Question about Delfield 113.28 cu. ft. Commercial Freezer Meridian MFRI3S Stainless Steel
Delfield MD # 6151 - S Sr # 206156-T not pulling down to Temp set at -10 and only pulling down to 24 freon is good
    Sergeant:
    Novelist:
  • 193 Answers
Take the top cover off that is next to the compressor,. That cover is about 30 by 30 inches. You will see two fans and an evaporator coil. Several things can happen. First these fans won't come on until the coil is somewhere around 10 degrees or if the door is open. So, once the freezer has been running look under the big cover and be sure both fans are running. If one or both are not running it won't pull down to 0. Also look at the coils and see how much frost has accumulated. If your defrost timer is not working it may be frozen over. When that happens air is blocked from reaching the inside of the freezer. While you are at it, fell of the coils if they are only partially freezing, you may be low on freon. If you have gauges to check the freon charge, check both the high side and the low side pressures. If the high side is less than 200 psi, you have some freon, but maybe not enough. If the high side pressure is 300 psi, you have something blocking the freon from returning to the compressor. Usually a blocked cap tube or a malfuncting expansion valve. Finally check the condenser coils which is the radiator thing out where the compressor is located. If it clogged with dust and grease, it will not dissapate the heat from the freon and will intefere with the operation of the entire unit. Clogged condener coils are probably the number one cause of burned out compressors. Good luck.
Posted on Sep 17, 2010
Testimonial: "Unit still had R 12 in it and someone had charged it and had air in the lines I reclaimed the unit and retrofited it with R 206 and it is find now."
Where is the expansion valve located on a delfield 6151-s freezer?
Not sure on yours but most domestic refrigerator don't have TX v@lvs
Jun 23, 2015 | Delfield Freezers
Delfield Freezer Model # 6151.S Wiring Diagram
http://download.partstown.com/is-bin/intershop.static/WFS/Reedy-PartsTown-Site/-/en_US/manuals/6000XL%20SERIES_spm.pdf. Start here.
Sep 07, 2012 | Delfield Freezers
Service manual for delfield 6151 g
http://download.partstown.com/is-bin/intershop.static/WFS/Reedy-PartsTown-Site/-/en_US/manuals/6000XL%20SERIES_spm.pdf. Start with this one.
Jul 02, 2012 | Delfield 113.28 cu. ft. Commercial Freezer...
Is it possible for a delfield freezer 6151 XL-S to trip a breaker every 2-3 hours if the TXV valve was faulty letting liquid get to compressor. This unit has had controller and relay start assembly...
I would look to see if it is tripping during the defrost cycle. One of the heater elements my be faulty. Never heard of a bad TXV causing a breaker tripping, but I guess it's possible. I would adjust the superheat so that it is about 6 to 8 degrees just prior to unit reaching temp and shutting off. I'd start there.
Apr 01, 2011 | Delfield Freezer 6151XLSR Stainless steel
Delfield freezer 6151-S ,replaced door gaskets and they don`t seal
Take a hair dryer (or take off the gasket and throw them in the clothes dryer (yes I am for real I do this all day long)) then put them back on. or the hair dyer way is keep heating the gasket up and holding the door closed while you do it. they should start to seal as you are pressing them together.
Sep 23, 2009 | Delfield Freezer 6151XLSR Stainless steel
Looking for 6151-s manual please help!
This should cover your model-Good Luck
6151
Sep 03, 2009 | Delfield Freezers
Delfield freezer 6151-S keeps tripping GFCI
Try it in a normal plug. Freezers and refridgerators just pull too much to be used on a GFCI. The more a GFCI is used the eaiser it trips.
Aug 31, 2009 | Delfield Freezer 6151XLSR Stainless steel
Can I turn my Delfield freezer Mdl 6151-S into a cooler
It can be done but someone would have to do their homework. They have to know the BTU rating of the evap. Then match the compressor and expansion device to it for the intended temp range. In some cases, the compressor can be used in multiple temp ranges, so you could be lucky and just change the expansion device and possible the temp control, depending on which one you have. Let me know if I can be of any further help.
Jun 03, 2009 | Randell 47 cu. ft. / 1331 liter Commercial...
Digital control settings
I have the dlefield maual if you talking about the digital defrost/temp adj
Aug 03, 2008 | Delfield Freezer 6151XLSR Stainless steel
Delfield 113.28 cu. ft. Commercial Freezer Meridian MFRI3S Stainless Steel Logo
320 people viewed this question
Top Delfield Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
Tom Donaldson
Level 1 Expert
Are you a Delfield Freezer Expert? Answer questions, earn points and help others
