I have Sanyo SW800X2T washing machine its wash timer is not working \r\nI have been waitibg for this part to receive at chennai since last three months. Is this part so valued that even after passing three months it is not pmade avialabel to us.
SOURCE: Washing Machine is leaving lint on everything.
Clean the washing machine lint trap if your washer has one if not buy a washing machine lint trap at a place like home depot.
Posted on May 16, 2009
  • 4 Answers
SOURCE: Simpson washing machine not turning on
check outlet with multimeter for 120 volts .If voltage found check cord for 120 volts .If cord has 120 volts turn on timer jumper lid switch . did this help?
Posted on May 30, 2009
  • 111 Answers
SOURCE: Washing Machine has burnt rubber smell
your problem is probably the coupling that ataches the motor to the transmission , take the skirt of the washer off , take the motor off and you going to see the rubber coupling if is bad just change it , cheap part
Posted on Jun 18, 2009
jrwoodlock
  • 19 Answers
SOURCE: My Washing machine stains clothes;
Its the felt drum seal (clothes getting stuck in there and getting the greasy adhesive on them). I took a Q-tip and slid it between the felt seal and the metal, and the color and consistency of what came out was the same as the marks on the clothes.
Call a Whirlpool tech, they can replace
Posted on Aug 21, 2009
I had the same problem, and it turns out that it is NOT the seal. It is the liquid fabric softener. The fabric softener dispenser needs to be cleaned periodically or it gets a black waxy, goopy, build up. It is this same buildup that ends up staining your clothes with dark brown or black stains. Just remove the dispenser and wash it our very well and the problem will be gone.
Posted on Apr 12, 2010
I have sanyo sw800x2t my problem is the water continues draining even it is closed,so i can't put water and wash,is somebody can help me for this problem?
Washer fills with water then drains:
The critical question is. Is the water is just running down the drain but the pump isn't running. If it is being pumped out, and you can hear the pump running just the same as when it's emptying prior to spin then it could be aborting the wash because it is, or it thinks it's overheating. ( due to defective water temperature switch)
If the pump is failing to shut off then there is something wrong with the electronics. If your washer is a mechanical timer controlled device then you may have a sticking switch (which may explain if switching cycles does something for you). But if you have an electronic timer then you may be experiencing a board failure, where a cycle is being commanded when it is not intended to by design.
If water isn't being pumped out, but just draining away all the time, the washer will keep detecting there isn't enough water inside and top up with more.
Modern washing machines should be sophisticated enough to realize something's wrong and abort with an error, but if not, it may continue washing or rinsing for a short while before losing enough water to trigger more coming in again. It can get stuck on this cycle indefinitely and it's called siphoning.
Siphoning occurs when the end of the drain hose is lower than the level of the water inside the washing machine.
Try raising the hose and see what happens.
Also the drain hose should have some type of air gap where it fits into the stand pipe. It should not have an air tight fit.
Again Either it's siphoning down the drain due to an issue with the plumbing, it's overfilling, or also if it ( THE WATER) overheats then in some machines the software will employ a fill and drain tactic to cool down the water. The important thing is to work out which of these different faults is causing the problem by careful observation.
Other switch's to check would be the water inlet valve and the water pressure switch with a multi meter for continuity or OHMS.
And in some modern washers that come with THERMISTORS:
One symptom of a washing machine that thinks it's overheating and thus fills and drains at same time ( possibly because of a faulty thermistor) is if it's filling with cold water and pumping out at the same time. This is covered in this articleWashing machine fills and drains at same timealthough the same symptom can be caused by other faults.
By the way my advice is free cuz God is good!
Jun 04, 2015 | Washing Machines
Sanyo, washing machine, asw-ep70a
It probably needs a belt. It may have been slipping so much with the bigger loads that now it is shiny
Nov 29, 2013 | Washing Machines
Whirlpool washer will occasionally be filling with water and pumping water out, problem will last until i turn timer knob to next action, after turning timer to "sweet spot" washing machine will...
These timers are normally sealed units (crimped and pressed sheet metal) and replaced as a unit.
If you could open one up, you'd find
that the contacts causing the intermittent problem are burnt from arcing. All washing machine timers
will eventually get this problem with enough use. As an electrician, you'll recognize that all switches
(washing machine timers are a series of switches oriented around a slow (timer) motor) are rated
for a given number of make/break cycles. Washing machine timer contacts are no different.
If you could actually "shine up" the offending pair of burnt contacts, another pair would soon
show the same symptoms, since all the contacts in your timer have endured the same number of
make/break cycles.
Feb 21, 2011 | Washing Machines
My final spin cycle is not working on any wash
TIMER!!! Last cam in your timer has a loose set screw or is broken. Don't try to fix it, it won't last. Buy a timer.
Mar 09, 2010 | Washing Machines
I want to take the top of the washer off. It looks like it swings up, were are the latches?
In most of the washing machines the latches will be three in top and three in bottom will be present the upper will be quite upside to 1latch will be rotate timer 2latch will be center of panel. and 3 rd will be at left side of the panel last switch
Dec 24, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
I have a sanyo ASW 40AP WASHING MACHINE now nothing is wrong with it except for the timer that controls the cycle well the i want to know the name of the bolt like thing that holds and controls the timer...
If you are referring to the Spindle on the timer being loose ,this would suggest you may need a new timer quite an expensive repairif on the other hand its thewhole thing that is loose or the timer knob, both would be repaired quite cheaply...I wish you good luck
Oct 07, 2009 | Washing Machines
How long a complete washing cycle last. Mine lasts for
If you have a timer in your washing machine, you can adjust it to a lower setting, and still have a complete
a complete washing cycle.
Sep 24, 2009 | Washing Machines
Washing Machines Logo
71 people viewed this question
Top Washing Machines Experts
