Question about Cycling
Where can i buy a ray drop out for the shogun xc 100 mountain bike
2 Suggested Answers
  • 1138 Answers
SOURCE: Suspension adjustment for a 2007 Shogun Hydra
Have a look at this site:http://www.bikeforums.net/archive/index.php/t-15120.html and this site might help http://www.bikewebsite.com/suspension.htm You will have to either search for the manufacturers site and look for the adjustment info there( you should be able to download the manual for the forks ) or mention the specifics here so we can find them. According to my info your bike should have a Suntour SF-M3010db fork on it.
Posted on Aug 29, 2009
Display panel on Yamaha xc 125 Cygnus not lighting up
main fuse may be seperate to rest of fuses go online and check
Jan 18, 2015 | 2008 Yamaha TT-R 125L
Tip
Bike Headset Installation
Hi I found this Bike Headset Installation guide while searching in Google, it really helped me and I hope it will help others here at Fixya:
  • Make sure the frame has been reamed and faced, otherwise you will have trouble installing the headset, or the headset won't last very long. If you aren't sure, take the bike to a bike shop.
  • Seat the crown race on the fork crown. This requires a crown race slide punch. Pound the crown race down until it sits flat on the fork crown.
  • Clamp the frame into the repair stand.
  • Lightly grease both ends of the headtube and place the headset cups into the ends of the head tube.
  • Slide the cup press through the head tube. Install the lower half of the press.
  • Turn the handle on the top of the cup press clockwise while holding the bottom of the press with a wrench. Work slowly and carefully, making sure the cups press evenly into the frame. Be sure to tighten the cups firmly into the frame, but do not over tighten.
  • Remove the cup press.
  • Grease the bearing and install the fork. For information on how to adjust the headset, see related eHow "Adjust a Bike Headset."
Good luck
Daniel
on Oct 30, 2008 | Marzocchi 2008 XC 700 ATA Mountain Bike...
Value of a element mongoose bike
Condition and appearance are important. If its in top condition it will be worth more than a junked out one. I usually buy this bike for about $ 25, then repair or tune it up and resell it for about $ 45. But that's my area. The same bike in Chicago will bring about 75-100 in full working order.
Oct 01, 2014 | Mongoose Exile 26 Men's Full-Suspension...
Need a manual on Shimano 24 speed / 7005 al motobecane 700 xc
Ther is no manual for a specific bike. If you want to know something, web surf for it. All parts on that bike are over-the-counter common bike parts. No high tech anything except the now-obsolete Unified Rear Triangle. You might search for Motebecane's website.
Using this as a spec resource...
http://www.spreadmyad.com/houston/vehicles/bicycles/9672382-motobecane-700-ds-24-speed-full-suspension-mountain-bike-mtb-bicycle-pearland-250
... you could query "how to adjust (whatever)".
This is a good resource.
Sep 12, 2011 | Cycling
How to Maintain a Bike's Tire Pressure for Good Performance?
Buy a good floor pump with a gauge (see "How to Buy a Bike Pump," under Related eHows). A small, frame-mounted pump is useful only for roadside repairs.
Understand that it's normal for most tires to lose up to 10 pounds per square inch (psi) per week. This does not mean you have a slow leak.
Look on the tire's sidewall for tire pressure recommendations. Don't exceed the maximum tire pressure listed.
Inflate your mountain bike's tires to 40 psi for dirt riding. You may wish to inflate your tires to 50 to 60 psi for city riding.
Inflate your road bike's tires to 100 psi for road riding. Some road tires have much higher psi ratings. However, 100 psi will provide a good mix of performance and comfort.
Inflate your hybrid bike's tires to 60 to 70 psi for city riding.
Check your tire pressure before every ride
Dec 21, 2010 | Cycling
Need to no how much oil they should hold. they are 07 drop offs triple clamp
offical Marzocchi site has all the details.
(near the bottom for your drop offs)
http://www.marzocchi.com/Template/contenuto.asp?LN=UK&idC=1592&IdFolder=777
Jan 31, 2010 | Marzocchi 2008 XC 700 ATA Mountain Bike...
What the best way to take the back wheel of my mountain bike
Shift to your top gear before removing the wheel and as you take the wheel out, pull back your derailleur to make it clear the cassette more easily.
Hope,
matt
Sep 05, 2009 | Mountain 2009 Easton Xc Two Disc Bike...
Aug 28, 2009 | Mongoose Exile 26 Men's Full-Suspension...
Wacom Mouse XC-100-03 Right click doesn't work
Greetings,
You can buy any other style or brand of mouse and it will work right along side of the Wacom. I chose to keep my Logitech wireless mouse after installing my Wacom tablet because it provided a better feature set (i.e. more buttons ). I have had no issues. Please rate me well if this helped.
Take Care,
-WN
May 06, 2008 | Wacom ZC100 Mouse
Cycling Logo
49 people viewed this question
Top Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
