Question about Sony NWZB135F MP3 Player
My device not switched on and not connected to pc
    Sergeant:
  • 158 Answers
Try to push the reset button for a few seconds. Please make sure that it is properly connected to the USB port.
Posted on Sep 17, 2010
I have an ASUS and it will not connect to my bluetooth mouse. There is a bluetooth on/off switch in Settings, but it is greyed out and cannot be moved from off to on. How do solve this so my mouse w
Not sure your ASUS has a bluetooth transceiver in it. But to make sure, add the dongle that came with the mouse and install the drivers needed to connect the bluetooth dongle and mouse.
Sep 12, 2014 | ASUS Computers & Internet
Tip
Automatic Serial Data Collection
Automatic Serial Data CollectionAs more and more devices come equipped with some type of communication for data collection and monitoring, the amount of data that can be collected by a PC in a system is astounding. A problem arises, however, when multiple instruments or devices need access to the PC through the serial port, but only one port is available.
There are multiple options for expanding the capability of a port that was designed to communicate with only one device. You can add a separate serial port for each RS-232 device that you need to talk to. By adding serial ports, multiple devices can have their own dedicated port, often concurrently and at high speeds. The drawback is that separate serial ports may be expensive and require some effort to configure. There is also a practical limit on resources available inside the PC to allocate to Serial Ports.
Multiple devices can be tied together by converting the signal at each point to a multi-drop bus, like RS-485. This allows up to 32 devices on a single network without repeaters. The devices can also be connected up to 4000 feet away from the PC. The disadvantage is that each device must have its own unique address. Also, some protocol needs to be established to prevent more than one device at a time from sending data to the PC. Usually this is done by having the PC poll each device individually. This does not lend itself well to devices that send their data automatically, without being requested.
Using the 232BSS4 buffered Smart Switch is an excellent way to collect data from multiple devices utilizing RS-232 serial ports. Up to four instruments, card readers, or time clocks can be directly connected to the 232BSS4, providing access through a single serial port on your PC.
If you have more than four devices that are sending data, more than one 232BSS4 can be cascaded, allowing more ports to be added. The 232BSS4 buffers data from all ports at once, making it well suited for devices that will send a fixed amount of data at sporadic intervals, such as measurement instruments, security access card readers, barcode scanners, or time clocks. Below is an explanation of how best to utilize the 232BSS4 to connect these devices to your PC.>
Figure 1
>Figure 1 shows a typical setup, with 16 devices sending information at random times to the PC. The switches at Level 2 receive the data and send it on to the Level 1 switch. The Level 1 switch buffers the data and sends it to the PC. Each of the switches will automatically send the data when it is available. If another port has access to the PC, the data will be buffered until a path is available.
Cascading in Automatic mode:
For best results in an automatic system, the 232BSS4s in the system should be set up the following way.
  • Set the switches to turn on the AutoSelect feature.
  • Set the Port Timer to 0
  • Set the Inactivity Timer on all of the switches to somewhere between 50 and 500 milliseconds, depending on the space between data packets and the response time required to each connected device.
  • If you need your software to identify which port sent the data, set up the port preamble on the Level 2 switches. Set each port to have a unique preamble. The preamble can be 1, 2, 3, or 4 characters long, and any characters can be used. The preamble will be added to the beginning of each new data packet arriving at the PC. The data collection software on the PC should be written to recognize this preamble as an address or identifier of the data source.
Cascading in Polled Mode
This configuration will also work with systems where the devices have to be polled for information. With the setup of Figure 1, the switches can be configured so that you still only have to send one set of switching characters. To do this, set the switches up in the following way:
  • Set the switch on Level 1 to broadcast to all slaves on startup.
  • Set the switch on Level 1 to AutoSelect mode, no preamble.
  • Set the switch on Level 1 for 0 Port Time
  • Set the switch on Level 1 for a short Inactivity Time. Somewhere around 5 milliseconds or so.
  • Set the switches on Level 2 for no AutoSelect.
  • Set the preamble on the Level 2 switches to be unique from each other. One suggestion is to use a 3 character command. Use the first character as a start of command character like STX. The second character could represent the address of the Level 2 switch you are going to. The third character is the command character.
on Sep 12, 2010 | Computers & Internet
Cannot upload photo to pc
Please send your question in more details.
