Question about HP Officejet Pro L7590 All-in-One InkJet Printer
I had paper eaten in my top feeder. There still may be some in there but I can't easily see it as I can if it's in the back. When I load paper now into the top feeder nothing feeds! Please help!! ALSO....Is there a way to continuously feed from the glass so your not getting a report by page and then having to feed again and again? Thanks! Eric
  • emalins Sep 17, 2010
    Thank you. What I meant is that my paper jammed as you feed it not from the glass but from the feeder above where you can put several pages in to be fed through. I need to clear it from on top,not by removing the back.
    As for the glass, some machines ask if you have more than one page to fax/scan. I have not seen that feature on my L7590. Does it exist?
    Thank you again for your time!
    Eric
  • HP Master
  • 4,924 Answers
I linked here a page where you will find all about the paper jam troubleshooting ..and , also I advice to reset and try to see if it will feed after it ...On this page there is explained step by step how to do it ..
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00618080&lc=en&dlc=en&cc=ph&lang=en&product=3643612
I'm not sure what you mean by feeding from the glass...but if it is capable it is explained on the manual for sure ..
I suspect that what you mean by top feeder..is infact the manual feeding ..so there is not designed to multiple feeding ..for to do that you have to use the paper drawer..
Posted on Sep 17, 2010
  • Catalin Turcu
    Catalin Turcu Sep 17, 2010
    for the paper jam ..there is only one procedure no matter what the feeding way is used...cause there is only one mechanism for rolling the pages...and if the feature for multiple pages is not displayed there isn't one ..or you have not installed the full software in the computer for to be available ..
    anyway if it is somehow disabled...the resetting will bring it back ..
SCX 4521F multi/f keeps reporting "Document Jam"
Hello there,
If the paper is lodged too far into the printer and can't be removed: Press the power button to turn the printer off.
Pull firmly on the paper to remove it. If you can't reach the paper because it is too far in, raise the front cover and remove the paper from the front of the printer.
Close the front cover.
Press the power button to turn the printer back on.
Resend your document to print.
Ensure that:
The paper is a recommended paper for Laser printers.
You do not force the paper down into the printer when you load it. For example, if you are loading letter or A4 size paper, the top edge of the paper should extend above the top of the sheet feeder.
The printer is on a flat, level surface.
The left paper guide is against the side of the paper.
You do not load too much paper in the sheet feeder. Depending on the thickness of your paper, the sheet feeder can hold up to 100 sheets of paper.
The left paper guide does not cause the paper to bend in the sheet feeder.
Your printer feeds regular paper as expected. If regular paper feeds without causing problems, load the envelopes vertically against the right side of the sheet feeder. Make sure the paper guide is against the side of the envelopes.
Envelopes or the appropriate specialty papers are selected in the printer driver.
You are using a paper or envelope size supported by your printer.
do not forget to rate this solution....good luck
thanks for using FixYa
Feb 12, 2009 | Samsung SCX 4521F All-In-One Laser Printer
Saying paper jam dcp-135c brother printer
 Hello there,If the paper is lodged too far into the printer and can't be removed: Press the power button to turn the printer off.
Ensure that:
Jan 30, 2009 | Samsung SCX 4521F All-In-One Laser Printer
Paper is feeding unevenly on black & white prints
  1. Press the power button to turn the printer off.
  2. Pull firmly on the paper to remove it. If you can't reach the paper because it is too far in, raise the front cover and remove the paper from the front of the printer.
  3. Close the front cover.
  4. Press the power button to turn the printer back on.
  5. Resend your document to print.
Ensure that:
  • The paper is a recommended paper for inkjet printers.
  • You do not force the paper down into the printer when you load it. For example, if you are loading letter or A4 size paper, the top edge of the paper should extend above the top of the sheet feeder.
  • The printer is on a flat, level surface.
  • The left paper guide is against the side of the paper.
  • You do not load too much paper in the sheet feeder. Depending on the thickness of your paper, the sheet feeder can hold up to 100 sheets of paper.
  • The left paper guide does not cause the paper to bend in the sheet feeder.
  • Your printer feeds regular paper as expected. If regular paper feeds without causing problems, load the envelopes vertically against the right side of the sheet feeder. Make sure the paper guide is against the side of the envelopes.
  • Envelopes or the appropriate specialty papers are selected in the printer driver.
  • You are using a paper or envelope size supported by your printer.
Important: Your application may not be designed to print envelopes. For help, consult the documentation that accompanied your application.
May 21, 2008 | Lexmark X4270 All-In-One InkJet Printer
Paper feed on Canon i 350n ink jet printer
Ensure that:
May 13, 2008 | Canon i350 InkJet Printer
Paper jam
I removed paper from jam, red light will not quit flashing, I turned
printer off and on again, but it will not print and red light will not
quit flashing, What can I do?
May 12, 2008 | Office Equipment & Supplies
Jammed paper
Ensure that:
Apr 28, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
I have a Lexmark X3550 printer There is a paper way down inside that cannot be reached Tried the automatic remove and it does nothing. What should I do?This machine is only a few months old.
Bending the bottom exit tray will allow it to be removed. Simply remove tray and wipe rollers right in front of the bar that the ink slides back and forth on. Most printers get a lttle dust on the rollers then they wont feed. Hope this Helps.Sincerely Brian @ Game-On Computers.
Apr 26, 2008 | Office Equipment & Supplies
False paper jam
Ensure that:
Apr 25, 2008 | Dell 922 All-In-One InkJet Printer
Paper jam
Ensure that:
Jan 04, 2008 | Lexmark X1240 All-In-One InkJet Printer
HP Officejet Pro L7590 All-in-One InkJet Printer Logo
32 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
