Question about Bosch 4.2 cu. ft. / 119 liter Upright Freezer GSL14460
Motor not switching off - Bosch 4.2 cu. ft. / 119 liter Upright Freezer GSL14460
  • Bosch Master
  • 17,130 Answers
Possible that the thermostat is not working correctly to shut off when the temperature is reached.
you must try to set the temp down to the lowest to see if the motor cuts off. If cooling is sufficient then the thermostat must be replaced.
However if cooling is inadequate the gas or the compressor must be checked.
Posted on Sep 17, 2010
Kenmore upright freezer problem
Kenmore Freezer, lights on and loud buzzing sound. - Shop ...
www.shopyourway.com > KRISTI PETERSON > Questions
I have a Kenmore upright freezer model # 253.26052104 and at the bottom of the front there are two lights and an on/off rocker switch. At this time one light is ... When I attempt to turn it back on, it makes an extremely loud buzzing sound. What does that... The switch that you are describing is for the high temperature alarm.
Kenmore rocker switch Freezers Questions & Answers - Fixya
www.fixya.com > Forum > Tags > rocker switch > Freezers
Kenmore freezers rocker switch related questions and answers. ... Kenmore upright Freezer 20.3 cu.ft has 2 switches on the bottom of the freezer and was making a loud buzzing sound like an alarm and the ... How to turn off the doorajar beeping on aKenmore Freeze and what is causing the moisture buildup inside freezer.
GE 14.1 cu. ft. / 399 liter Upright Freezer FUM14DMRWH
Jan 01, 2016 | Kenmore Freezers
Necesito reparar el mecanismo rotativo de los shelves o compartimentos. Que numero de la parte o motor debo instalar?
Antes de gastar en partes nuevas, debes desarmar el aparato y inspeccionar. Le llega la corriente al motor? Funcionan los switches de limite (que detienen al motor en su punto), algun engrane, o fusible quemado?
Dec 31, 2014 | True G4SM-23-RGS Reach In Specialty...
Freezer contents thawed, freezer cuts on but only runs a few seconds and cuts back off
Compressors do not usually shut down. Either there is a power interruption to the motor caused by the power switch or thermostat or the motor has developed an internal short whereby it uses excessive power causing it to overdraw/overheat and have the clixon circuit shut it down.
Jan 20, 2014 | Frigidaire Freezers
Freezer wont turn on
Your freezer has a low pressure switch which determines if it is safe to run the motor. The switch may be bad or you have a freon leak. If you are going to pull the switch make sure you unplug the unit FIRST!
Feb 07, 2013 | Northland Freezers
Fan is not running in my True T49F Freezer
There is a switch above the door; check you have power from it when closed, then check the evaporator is cold enough as there is a thermistor that stops the fan until it is beginning to freeze. Lastly check the fan blade isn't stuck and the motor is ok.
Jul 02, 2012 | Freezers
Freezer temp keeps dropping despite putting on superfreeze switch. What might the problem be?
I own an Imperial freezer and it has a superfreeze switch. The schematic electrical diagram on my freezer shows that the superfreeze switch when activated, bypasses the temperature control thermostat and keeps operating the compressor motor non stop. Try switching the superfreeze to off after you reach your desired freezer temperature.
Aug 28, 2011 | Miele 4.2 cu. ft. / 119 liter Upright...
Freezer is warm, not freezing at all, fans run
If the fans your talking about are in the refrigeration section, then the unit is not in defrost. The interior fans shut off during the defrost cycle.
There is a condenser fan motor in the machine section by the compressor. If it fails, the problem you described can occur.
If that fan motor is still, and the compressor is cool to the touch, then no power is getting to the refrigeration section.
Could be a bad thermostat, or the unit has tripped off on the high pressure safety switch. The high pressure switch can be one of 2 styles. Auto reset, which means it will try to restart the compressor when the pressures become normal. The other has a lock out feature that requires it be reset manually. If it goes out on the high pressure switch, once reset, check the condenser fan motor to make sure it is running and/or excessive dirt in the condenser, which must be blown out.
Other causes can be a total loss of refrigerant, or a compressor that won't run.
Short of a broken wire all items listed except for a dirty condensor and reset of the high pressure switch, require a decent knowledge of electrical, Knowledge in the use of a VOM meter and amp-probe, as well as a set of refrigeration gauges.
Oct 30, 2009 | Turbo Air 49 cu. ft. / 1388 liter...
Fan in freezer not working
It runs when the compressor runs except when it's in the defrost cycle. If you have an electronic control instead of a defrost timer the control could be the problem since it runs the fans. You can test the evaporator fan. See how here> How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Sep 21, 2009 | Arctic Air 22 cu. ft. Commercial Freezer...
Motor goes on/off every few second.
You have problem with the motor compressor,it is trying to start, but cannot for one reason or another, could be siezed motor, sticking start relay.etc'
It is stopping and starting due to the motor overload device cutting in and out. it acts as a safety device.
This is usually associated with a serious malfunction..Plz rate my solution.
Thanks.
Dec 28, 2008 | Engel Freezer 22 Qt. Fridge/Freezer
Whirlpool sidexside m-gd25dq does not cool properly
Sounds like bad cold control. Replace it. I cannot see your repyl due to some tech issue w/ the site, so it may be a day or so before I can reply again. Please leave feedback for me if appropriate. Thanks
Nov 15, 2008 | Whirlpool 19.6 cu. ft. Upright Freezer...
Bosch 4.2 cu. ft. / 119 liter Upright Freezer GSL14460 Logo
76 people viewed this question
Top Bosch Freezers Experts
Charles T Nevin
Charles T Nevin
Victor Nwachukwu
Victor Nwachukwu
Are you a Bosch Freezer Expert? Answer questions, earn points and help others
