Question about Cell Phones
How do u unregister a bad Panasonic KX TGA740 handset?
1. Hit the Menu button.
2. Go to the 'Initial Setting' option (second icon in the right column.
3. Scroll down and select 'Registration'
4. Select 'Deregistration'
After you have done this, follow the on-screen directions to deregister the handset that is bad. You must know what handset number you wish to deregister to do this.
Posted on Jul 29, 2012
2 Suggested Answers
  • 3278 Answers
SOURCE: I recently purchased a KX-TGA600
Hello.
Be certain you registered the phone properly:
On the Base, press and hold LOCATOR until the IN USE light flashes. On the handset, press OK then wait until a beep sounds.
If you registered this properly, the way to reset is to remove the batteries of the handset and leave for a period of time (at least several hours).
try to register again.
If still the same problem, I suspect that the reconditioned handset is faulty and should be returned.
Hope this helps.
Posted on Feb 03, 2011
Panasonic user manual free download KX TGA740
The manual for the KX-TGA740 add-on cordless handset is available from the product page: http://shop.panasonic.com/support-only/KX-TGA740B.html?supportpage=true . The direct link to the manual is ftp://ftp.panasonic.com/accessory/phone_fax/om/kx-tga740_en_om.pdf . You may find more useful information on using the handset in the manual for the base phone with which you'll pair the handset. The KX-TGA740 is compatible with the KX-TG6411, KX-TG6421, KX-TG6431, KX-TG6441 and
KX-TG7431 phone systems. To find the manual for any of these models, see http://shop.panasonic.com/support . Enter the appropriate model number in the search bar and press enter. Scroll down the page to the support section if the page doesn't come up in the correct section.
I hope this helps.
(the handset will work the same even if your handset has a different letter suffix.)
Jan 25, 2017 | Panasonic Lands Phones
Where can I get an instruction manual?
Panasonic kx-tga600b handset manual - Google Docs
https://docs.google.com/document/d/.../edit Google Docs, Sheets, and SlidesPanasonic kx tga600b cordless extension handset manual. Panasonic kx ...Panasonic kx tga520 5.8 ghz fhss cordless expansion handset manual. Panasonic kx ... Panasonic kx tg6071 operating instructions manual pdf download. Panasonic... Need manual for kx tga600b so i can turn off voice mail dont need. Panasonic ...
Kx-tg6500 manual - Google Docs
https://docs.google.com/document/d/.../edit Google Docs, Sheets, and SlidesPanasonic kx tg6500 operating instructions manual pdf download. Panasonic ...Panasonic kx tga650b cordless extension handset installation. Troubleshooting ...Panasonic kxtga651b dect 6.0 plus expansion handset black kx. Panasonic kx ...Can i register a kxtg6500 handset with a kxtg4500 base. Panasonic kx tg6502 ...
Panasonic KX-TGA650B ' Installation Manual - Page 3
Feb 09, 2016 | Panasonic KX-TGA650B (037988474806)...
How do I unregister a lost handset for a Panasonic phone kx-tg5576
Since you do not have the phone anymore, obviously you cannot use it to deregister it! So here is what you do: One the base unit, Press and hold {INTERCOM} until the CHARGE
indicator flashes, then (2) Press and hold the handset's
extension number {1} to {8} that you do not want for 5
seconds. A long beep sounds, then the handset
number is erased. This will deregister that number handset unit.
Sep 23, 2014 | Panasonic Phones KX-TG5571
I cannot get my Panasonic base KX-TG5583 to register 8th handsets - only seven
It has to do with the electrical load that each ringer imposes on the line. Each set has a limit on how many handsets you can register with it. If you look on the bottom of the base you will see on the identification plate a data item called Ringer Equivalence Number or REN.
In telecommunication, a ringer equivalence number (REN) is a somewhat arbitrary number which denotes the electrical load a telephone ringer has on the line.
Dec 05, 2013 | Panasonic KX-TG5583 Trio Cordless Phone
How do you record an outgoing message
The KX-TGA740 is a cordless handset. The outgoing message is on the answering machine. Please consult the documentation for whatever answering machine you have on your phone line. If you require further assistance, please reply to this post and specify the make and model of the answering machine.
Oct 09, 2013 | Panasonic KXTGA740B - - Phone
I need to know how to unregister a handset from the base. Model kx-tga450b
On the base, press menu, initial setting, registration, deregistration. Then choose the handset number you wish to deregister.
May 09, 2011 | Panasonic KX-TGA450B Cordless Expansion...
Phone keeps saying move closer to base
The handset may have unregistered from the phone. The instructions to reregister it are in the manual, but I'll list them here for you.
1. On the handset, press MENU 001
2. On the base unit
For models KX-TG6021/KX-TG6022/KX-TG6023
Press and hold LOCATOR until the IN USE indicator flashes.
For models KX-TG6051/KX-TG6052/KX-TG6053/KX-TG6054
Press and hold LOCATOR/INTERCOM until the IN USE indicator
flashes.
After the IN USE indicator starts flashing, the rest of the procedure
must be completed within 1minute.
3. Press OK on the handset, then wait until a beep sounds.
4. Press OFF on the handset.
Aug 29, 2009 | Panasonic KX-TG6021 Cordless Phone
Panasonic KX-TG2740 Cordless Phone - Can I reset handset registration
press function button on handset, scroll to initial setting, select by pressing right arrow, scroll to registration, select, select hs registration, follow directions on handset display, pressing mute on "new" base station, and ok on handset(plugged in). If you like, you can unregister with the "old" base unit first.
Oct 18, 2007 | Panasonic KX-TG2740 Cordless Phone
Cell Phones Logo
306 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
