Question about RCA HD52W56 52" Rear Projection HDTV
RCA 52" can't set up PIP do I need to split cable?
When i press PIP it comes up but then i can't switch both change to same channel please help
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 317 Answers
Why?
Posted on Jun 04, 2008
Rca entertainment series pip. The audio is messed up. Some channels r silent, some are in spanish, some music play but not the voices. Called cable company they said the cable is fine. Help me please.
You have a simple problem:
It can be either in the set or a cable box if you use one:
The set in the audio menu or setup menu will have a setting called SAP- WHICH is secondary audio program--it will on certain channels do exactly what you describe--Spanish for Monday Night Football and music and such.
Find it in either the box if used or the set and switch it with the remote to Stereo (move it OFF of SAP)
I am surprised the cable company did not suggest this but ......
Mar 29, 2012 | RCA Televison & Video
I have the Eurolive B212A speaker,and the Xenyx 1202fx.I want to play my Ipod using this set up.Please help with connection
The Ipod is stereo and your speaker is not, so don't expect stereo.
Find a 1/8 inch stereo cable that splits the two channels into individual cables and enter those into two channels of the 1202 mixer. You might find a cable that goes from the 1/8 inch stereo and splits to two RCA type jacks which you have to either find RCA inpouts on your mixer or get two RCA to 1/4 inch adapters.
Crank the pan controls clear to the left on those two channels. Run a cable from the 1202 left main out to your speaker input.
Adjust the controls as needed.
Jan 03, 2010 | Behringer Music
How to split the screen to look at 2 channels.
try looking under your TV's menu, find the pip or split option and set them up, then on your remote, you should have a pip/split button..see if you can now watch tv with pip or split. If you need more help please be more specific about what the tv is doing when you push those buttons on the remote etc.
Dec 27, 2009 | Panasonic PT-47WX53 47" Rear Projection...
My big screen tv keeps changing channels. when i set it on one channel
YOu channel changing button on the TV have pressed in, just try pressing the channel button in you tv so that it gets released..
This should solve your issue..
Please rate this solution if this solves your issue, or leave me comment ill help further
RNJ VINODKUMAR
Dec 17, 2009 | RCA P52926 52" Rear Projection Television
Mitsubishi WD-52628 52" Inputs look like old cable scrambled channels
Change the 1000uf @16v capacitors on the FMT board that should solve your problem. You will most likely found that they have swelled. Let me know if you need further info.
Apr 04, 2008 | Mitsubishi WD-52628 52" Projection HDTV
RCA PIP
Put something else, DVD player, VCR or a second signal, into one of the other inputs on the unit and switch the PIP to watch that input...
Nov 20, 2007 | RCA D52W19 52" Rear Projection Television
Can't get second picture in Picture-in-Picture (PiP)
Watching two separate tv channels at the same time requires two tv channel sources,i.e. a split of some kind. For instance,the cable coming in thru the wall is split-half to tv or vcr/dvd combo and then to tv,the other half to cable box,then out to tv.If what I described fails,then you may have an actual tv failure.PIP video is generally a separate circuit from standard video.An expert tech w/service literature should be able to help. Let me know if you need more assistance.
Sep 16, 2007 | RCA HD52W56 52" Rear Projection HDTV
RCA TV won't change channels
Your set uses the 195 series chassis and you have something set wrong in your guide plus. Go into the TV's menu and do a complete set-up. Take the remote and press MENU, then "8" to enter setup, then press "1" for "begin setup now" and then press "1" for English, and so on. You must enter "set up guide plus+", then press OK on the remote to choose "setup", select "USA", enter your zip code, and then if you choose "yes" for "do you have cable?" you MUST then choose "no" for "do you have a cable box" If you choose "yes" for that choice, your tuner will lock on one channel no matter what channel you try entering. After choosing "no" for "do you have a cable box", choose "no" for "do you have a VCR?", exit the guide plus menu and then skip the rest of the steps by pressing "2", and then exit the main menu by pressing "0". Your channels will then work normally.
Aug 29, 2007 | RCA P52937 52" Rear Projection Television
Rear projection snow
Bad primary tuner==can be replaced,or==by-pass by using video inputs.
Aug 26, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Pip
Take the cable wire that hooks to the IN connector on your cable box and hook it to the IN connector on a 2-way cable splitter.Get 2 more short cable wires and hook one end to the OUT connector on the splitter and the other end to the IN connector on the cable box.Take the other short wire and hook it to the other OUT connector on the splitter then hook the other end of this wire to your tv (you must have two sets of RF connectors on your tv for this to work)Or you can tap the A/V connector off your cable box hooked to a video input on your tv.
Aug 19, 2007 | RCA P52930BL 52" Rear Projection...
RCA HD52W56 52" Rear Projection HDTV Logo
29 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
