Question about Spirit Exercise & Fitness
In the middle of a run my freespirit treadmill 122 309000 shuts off and on the didgital display it reads ERR 05. How can I fix this?
  • 944 Answers
ERR 05 always means speed sensor problem.If it is defective or loose contact will always cause this issue.The sensor controls the pulley belt to rotate.So your treadmill is not working.
You need to pull the cover off. Check for burned wire or short circuit on the board and loose sockets.
Use multimeter to test the sensor.
I have common service Treadmills manual.Use it for having some idea.
http://www.casallproducts.com/swe/pdf/Servicemanual/Vision/T9600-T9700.pdf
post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Posted on Sep 17, 2010
  • Natarajan Ramasamy
    Natarajan Ramasamy Sep 17, 2010
    spiritfitness manual
    http://www.spiritfitness.com/shop/docs/E...
TREADMILL ERROR MESSAGE
A proximity sensor is telling you the belt is incorrectly aligned. Probably too loose. Bolts on end of shafts control belt tension. Turn in if loose, out if too tight.
Sep 03, 2014 | Proform Freespirit 814 Treadmill Drive...
Freespirit treadmill
Turn treadmill off. Disconnect drive motor wires from lower control board (Mtr + and Mtr -)
terminals. Power up in OLS mode (FAST & START). Bring displayed speed up to 99.
Measure across the Mtr + and Mtr - terminals with your voltmeter (DCVolts). You should
measure at least 90 vdc on a 110V treadmill and 180 vdc on a 220V treadmill.
If you are not getting dc volts out of the lower board, replace it.
If you are measuring the proper dc voltage out, replace the drive motor.
see my personal TIPS for motor help. God bless you 1232c4bc-7349-41aa-9120-7d58645cb442.gifc11b620c-0d7d-410d-9958-64f3636d4ac5.jpg
Jun 05, 2013 | Exercise & Fitness
BH treadmill error E 1 Whats the fix?
ERR 01 indicates a speed issue. In this case, the motor speed as reported from the optic sensor differs
from the speed setting.
Analysis: Optic sensor signal issue -- Either the optic sensor signal is not right, or it is read incorrectly, or
the signal is not reaching the display.
Test the speed sensor. clean it, and tight the connector very well.see the diagram attached.
God bless you
Apr 04, 2013 | Bh Fitness T8 Pro Treadmill Fitness...
My freespirit tradmill error 5606
1) LUBE the deck belt, this happen because the lack of maintenance , produce shut down for to protect electronic system,to due the enough friction between deck vs deck belt., maybe deck worn.
2) lube the rollers bearings
3) test the motor input voltage, if there are the motor need repair.
4) measure the output voltage board, for input voltage motor, if there are NOT the board is faulty.
After fix it RUN the software calibration for diagnose, troubleshooting.
God bless you
Jul 13, 2012 | Exercise & Fitness
I get the worse electrical shocks from my treadmill...the other day I got a really bad one and the treadmill shut off and when I started it up again all the numbers on the console are cut in half??
Better check the harness where it runs up the supports. Some of these had the harness mis-routed and screws were able to damage the wires and create shorts.
Apr 27, 2010 | RTO Freespirit 817 Treadmill Walking Belt
Exercise & Fitness Logo
407 people viewed this question
Top Spirit Exercise & Fitness Experts
MrJunk
Level 1 Expert
Electro Med Services...
Tom Chichester
Are you a Spirit Exercise and Fitnes Expert? Answer questions, earn points and help others
