rebooted the computer, no change.
hi there,
Aug 03, 2009 | Dell Inkjet 720 Printer
Dell 926 printer wont print text.
do you receive and error msg like printer communication not available?
if you're receiving printer communication not available, you can try these steps:
Optional***
BJ Language Monitor
Local Port
USB Monitor
LexBce Server
Print Spooler
have a great day
Dec 23, 2008 | Dell 926 All-In-One InkJet Printer
Open Questions:
Secure Your Data With Our Online Backup Services ' DataAlign In vanilla terms, a backup or the process of backing up, refers to the copying and archiving of computer data so it may be used to restore the original after a data loss event. Backups have two distinct purposes. The primary purpose is to recover data after its loss, be it by data deletion or corruption. The simplest definition of a computer backup is an exact copy. In the case of computer files, we are referring to copies of the original files that you have on your laptop, desktop, or external drive. Creating a backup of original content means having that data saved in two places, but it's also important to make sure that those two places aren't on the same type of device. For example, if you have 3 copies of a working document on your computer, if your computer crashes, you will still lose all three. This makes the backup method and medium, an important thing to consider for your backup strategy. With the kind of Online Cloud Backup technology being used these days, it is extremely important to back up your files. Ideally, we store data files, movies, music, photos and our official documents on the computer. With the ever-changing technology, desktops and laptops have reduced in cost, and the quantum of storage inside them has surged considerably over the last few years. Unfortunately, storing all your data in only one place is risky. Accidental deletion, theft, computer loss, natural disaster is just some of the reasons that could cost you heavily as you stand out the chance to lose the data you've spent so long generating and collecting. Having an excellent backup strategy Computer Data Backup is the only way to battle the unexpected loss of data. There is more than one way to back up your computers, and using multiple forms of backup will minimize the risk of losing your valuable files. This is where, the PC Backup solution from DataAlign stands out of the rest and gives a one stop solution for Business Server Data Backup up your computer's data on the secure cloud servers. Our innovative platform has been designed while keeping you in mind. To provide optimal user experience we focus on simplicity and this in turn ensures that you will be able to backup and access large data quickly and smoothly.
May 25, 2018 | Quantum Computers & Internet
Computers & Internet Logo
74 people viewed this question
David Payne
David Payne
