Question about Dryers
My clothes dryer does'nt start when I turn the ON switch.
  • Dryers Master
  • 1,525 Answers
Hello there may be a couple of things that could be wrong , first check inside the of the door to see if the long plastic pin is connected the this activate the motor , if this is ok then the capacitor next to the motor could be faulty. ps check the fuse in the plug
regards
shaun
Posted on Sep 17, 2010
Wont cycle to dry clothes
When the dryer door is open, you should be able to find a switch (it may be just a button protruding from the cabinet). The switch turns the machine off when the door is opened. It may be damaged or worn out.
Apr 04, 2014 | Maytag EPICz Electric Dryer
GE d clothes dryer starts when you close the door, before you turn the saitch.
Dear Dan,
You may have a bad start switch. Here is how I would check it.
Unplug your dryer, and remove the back of the control panel, which usually means pull it out from the wall and take out about 6 or 8 screws. There is usually a long rectangular panel for the control panel access.
Locate the start switch and unhook the wires from it, being certain that the wires are then not touching anything at all.
Then plug in the dryer and see if that is what the problem was, it should not turn on at all.
You can buy new switches from an appliance dealer, or from "Sears Parts" on the internet.
You can buy new and used switches from e-bay.
Be blessed.
Oct 31, 2011 | GE WE4X881 Clothes Dryer Start Switch
Dryer can't turn on. Start button just buzzes.
replace the "Broken-Belt" switch by the drum motor,when the belt breaks it shuts off the heating element so as not to burn the clothes because the drum can't turn to produce air flow to dry the clothes as they tumble,when you replace the belt it will make the switch close the circuit again and it will start
Dec 26, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Dryer stooped working suddenly.
Replace the fan belt that turns the dryer drum. Use only the genuine replacement spare part for your dryer.
Jun 07, 2010 | Frigidaire GLER331A Electric Dryer
Dryer won't stay running
I had the same problem with my kemore. Thank goodness I still had it under warranty.
The tech said the door latch was just slightly ajar. This is common he said that when we take clothes out we let the door close to hard or gets ajar for leaning in to take clothes out.
He readjusted it and I have never had a problem with it again.
Hope this helps
Sep 26, 2009 | GE DBSR453EBWW Electric Dryer
Ge Cloths dryer will not stay running or turn drum
probably broken belt some dryers have broken belt switch that shut dryer off if belt broke
Nov 25, 2008 | GE Dryers
What goes on in the dryer as it is being used?
customer selects cycle
customer pushes start button
motor starts, motor switch closes and turns on element or igniter
depending if electric or gas
tub turns and heat dries clothes
thermastats cycle during run not to overheat clothes
timer cycle ends
you get clothes out now dry and put on
Apr 19, 2008 | Dryers
Getting the dryer to start after turning it off.
Suggestion: Switch off wall plug and restart to dry.
Jun 26, 2007 | Malber WD1000 Front Load Washer/Dryer
Dryers Logo
24 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
