Question about Home
Whiledoing a little landscaping, I cut the incoming water line and, while repairing it, I got dirt in the line and it went to two of our toilets. Now, these two toilets will not shut off when the toilets fill. Is therfe a way I can clean them out or do I have to replace them. Please give me suggestions on how to clean or replace. Thanks Jim
    Sergeant:
    Novelist:
  • 193 Answers
Jim, you may be suprised how easy it is to remove the toilet fill valves. Turn the stop **** off at the wall under the toilet. Flush the toilet and then soak up the remaining water in the tank with a towel. In a lot of cases you can turn the supply line fitting by hand. Even if you need a wrench or channel lock pliers, turn the large fitting nut clockwise until it drops free from the toilet tank. Reach inside and lift the valve out of the tank. You probably can't disassemble the valve, but you can inspect it for dirt and debris. Depending on the type of valve, you can probably blow backwards through the valve and watch for whatever is in there to come out. Most valves depend on a float of some sort to raise an arm up to shut the water off. Be sure the float is in the open position when you try to blow through it. What I would do is trot over to Home Depot or Lowes and pick up two of those tank valves that look like a little turtle and put them in instead of cleaning out the old ones. They are less than $20.00 and don't require any float at all. Less moving parts means less things to go wrong. You set the water level in your tank by turning a small screw on the turtle. When you reinstall the valves, whichever one you use carefully tighten the water line nut back to the tank. Do not overtighten. Check for leaks. Do not leave any leak, not even just one drop an hour. Good luck.
Posted on Sep 17, 2010
My toilet has a 1 yr old fluidmaster valve assembly bad it takes nearly 3 minutes to fill after flush,a make s a loud hissing sound. I have another toilet thank takes 36 seconds to fill and more quiet,...
The fill valve may be clogged with dirt or scale. After turning the water supply valve off remove the top of the valve by grasping the black cap section with one hand and the shaft section below with the other. Turn 1/4 turn and the top should come off. Check for any dirt or scale on the top section. Take a paper or plastic cup and turn it up side down holding firmly over shaft section, turn water on to toilet ,water is going to come out under pressure so be prepared to hold cup firmly to catch water and divert it down into tank. This will allow any dirt or scale in the line to be flushed out. Turn water back off reassemble cap section and turn water back on.try flushing toilet to see if problem has been solved.
Hope this helps.
Bob
Jul 05, 2014 | Plumbing
Problem with a PF/2 Energizer (pressurized) toilet. After the flush and the refill... a small stream of water keeps sipping and hissing out from a small tube located towards the bottom of the housing...
there must be some dirt on the seat of the valve as when water is turned off and on sediment , dirt can plug up small orficies take apart the valve by getting a schematic from the manufacturer online to take it apart
Sep 14, 2013 | Home
Winterizing
I think you have covered it all. Just last flush !
Jun 24, 2013 | American Standard AMERICAN STD 12 RGH...
How do I adjust the pressure in a Kohler pressurized flush toilet
You cannot adjust the pressure on the toilet. But you can adjust the stop setting screw at the top of the float arm. If the water is coming in too fast you can adjust the valve where the toilet water line connects to the wall water supply. Closing the valve a little will slow down the flow of water and it will take a little longer to refill the toilet water tank.
Mar 06, 2011 | Kohler - Toilet - Two-piece - Highline -...
Refills too slowly.
You have dirt in the supply tube or the valve...
Depending on what valve is in the tank you can take the top off and wash the dirt out...
Otherwise you may have to replace the float valve inside your tank...
heatman101
Apr 17, 2010 | American Standard 2002.014 - Champion4...
My Maytag mdb 7 dishwasher stopped working on the same day that a Plumber came to our house to fix our toilet. He says he didn't turn off the water anywhere in the house, other than the valve beside the...
If he indeed only accessed the toiled shut off valve, then that would not affect the dishwasher.
Even if dirt/sediment got into the line to the washer somehow, it should be able to be cleared at the inlet valve to the washer.
As to you needing to replace the washer, one would need to determine what the problem is first. It could be a very simple and cheap repair.
If he indeed only shut off the toilet valve, then yes, it would be a coincidence that the washer went out the same day.
If you are on city water, then it is possible that if there is construction nearby or anything that would introduce sediment into the line upline from you, that it could have contaminated the washer.
If your toilet was having problems with water flow as well (thus your reason for calling a plumber) then I would strongly suspect that this is the case.
It is possible that both issues were caused by sediment/dirt from your city water source.
Sep 27, 2009 | Maytag MDBH945AWW / MDBH945AWQ /...
My 14 month old boy threw a pen in the toilet when it was flushing it went down now toilet won't flush well
Pen probably is jammed in the p-trap cast into the toilet and is restricting anything being flushed. This could build up and cause an overflow (yuk!). Worst case is that it went farther into the system and is stuck somewhere "down the line". Easiest way to fix is shut off water to the toilet (small valve on the wall behind toilet). Staighten out a wire coat hanger leaving a small hook in one end. Try snaking it through the toilet bowl where everything goes down and hook the pen and bring it back into the bowl. Proceed gently as you want to try to recover the pen rather than have it go farther into the system. Due to the length of the pen, it is probably not very far up into the trap area. Good luck, and if this has helped please rate it accordingly.
Jul 20, 2009 | Home
DISHES COME OUT WITH DIRT ON THEM
Your incoming water temp should be about 140 degrees. If not boost your water heater temp.
Check the dishwasher drain line. It should be tied up under the bottom of the sink to prevent sink water from backing down the drain into the DW.
Feb 27, 2009 | LG Dishwashers
Home Logo
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
