Question about Zenith R56W36 56" Rear Projection Television
My Zenith tv has wild colors and double image. what do i do?
  • Zenith Master
  • 17,130 Answers
Possible that the lamps are out of alignment resulting in poor convergence of the image.
You might have tto use a test pattern to see if this can be corrected or if this is the fault if the convergence section.
Posted on Sep 17, 2010
IMAGE STAYS ON FOR AN LONG TIME
Sounds possibly like image retention. If you watch the same channels often any recurring text, logos, or graphics, especially white colored, can ghost on the screen.(playing the same videogame for a long period can also have the same effect) Watching other programs or channels will cause the ghosting to disappear.
To prevent image retention you need to activate the TVs anti image retention mode(Called ISM Method). On Zenith and LG (the manufacturer of Zenith T
s) plasma TVs open the TVs menu, select the Option section (picture of a briefcase with a wrench). Select ISM Method and change it to Orbiter, this is reccomended if you watch programs or channels (or play videogames) that have still images for long periods of time. It moves the image a little every couple minutes.
If watching others channels or programs doesn't make the image disappear, change the ISM Method to either Color Wash or White Wash (don't use White Wash frequently, it over excites the plasma gas and can shorten the life of your TV if overused) for a few minutes and then return to Orbiter.
Oct 23, 2013 | Zenith Z60PV220 60-inch Plasma TV
My zenith sentry tv has a double image on the words that come on screen. The people are clear but all wording has double images
Hello
Double images are technically called Ghosts, occures due to the setting and direction on the antena. You have to reorient your antena, in such a way that Ghosts disappeares from your screen. The reson for this fault is not with the TV, as it gets a direct transmission signal, and a reflected signal of the same, reflected from near or far objects, like tall buldings, hills and so on. The signals, the orginal and the reflected, will be processed by the TVs internal ciiruit, and the first will appear as strong picture, followed by the second, a weak picture, will be seemed as an image of the first one, just on the right side [view point] of your TV.
You just adjust the position and height of your antena, looking the picture, where there is minimum Ghost level is. No other repair should be done to your TV, as it is perfect, and you just give it only direct signal path. OK.
Nov 22, 2010 | ZenithZ2541S 25" TV
Blurry picture on left side double image right side is ok....
Ur convergence is dead,need convergence kit.
U know how to solder right?Tries these websites for convergence kit.Tv Repair World.com,Shopjimmy.com,Ebay.com or Partstore.com
Sep 25, 2009 | Zenith IQB50M90W 50" Rear Projection...
I have double image I am looking at array but not
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai2_bing.gif,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Aug 05, 2009 | Hitachi 50DX20B 50" Rear Projection...
Samsung HCN4727W Rear Projection TV, green screen, audio works
*Screen Looks 3-D
*Colors wont align
Jul 10, 2009 | Samsung HL-R4667W Rear Projection...
Hitachi Mo# 53uwx10ba double image
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
*Screen Looks 3-D
*Colors wont align
Sep 07, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Double images with red halo outlines
Sounds like your describing convergence ICs. They cost about 10.00 each and you will need to replace both of them. And possibly the resistors that power them total cost under 30 dollars if you do he soldering yourself. Hope this helps.
Feb 10, 2008 | Zenith B50M88W 50" Rear Projection...
Zenith R56W36 56" Rear Projection Television Logo
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