1) What device you are using to upload photo to the PC;
2) How is the device connected to your PC, by wired, or by wireless connection?
3) If by wired, the method of connection, i.e. direct connection without router, or connected via router; or via USB connection
4) what program is your device using to transfer the photos? e.g. wi-fi direct, blue-tooth transfer etc.,
5) how large is the size of your photo going to upload?
After getting all these information, then we can sort it out for you one by one the possible solution.
Jul 23, 2014 | Alcatel Computers & Internet
Can you trace which switch and port was used by a mac
You can connect it again and it will take the older port itself. But don't connect any other device.
Power Performance Chip
Aug 08, 2012 | Compal DL70 PC Notebook
Not connect from console port
Verify that the correct settings and cable/connectors (rollover cable, correct COM port specified) are being used when establishing the console connection.
From the manual-
3.9.2 Connecting to an IBM or Compatible Device
To connect an IBM PC or compatible device, running the VT terminal emulation, to an
Enterasys Networks module Console port (Figure 3-20), proceed as follows:
1. Connect the RJ45 connector at one end of the cable (not supplied) to the Console port on the
Enterasys Networks module.
Connecting to Console Port for Local Management
Hardware Installation 3-31
2. Plug the RJ45 connector at the other end of the cable into the RJ45-to-DB9 adapter (supplied
with the device).
3. Connect the RJ45-to-DB9 adapter to the communications port on the PC.
4. Turn on the PC and configure your VT emulation package with the following parameters:
Parameter Setting
Mode: 7 Bit Control
Transmit: Transmit=9600
Bits Parity: 8 Bits, No Parity
Stop Bit: 1 Stop Bit
source: Install Guide for Enterasys 1H582-25 / 1H582-51 (http://www.retrevo.com/support/Enterasys-1H582-51-Switches-manual/id/2785dj098/t/2/)
Jun 22, 2011 | Enterasys MATRIX E1 (1h582-51-g)...
Ip address
  1. Type 192.168.0.1 or 192.168.1.1 in the URL web page address bar.
  2. Click on setup>Basic Settings
  3. Check the box labled DHCP.
  4. Make sure that the devices on the network have Obtain IP Address automatically radio button is checked on the network connections.
Now, all the devices are connected to network. Understand the meaning of 'Server'. Any PC can be a server, for that mater most devices can be a 'Server'. The term simply means providing resources like files, folders and printers. However how secure your resources are is determined by the operating system on the PC or device providing resources (printers, files/folders, cameras) . I recommend Microsoft Windows Server 2003 Standard as a Network Operating System for your PC. This is a very powerful and sophisticated OS and will most likely only be used to its fullest ability by a MCSA or MCP. This is not an OS that can or should even be touched by an average or expert PC user. This OS is intended to be managed by a professional trained and certified to use the OS. Please contact if you have any more questions in this area. This is my area of expertise.
Jun 16, 2009 | D-Link DES-1008D 8-Port Ethernet Switch...
Message showing - player problem connect pc and fformat player
i have philips gogear sa 1356/97 mp3 player.it is not working .when i switch on the player a message displays "Player Problem-Connect to pc-format player". My PC not detecting the device.
Jan 19, 2009 | Philips GoGear SA1350 MP3 Player
Philips firmware upgradation
on switching on mesage displays connect it to pc and repair using philips device manager , what to do now ?
Jul 06, 2008 | Philips GoGear SA3125/37 MP3 Player
Connect to PC and use device manager to repair
If you have the software conect the device to the computer; press volumen + with on/off switch at same time; then press volumen - anh hold it. The software recognice the device and you can update the firmware or repair it.
Aug 20, 2007 | Philips GoGear HDD6330 MP3 Player
Connection problem between modem router and hub
Sounds like you may need what is called a "Crossover Cable' connecting your router to your hub, or if either device has an uplink port, use it on one device to connect to normal port on other device. Here are instructions for making your own cables: http://www.lanshack.com/make-cat5E.aspx
Dec 08, 2006 | Kingston EtheRx Networking Switch
Sony NWZB135F  MP3 Player Logo
506 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
