FixYa.com
Tags:
Denon AVR-3805 7.1 Channels Receiver
Denon AVR-3805 (by 4 users)
posted by lwf3 on May 17, 2008
I have a Denon AVR-3805. It works great. However, today I'm having a problem even switching it on! It is in standby mode with the red light around the standby button is flashing. When I switch the sytem on it comes on for just a few seconds and then immediately truns off and goes back to standby mode with the red light flashing again. Any ideas what is wrong? I disconnected all the inputs and output connections to no avail. I tried to reinitialize the processor to no avail. Any suggestions???? Thanks, Lance
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
3 Other Users Have The Same Problem
Comment by Guest, posted on Jun 24, 2008
My Denon 3805 also shuts down for unexplained reasons. Recently, it has turned off completely. When I press the "on" button, it turns from red to green but nothing else lights up. Is an authorized Denon dealer my only option?
Comment by Guest, posted on Jun 15, 2008
Exact same problem. Unit turns itself off after a few seconds or after a couple of minutes. Nothing has changed on our system nor have the room conditions changed to cause any type of flucuation. This is extremely frustrating and nothing you have posted works.
Comment by tricor, posted on May 25, 2008
I am having the exact same problem
Solution #1
posted on May 26, 2008
Not Rated (0)
DocBill
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
It's likely that you have shorted some speaker outputs, I had that problem and sorted it. Unfortunately it does mean replacing some output transistors..the devices are dificult to get to just to add insult to injury. They are the devices that are mounted directly onto the large heatsink and solder connected to the bottom circuit board. You only have to change the matched pair that you have blown....tricky to identify which ones without some electronics knowledge. The power output section does have some fuses to protect it but sadly these do not appear to be fast enough to stop "one" from damaging the power output stage if you unfortunately short outputs. The transistors are available from Farnell, use pin compatible replacements SAP15N and SAP15P.....all the best. Doctor Bill
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Receivers problems?
Loud crackling noise when set...
My Denon AVR-3805 started... Answer This...
Denon AVR3805 connected to...
I can't seem to use the Denon's... Answer This...
Audio Cuts in And Out on CD
My model is actually the AVR... Answer This...
Setting the Balance is a...
I can not get the right... Answer This...
Denon PMA-655R
Hi AMP = PMA-655R The amp... Answer This...
Repair Service
Find Receiver Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
