Question about Zanussi Dryers
Start button not working on my Zanussi TCE 7276 W. I have undone 2 screws but I still cannot see how front panel comes off so i can investigate and do not want to force it in case of damage. Can anyone advise how to remove please?
4 Suggested Answers
bomark2002
  • 160 Answers
SOURCE: Broken Zanussi tce 7127 w dryer
the dryer is telling you a trouble code like in a car when something is malfunctioning with it, try to call your manufacturer and ask them to tell you what that code means.
Posted on Nov 06, 2009
Testimonial: "That's a great starting point - thanks! I rang the manufacturer and they didn't know what the code meant..."
SOURCE: TCE 7227 W tumbledryer waterconductivity needing regular restting
Carolsquires, I have the same problem with 7227, did you get a solution?
Trevor
Posted on May 31, 2010
SOURCE: Zanussi TCE 7276 W Condensing Dryer
hi i have a problem with the zanussi 7276w model all lights are on ready to start but the tumble dryer will not start
Posted on Jan 08, 2011
Cannot remove control panel from a Zanussi FJ1295 WASHING MACHINE, trying to replace push button which is stuck
take 2 7mm scews top left and top right then the screws from soap tray
when looking into machine from the top there are clips on the inside of the front panel down the side push them in ward and use a flat head screw driver to push the panel out repeat on other side not to much force is needed take your time
Jan 31, 2015 | Zanussi Washing Machines
Zanussi Tumble Dryer TCE 7276W error code E50 - what shall I do? I put washing in TD and set it A and turned it on, it came up 2.05 as it always does but after some time, I come across "End" is...
Hello this is Dennis from blue hawk electronics I had the same problem with my Zanussi tumble dryer and all I did was to take out he front circuit board and reflow board and has been working fine now for 9 months and still going strong
Sep 03, 2011 | Dryers
Tce 7276 tumbledryer error code E60 keeps coming on then the door opens what does this mean
Sorry I dont know the answer but maybe a quick call to Zanusi service department can advise what that means.
Feb 05, 2011 | Washing Machines
Zanussi TCE 7276W Condensor Dryer - no red lights but won't go!
Hello, have you cleaned the condensor stack just recently if so check that the stack etc is fitted correctly and the door is closed fully.
Hope this helps.
May 14, 2010 | Dryers
Has the condenser been cleaned lately if it is not put back in correctly then sometimes the micro switch on the door does not click in,check this door where the condenser sits.
Hope this helps.
Mar 25, 2010 | Dryers
Trevor
Feb 17, 2010 | Zanussi Dryers
Nov 06, 2009 | Dryers
ZANUSSI ZWF1237W 2 YEARS OLD NOT WORKING
The motherboard is blown the part is covered under warranty which will take 4-5 days to come in and I have to pay for the labour.
Jan 22, 2009 | Zanussi ZWF1430W Front Load Washer
Sep 21, 2008 | Zanussi TC7114W Electric Dryer
Remove panels from ZanussiWDS1183W
once uve got the lid of there about 3 or 4 screws on each side brass coloured undo 2 on each side closest to the back once uve undone them down the side panels at the bottom ull see a plastic cover with a hole in the middle put a thin tool into the hole and pull to the side this will show u another screw on either side undue these now go to the back undue the screws at the back now last thing for u to do is the suspension springs at the top u will need to lift the washer tub up whilst leaving the frame work on the ground once u have lifted this get a flat screwdriver and squeeze it under the spring head which comes up and over were the first screws are that i told u to remove u need to get those springs out so u can pull the sides away from each other and pull backwards m8 might sound hard but its not
Feb 23, 2008 | Zanussi WJS1397W Front Load Washer / Dryer
Dryers Logo
64 people viewed this question
Top Zanussi Dryers Experts
Tim Whalen
Gerry Harvey
Gerry Harvey
Are you a Zanussi Dryer Expert? Answer questions, earn points and help others
