Question about Yamaha HTR6230 Receiver
Yamaha htr-3063 speakers won't work with my speaker wires I had pre wired. I got a check speaker wires message when I connected the speakers after it cut off on me. What is the solution?
Wires shorted or broken. run new wire !
Posted on Oct 06, 2010
Yamaha HTR-3063 AV Receiver has stopped working. I turned it on and the lcd screen scrambled, then sound cut out. Can I fix this?
Have you tried switching the unit on with no cables or speakers connected and yes the unit can be repaired no problem.
Jun 15, 2016 | Yamaha Audio Players & Recorders
No picture using my playstation 3 with my yamaha receiver htr 3063
you might have to reset the video output. hold down the power button for 5 seconds. It should beep and the iight will flash. wait a few seconds then turn it on.
Nov 16, 2011 | Yamaha HTR-3063
Speakers wont work on the htr-3063....worked 10 minutes before on the old receiver
check to see what ohm your speakers are using. I know the 3063 supports both 6 and 8 ohm but it is defaulted at 8.
Aug 16, 2011 | Yamaha HTR-3063
How do I connect a CD player to my Yamaha HTR-3063 receiver?
... in whatever manner it requires according to its manual. The Yam accepts just about anything.
http://www.retrevo.com/support/Yamaha-HTR-3063-Receivers-manual/id/23653ag915/t/2/
Aug 14, 2011 | Yamaha HTR-3063
On my HTR-3063, I could not get it to come on. So, I unplugged all the cables and speaker wires, and I plugged it in without any plugs or wires, and it turned on. So I changed all my wires and HDMI cables,...
Generally speaking, an amp protects itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Add things one at a time until you identify the one component (probably a speaker) that is causing the problem.
Mar 22, 2011 | Yamaha HTR-3063
How to solve a W 1 error on a Yamaha HTR-3063
Are we really talking about a HTR-3063?
Register and download the manual for free at retrevo.com
Strangely enough, that message is NOT documented in the HTR-3063 manual, but in another Yamaha manual (HTR-5063) it means the speaker being tested is believed to be Out of Phase, meaning wired incorrectly.
Your unit (HTR-3063) doesn
Feb 15, 2011 | Yamaha 5.1-Ch. Surround Sound Home Theater...
I have a yamaha htr 5890. I would like to hook up
You are probably connected to the pre-out jacks. These are not amplified. Connect them to the B speaker outputs(screw down connectors). If that won't work (and it should), you can connect to the "Presence" speaker connections(spring loaded connections).
Feb 02, 2010 | Yamaha HTR-5890 Receiver
NO sound, display says CHECK SP cable? Just bought yamaha292 theater system with AV receiver HTR-6230, all speakers are wired, plug with 1 optical to my TV, selected the inputs and there's no sound. ...
Probably the speakers are not wired correctly. Check this by turning on the receiver without speakers connected. If the message is gone, issue was in the connection of speakers. Check that you have not short-wired the + and -.
Dec 13, 2009 | Yamaha HTR-6130 Receiver
"Check Speaker Wire" error on my Yamaha Receiver
found the source of the problem with "Check SP Wires"! to solve it is necessary to check each speaker connected to the device Yamaha on the rear panel (red and black) using the device for determining the number of ohms, which shall not be less than 4 ohms, in large passive speakers experienced in Amfitone AU-027, the result showed that left at 0.45 (7) ohms, and the right-hand column, as such, no.
The successful test ... and good music!
Mar 13, 2007 | Yamaha HTR-5790 Receiver
Yamaha HTR6230 Receiver Logo
481 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
