Question about Dell E173FP 17" LCD Monitor
I have a similar problem to one posted a few months ago - flashing LED on the power button, except the monitor does come on after a couple of minutes and the LED stops flashing. bdmrtn said to the other poster: "You may have shorted out transistors in the inverter circuits, common problem. Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). " Would mine be the same possible problems, just less far along? The problem just developed last night.
  • 1 more comment
  • Louis Ebert Sep 17, 2010
    mmckitri, May very well be your Dell e173FP has same failed components as stated by "budmrtn". Just tell us the "brand names" of the capacitors (electrolytic filter caps) you find populating your monitors "switch-mode-power-supply / cold-cathode-fluorescent-lamp-ballast circuit board" !!!! Are any of them named "CapXon" or "ELITE" or "Jun Fu" ??? If you find any of them I suggest you make sticky lable and place it over the Dell logo of unit with new name of : CrapXoff!!! Good luck with the repair. 12fixlouie
  • mmckitri Sep 19, 2010
    So far we have bulge-y leaky capacitors. Still looking. Will keep you posted :) Thanks so much for the tips.
    Mary
  • mmckitri Sep 26, 2010
    We replaced the 2 leaky capacitors, crossed our fingers, and w00t! The monitor is back in business. The old capacitors were rated at 10V, and we replaced them with 16V ones.
    Thanks so much for your help budmrtn!
  • 11,361 Answers
Look real close at the solder joints on the inverter transformer pins, and the transitors. What usually happen is that the cold solder joints will mess up the bias on the transistors or causes arcing and that will take out the transistors, you need good magnifier glass to see, you will see ring/cracking around the component's leads.
http://s807.photobucket.com/albums/yy352/budm/Poor%20solder%20joints/
It will get to the point that the transistors 2sc5707/5706, and also still should look for bad caps.
Replacement board: http://www.lcdrepair.us
http://s807.photobucket.com/albums/yy352/budm/Dell%20E173FPb/
Posted on Sep 18, 2010
    Mary
    Mary
TX-32LZD81 fault red led flashes 13 times, repeating regularly after being taken out of standby. The led goes green initially for several minutes before it starts flashing
13 flashes denotes a fault to its main board. If you wish to get more details about these blinking codes, check this link.http://electronicshelponline.blogspot.com/
Pull up previous posts by its left sidebar, or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.
Sep 18, 2013 | Panasonic Televison & Video
I have a Panasonic PT-52LCX66 television that I bought just over 4 years ago. I have replaced the bulb for the second time just 3 months ago and now the set will just shut off after about 3 minutes of...
Tv making and have clicking sounds as tv shutdown as lights flashes?Yes.The board that call the Ballast board might be dying and dead soon.This Ballast board job responsible only are to ingnite the tv projection lamp only.
Jun 30, 2011 | Panasonic PT-52LCX66 Projection Television
Samsung Syncmaster 941BW No power
My Samsung 941BW would not display, only a flashing blue power button; no-onscreen menu, nothing. The internal power supply had 9 CapXon brand capacitors. Two (C109 & C110) were bulging. I replaced all except the huge 100uF 450V Cap and Presto-Magico....the monitor works fine now. If you are comfortable replacing circuit card components, go for it! Thanks for the tip, budmrtn!
Aug 27, 2009 | Samsung 941BW LCD Monitor
Sharp 52" Aquos LCD Will Not Turn ON-Blinking LEDs
I had a similar problem. Fleeting video, then audio only for few seconds and then nothing except the green power LED blinking on and off.
I changed the power inverter board, backlight inverter boards and power supply board but still the problem is not gone.
Just 18 month old TV and out of warranty.
Jun 06, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Blank screen, flashing led power light
this sounds exactly like what happened to my 2232BW. I took screenshots of the fix and posted them on my webpage:
http://www.alexdemo.site90.com/#samsung2232bw_fix
Jun 03, 2009 | Samsung SyncMaster 2233BW 22" LCD Monitor
Lcd monitor power light flashing with no img. seems 2 be frozen
The display is in safe mode and you will need to reset the display to get the display out of the safe mode. There are 2 different model revisions. Please choose the method that will match your revision. Depending on the revision of the monitor, one of the following 2 methods should reset it to a normal state. This reset generally requires both hands and it is sometimes easier with another person.
If the serial number begins with an A and/or your power button on the far right (5th button from left):
Method #1
1. Unplug the VGA cable.
2. Remove the power cable from the back of the monitor.
3. Counting the buttons on the front of the panel from left to right as 1 – 5, hold the buttons 2 and 3 down at the same time (see picture above) and while continuing to hold the buttons, plug the power cable back in.
4. Keep holding the buttons for 5 seconds after the power has been plugged in and then let go. The green light should be steady when you release the buttons.
5. If the procedure worked, the green light will go to amber and you should see a "No Signal" message on the screen for a few seconds.
Method #2
4. Keep holding the buttons until the 4th green LED blink; then, let go. The green light should be steady when you release the buttons.
If the serial number begins with a B and/or your power button is in the middle (3rd button from left):
Method #1
3. Counting the buttons on the front of the panel from left to right as 1 – 5, hold the buttons 2 and 4 down at the same time (see attached picture) and while continuing to hold the buttons, plug the power cable back in.4. Keep holding the buttons for 5 seconds after the power has been plugged in and then let go. The green light should be steady when you release the buttons.
Method #2
3. Counting the buttons on the front of the panel from left to right as 1 – 5, hold the buttons 2 and 4 down at the same time (see picture above) and while continuing to hold the buttons, plug the power cable back in.
If you have tried the reset a few times and it does not solve your issue, please Ask a Question to submit a request through the system or call 1-866-752-6271 Option 1 to contact technical support.
Mar 02, 2009 | Planar PL1910M (Black) 19 in. Flat Panel...
No Display on my Samsung 204B monitor
If you know how to open it up and get to the power supply you will find three capacitors 2-820uf and 1-330 @ 25vdc 105o.they will have puffed up tops replace them. FYI the monitor has a 3 year warranty.
Dec 12, 2008 | Samsung SyncMaster 204B 20.1" LCD Monitor
Presario SR1030AN Turning on but not booting or POST or no any beep at all.
Have you tried switching the power supply out with one that is known good?
Nov 26, 2007 | ASUS A7V8X Motherboard
Sony GDM-F500R (G1 Chassis) has trouble turning on
sometimes relay contacts get "sticky" from arc oxide corrosion whenever enough electricity is passed from metal to metal...in a perfect mechanical relay, the relay would be sealed in a vacuum. Try swapping relays to transfer the problem. If you can transfer it, you found the bad relay. I actually have disassembled relays and polished their contacts with great success.
Nov 13, 2007 | Sony GDM F500R Monitor
Mag Innovision LT765b 17 in. Flat Panel LCD Monitor
It sounds like this one needs component-level troubleshooting, probably in the power supply section.
Aug 30, 2006 | Mag Innovision LT765b 17" Flat Panel LCD...
Dell E173FP 17" LCD Monitor Logo
832 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
