Question about Stoves Premier 600EMa Electric Single Oven
The oven was working as normal, after half an hour it switched off and nothing worked not even the light. how can i get a manual
2 Suggested Answers
  • 250 Answers
SOURCE: oven making whirring noise when switched off
The back panel of the main oven houses the circulating fan. From experience, fat/grease/gunge accumulates and drips down the inside of the plate through the vents. This will then rub on the fan as it turns. There are four self tapping screws, one in each corner of the panel. Remove the screws and the panel will come off. That is the easy bit, getting rid of the grease is harder. Don't forget that the oven side of the panel is a stay clean and shouldn't be cleaned with anything abrasive. I use the Lakeland brush on oven cleaner on ALL the walls of the oven (even the Stay Clean) and it works a treat. It may take some time to disolve the residue and a couple of goes, but it does work.
Posted on Apr 24, 2010
Why has our oven stopped working whilst cooking - nothing electrical seems to be working?
Did you check your electrical breakers? Maybe it tripped. Reset it by first switching it fully to the off position, then switch it to on.
Feb 29, 2016 | Ovens
Model number 3627361192 oven wont work but broiler does the oven starts but then flame goes out
replace the igniter. Even though you see it glowing, it's failing.
Jul 17, 2014 | Kenmore Ovens
AEG double oven/grill stopped working
It appears the oven has shorted out. Try checking the breaker box and see if any switches have been flipped. If this is not the case a new oven is in order.
Jan 24, 2014 | Ovens
Aeg competence d8800 5
Electronic component failure. As only 5 years old then worth calling a Service Engineer.
Sep 18, 2017 | Ovens
Help! I have a GE Oven and the oven won't light. I have replaced the ignitor already. Still doesn't work. The ignitor does not glow, there is nothing. Checking the volts at the oven temperature selector,...
Check the voltage at the ignitor connections.
If low voltage is not there,replace the oven control.
I can not be more specific without a model number.
Nov 27, 2010 | GE Ovens
Baumatic oven not heating up. Grill and fan fine.
if it is the b180, the answer (having just fixed this) is really simple.
The coily bit is the oven element - it will have gone. A new one from eBay cost me about 6 quid.
[WHEN IT ARRIVES !]
Turn the power off.
Inside the oven use a philips screwdriver to remove the 4 screws (KEEP THEM !)
You will see a coily thing and a fan.
You unscrew 3 more screws (2 on the left and 1 on the right).
(KEEP THESE TOO!)
now ... bit tricky, have the new one inside the oven and take each wire off one at a time and put it on the new element.
Screw it back on but DONT put the last panel back in.
Turn the oven on maximum for about 2 minutes and see it glow red.
Turn the oven off. Make a cup of tea and have a couple of biscuits while admiring how good you are and waiting for the element to cool down!!!
Put the final panel back in place. Whole thing (including a cup of tea) takes about half an hour.
Jan 27, 2010 | Baumatic B180 Electric Single Oven
My oven broiler does not seem to be working-I turned it on broil for about 15 minutes - no heat, nothing. On normal bake, it takes about a half hour to heat the oven to 350 degrees - my old stove took...
check the bake (lower) element, mine just went out. It was easy to spot the problem once I pulled the element out, the wire had burnt off the end. Please remember to turn the power off first.
Nov 28, 2009 | Whirlpool RBS275PD Electric Single Oven
Stoves Premier 600EMa Electric Single Oven Logo
32 people viewed this question
Top Stoves Ovens Experts
ashburton
Dan Webster
Dan Webster
Are you a Stoves Oven Expert? Answer questions, earn points and help others
