Question about GE GTS20ICNCC / GTS20ICNWW Top Freezer Refrigerator
Freezing fresh food
Frigidaire Refrigerator model FRS26HF6BQO
suddenly started to freeze food solid in fresh food compartment
  • Anonymous Mar 27, 2014
    had a bad board and dammper. Replaced both and now the fresh food freeezing some times
    Genius:
  • 3,422 Answers
HI,
The problem is with the damper door.Check that it is not cracked.If it is cracked then you will have to replace it with a new one.
Goodluck..
Posted on May 17, 2008
Drawer Freezer. Doesn't completely freeze food
Good Morning Stacey, thank you for your post!
I understand that your Frigidaire refrigerator is not freezing food properly. What temperature is your refrigerator set to? How much do you have packed into the freezer? Is this a new refrigerator? Could you also provide me with your model number? You can locate the serial (which lists your model number) on the inside wall of your fresh food side. Once I have that additional information I would be able to assist you further. -Matt
Jan 03, 2016 | Frigidaire Refrigerators
Fresh food compartment is too cold.
It's ether a bad thermister out thermostat or a damper stuck open I would guess.
Sep 03, 2012 | Frigidaire GLRS237ZA Side by Side...
The fresh food compartment on my PLHS267za fridge is freezing. Have tried turning the temp all the way down and it is still freezing. What could the problem be?
damper stuck open by the fresh food thermostat. the unit doesnt know that it is cold enough so the damper stays open letting cold air from the freezer to continue to travle over.
Oct 19, 2010 | Frigidaire PLHS267ZA Side by Side...
We have a ge side by side and the refrigerator is freesing stuff. the model number is GSS25X SNA BS
Is it all areas of the fresh food side that are freezing your items, or is it the drawer area?
There is a direct connection (on my GE side-by-side, at least) between the freezer compartment and the drawers in the fresh food compartment. The size of the connection is controlled with a wheel or a slider. This could contribute to freezing in that area of the fresh food compartment.
Otherwise, it could be the temp sensor(s) in the fresh food compartment. If the computer thinks the temp is too high in the fresh food compartment, it will continue to cool.
It could be a problem with the motorized door that connects the freezer compartment to the fresh food compartment, located at the top of the dividing wall between the compartment. That door should close when the temp in the fresh food compartment is cold enough. If that door mechanism has failed, is disconnected, or otherwise blocked in the open position, cold air from the freezer compartment will continue to circulate into the fresh food compartment.
Jul 29, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Food in fridge freezing solid
Sounds like you need to replace the THERMOSTAT , aj
May 05, 2009 | Frigidaire GLRS267ZA Side by Side...
Food and drinks freezing in my refrigerator. How do I adjust?
Inside your refrigerator is a control on left side of the panel. Try to adjust there and try to close the dampers near the lower drawer bins. If that don't work change the temp a little higher in the fresh food compartment. But closing the ducts should do the thing. Let me know, Thanks Sea Breeze
#27 below in pic try ajusting the air coming into fresh food compartment.
seabreezehvac@yahoo.com
http://servicepartstec.blogspot.com/
Apr 21, 2009 | Estate TS25AFXK Side by Side Refrigerator
Fridge keeps on freezing everything inside of it
This refrigerator only has one thermostat located in the fresh food compartment it is designed to activate the sealed system (cooling) until it reaches approximately 37 deg f in the fresh food compartment. The damper controls how fast the cold air can move from the freezer compartment to the fresh food compartment. Allowing you to control the temp in the freezer by controlling the flow of cold air to the thermostat.
You have one of two problems.
#1 your thermostat is no longer opening when it achieves set temp. fix = replace thermostat pn 61005798 $35
#2 your damper arm or assemblie has broken. Fix = Replace damper or broken arm and actuator.
damper assembly pn12001377 $44
damper actuator pn 61002000 $2
damper arm pn 61001999 $2
thermostat actuator arm damper arm
damper assembly both pics
Apr 06, 2009 | Refrigerators
Top mounted freezer on refrigerator not working
Move the refrigerator to a room that is at least 50 degrees F.
Temps on most refrigerators are regulated by the fresh foods temp. If your garage is let's say 35 degrees, the fresh foods temp will most likely never raise enough to turn the refrigerator on. With the refrigerator never running, the freezer compartment will warm to 35 degrees, resulting in everything melting. Even if garage is a bit warmer, say 45, the refrig will not run long enough for the freezer to maintain a low enough temperture. If the garage temp falls to below freezing, say 20 degrees, the food in the fresh foods compartment will freeze. (outdoor beverage dispensers have internal heaters to prevent product from freezing !) Please don't rate this if not a Fix-Ya for you, as anything else lowers my score.
Jan 22, 2009 | Frigidaire 5 cu. ft. / 142 liter Chest...
Fresh food side freezing
the air damper is stuck open or tempature control is bad. look thru the vents(use a mirror) on the left rear(top side) of the fresh food compartment (right hand door) to see if the air damper is open/closed. i am sure it will be open since your freezing food in the ref section. if it is open ,watching with your mirror turn ref (fresh food) control off. the air dmper should close, if not damper could be stuck(ice build up,piece of foam,ect) if you can determine damper door is free, then best thing to do is replace controlassy.(120.00 or so) good luck
Nov 06, 2008 | Frigidaire FRS3R5EMB Side by Side...
Freezing fine,food area warm
I have the same refrigerator and the SAME problem. The freezer unit didn't work at first (for about a week) and then it started freezing solid with not way to control the temp. When that happened, the refrigerated section stopped working and has not worked since (two months). Help!!
May 27, 2008 | Frigidaire FRT21H8 Top Freezer...
Open Questions:
See all GE GTS20ICNCC / GTS20ICNWW Top Freezer Questions
GE GTS20ICNCC / GTS20ICNWW Top Freezer Refrigerator Logo
212 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
