Question about Pentax ME Super 35mm SLR Camera
Light meter I have 2 camera's I was told the light meters are not working. Do these camera's have light meters and if they don't work how do I fix them? Thanks. -Mitch
    Problem Solver:
  • 18 Answers
Yes, the Pentax ME Super has a built-in light meter. It is used by the ME Super in order to determine the correct exposure settings when the camera is used in the "A" (Autoexposure) & "AV" (Aperture-priority) exposure modes.
I don't mean to insult you, but have you tried new batteries?
Sometimes the meter fails when the batteries don't have enough juice.
Take care & Happy Imaging!
Glen
Posted on Jul 26, 2008
When I snap it having lines and blur
Buy new camera and use it often. You don't use it you lose it.Oxidation on circuit connector, contact resistance became too high.
Jul 15, 2012 | Samsung Digimax S600 Digital Camera
The light meter does not light up. I've put 2 new batteries in. The shutter works and the camera worked perfectly when i put it in storage 10 years ago. How do i get the light meter to work?
First off, did you store it with batteries installed? If so, check the compartment to be sure there's no corrosion on the contacts. If there is, a pencil eraser works well to clean it off - I don't recommend using any sort of liquid since it can seep into the inside.
If that's not the issue, I can't remember if the ME Super is a mechanical or electronic shutter. Does the shutter function, without any batteries installed? If so, it's mechanical and will not depend on batteries, and therefore there is really no way to narrow down the cause of the issue beyond a good cleaning.
If on the other hand it will not function without batteries, but is with them, you know the power system is working, and the meter itself is the issue. It'll require a technican to open the camera and hunt down the exact cause. Cost for an estimate most places is around $35, if you don't have a local shop, KEH Camera which has a website is very good,
You can of course just use the camera without a working meter. Handheld meters can be picked up from $10-400 online (ebay and others), or you can guesstimate your exposures if using print film using the tried and tested "sunny-16" rule of exposure.
Sep 08, 2011 | Pentax ME Super 35mm SLR Camera
Burner wont light no heat , changed ignitor but still not working.
Is ignitor getting white hot? Look at it and see if it glows. If it does then that part of operation is probably working fine. There are two black valve coils on the gas valve that sometimes go bad. If you have a meter then I believe they should read 1-2 KOhms. ...can't remember. If you don't have a meter then I'd replace both of the coils (shotgun) and see if that fixes it. Hope this helps,
Oct 12, 2010 | Whirlpool LGR5636L Gas Dryer
Light meter not working on olympus 35rc can it be fixed
Three places to look for are:
1)Battery terminals and the wire from the battery terminal. Check for battery corrosion. 2) CdS meter cells is bad 3) Galvanometer is bad.
The camera can be repaired but you will need a donor parts camera.
May 02, 2010 | Olympus Photography
No light meter on Vivitar V3800N
It may be that the batteries that came with the camera are dead. Double check the way you have them installed, both cells should have the positive side up as they sit in the cap. It is best to handle button cell batteries on the round edges rather than the flat sides. The battery cap for your camera should have open slots on the sides so you can place the batteries in using those openings
Feb 01, 2010 | Vivitar V4000 50MM 35mm SLR Camera
Underexposure problem maybe? please help!
Your camera probably needs a new battery.
The light meter needs sufficient power (5.5v to 6v) to work correctly.
Your ISO could have moved, even a double or halving of it will over/underxpose a full stop.
Nov 10, 2009 | Canon EOS-AE-1 35mm SLR Camera
Exposure needle not working
clean the battery cover and contact with a pencil eraser making sure the cap threads are also clean.
this is a fairly expensive repair if the meter or circuit board needs replacing ( no new parts are available ).
if the meter still does not work, and the K1000 is in good working order buy a inexpensive hand held light meter.
Jun 11, 2009 | Pentax K1000 35mm SLR Camera
Nikon D40x Metering Problem
the meter should turn on as soon as you half press the shutter. otherwise remove the lens and try cleaning the electrical contacts on the lens and on the camera body.use q-tips dipped in very light spirits of alcohol, make sure you dont leave any debris around the area. caution with the camera's sensor.
Jan 31, 2009 | Nikon D40x Digital Camera
MY LCD SCREEN DOESN´T WORK GOOD
Hello Emilio, it seems that your camera was in contact with water or Coca-Cola. In order to repair it you should change light guide plate part number: 147913011 or LCD part number: 180572011 or both. Best regards, Arpi
Apr 16, 2007 | Sony Cyber-Shot DSC-S40 Digital Camera
Pentax ME Super 35mm SLR Camera Logo
484 people viewed this question
Top Pentax Photography Experts
pontelemon
pontelemon
Bill Eager
Are you a Pentax Photography Expert? Answer questions, earn points and help others
