Question about CTX F973 19 in. Flat Panel LCD Monitor
CTX P973 19 in. Flat Panel LCD Monitor: Won't power-up Over a period of many months my CTX monitor has progressively got worse and now it no longer powers-up. Please help identify any possible faulty component. The 2 stages of the symptoms are as follows :- Stage-1 My CTX P973 monitor started showing tearing (interference type)lines over the full screen when pressing the Power-On button but soon cleared and full video became present and stable until the next switch on. Stage-2 Now the monitor wont power-up at all (no LED lights on the power button, blue or amber) however, on removing the power plug the blue LED lights momentarily. Similarly the blue LED lights up momentarily when re-inserting the power plug. But the power-on button no longer lights up when pressed and the monitor remains totally dead. Please can anyone suggest a possible component/s that could be the culprit (a specific Capacitor maybe ?).
  • Louis Ebert Sep 17, 2010
    micheluzzu, First thing to do is watch some of the better and more informative video clips at YOUTUBE so you will know just what you will be looking (visual inspection) for inside your CTX P973 !!! All "cold-cathode-fluorescent-lamp" lcd monitors use same basic design and operating principles to display text and graphics on their glass lcd panel. If the "switch-mode-power-supply can't supply dc voltage and current to the rest of the key circuits in monitor you will have a black or blank n black screen to look at. Do extensive reading and follow all links you find in the fixya profiles/testimonials of "budmrtn" "buddymc" "12fixlouie" and other technicians here on fixya. Then come back after you have done your research if you need more help with your unit. 12fixlouie
3 Suggested Answers
SOURCE: Monitor wont power-up
It is usually the Large Value Caps around any heatsinks etc. in the Power Supply.. I usually simply replace ALL Large Value Electrolytic Capacitors, with same or better temperature ratings. This often fixes any problems.
Posted on Jul 24, 2007
SOURCE: ctx no power up
What are tearing lines?
Posted on May 29, 2008
How to fix No Display on LCD Display Panel at all?
Good day, For you lcd issue you may try doing these steps:
1. Check if the the power cable of properly plugged in.
2. Check the cable connecting your monitor to the tower or CPU
3. If there's no power at all you can try to change the power cord and also the monitor to cpu cable.
4. You can also plug it on another outlet to make sure that its not your power outlet that's causing this problem
If everything above doesnt work for you, you might consider having it check by a technician or just purchase a new one. Hope this information help you a bit. Have a great day.
May 24, 2011 | CTX Panoview 510 (White) 15.1 in. Flat...
It power downs after saying no VGA input
Is your PC Video card, VGA cable and connectios are OK, please check them out first.
Post back what you find since it can be your PC may not be sending out the video signals to the monitor. PC works OK with another monitor?
Please post back what you find.
Please leave ratng if it helps.
Feb 05, 2011 | CTX S962G (Black, Silver) 19 in. Flat...
I'm missing the power adapter for the CTX Monitor S500. Where can I find one?
http://www.google.com/#hl=en&source=hp&q=power+adapter+for+the+CTX+Monitor+S500&btnG=Google+Search&aq=f&aqi=&aql=&oq=&gs_rfai=&fp=ff274912d96214e6
Jun 24, 2010 | CTX S500BA (Black) 15 in. Flat Panel LCD...
LG hdtv picture has started to get fuzzy and it
How many years have you had the TV?
The systems wear out over a period of about 2- 4 years.
LED systems, now very expensive, have a longer life expectancy than LCD systems.
Apr 16, 2010 | LG 42LC2D 42 in. LCD HDTV
Hello, A family member gave me a CTX S760 17- LCD Monitor. When I hook it up and start my PC the screen looks GREAT for about 15 sec or so and then goes black. Same thing will happen if I power off the...
christoph972, This really sounds like a SMPS going into SHUTDOWN MODE after detecting a fault in the "cold-cathode-fluorescent-lamp" electronic ballast circuit which is called an INVERTER CIRCUIT, or it has a problem all by itself. The big question is? ? ? WHAT is causing the fault? I need you to do the flashlight test to evaluate the condition of the LCD monitor's "switch-mode-power-supply". With a KNOWN-GOOD, fully booted pc that has the WIN-desktop showing, reconnect the S760 to the pc. then and only then push the "ON" button for the monitor and note what happens. After the screen goes black, shine a bright flashlight at different angles about 1" from the LCD screen. Get back to me with the results of test. Did you see or not see the WIN-DESKTOP? Also visit YOUTUBE and search for and view videos of typical lcd monitor disassembly and or lcd repair. FYI only!! The longer ones (8-12min) will be more informative. The symptom you have with this freebie monitor is classic! It could possibily be repaired for $12 or less. Get back to me here at fixya by posting another comment to the above stuff you already did. I"m louie12fix onfixya or lmistyrel @aol.com
Oct 08, 2009 | CTX S760 (Beige) 17 in. Flat Panel LCD...
Looking for AC power Adopter for CTX LCD monitor
Check it on Radio Shack maybe they got something
Jun 03, 2009 | CTX SV900MD 19" LCD Monitor
Ctx lcd monitor turns off after 1 second
Your backlight fluorescent bulb is burned out.
Dec 24, 2008 | ViewSonic VE710b 17" Flat Panel LCD...
Brightness of monitor changes itself to quite dim
YOu can go to the monitor settings to make sure nothing's been changed. It could be an energy saver issue where the display dims after a certain period of time, and you can reset it to longer period of time so it would stay bright for you
Dec 12, 2008 | CTX PV 700B 17" LCD Monitor
Sporadic Discoloration & Distortion
Most of these monitors have a 3 year warrantly. Give them a ring and see if they will exchange it. No harm in trying!
Mar 22, 2008 | Acer AL1912B 19" LCD Monitor
Jul 01, 2007 | CTX F973 19 in. Flat Panel LCD Monitor
CTX F973 19 in. Flat Panel LCD Monitor Logo
56 people viewed this question
Top CTX Computers & Internet Experts
Rommel Balcita
Jerry Greenberg
Jerry Greenberg
Are you a CTX Computer and Internet Expert? Answer questions, earn points and help others
