Question about Water Heaters
Ideal c80ff. doesn't work on heating,pump just runs continously.Works on hot water most of the time.Pump runs when there is no demand....all the time.Voltage to live and neutral on fan when boiler decides not to work.Any ideas?
3 Suggested Answers
  • 104 Answers
SOURCE: ideal c80ff
differential is set too close and water temp set too low.dirty coil can have same result -how old is unit?
Posted on Nov 02, 2008
  • 150 Answers
SOURCE: combi boiler problem
most have an overrun built in for a few minutes. if much longer have you got a room thermostat anywhere to turn down
If it never turns off check the switch which controls ON/TIMED/OFF and turn to timed or off. if it still continues on timed then it's the timer
Posted on May 03, 2009
Hot water runs but heating wont. Pump continously overunning.
What do you mean when you say that 'hot water runs but heating won't' ? Do you mean that water is coming out of the hot water faucet, but that it is cold? When you say pump continuously overrunning, what pump and what do you mean by overrunning? I would like to help you, but I'm not sure what you are asking. Also, is this a water heater, or a boiler?
May 26, 2016 | Water Water Heaters
How to use Central Heating only on an IDEAL W2000 CF50 boiler
you should have a programmer that will let you have the hot water and heating on or off . You could have a motor rised valve on the system which controls both . depends on what system you have . Fully pumped of just pumped on the heating side .
Jun 14, 2017 | Water Heaters
Tank full of hot water,faucets deliver only cold,water trickels into tank with rapid intermittend pump action
1) Copy following link:
http://waterheatertimer.org/Crossover.html
2) Add comment with clear description of water heater, fuel type, and pump?
Is this a pump problem or water heater problem?
Is this a water well pump?
Are you getting good stream of cold water at tap?
Which water heater do you have?
Is the heater new?
Or older heater that stopped working.
Dec 27, 2012 | Atwood 10 Gallon Gas/Electric Water Heater...
I have an ariston 20/24 mffi combi pressure rises when switched to central heating but pressure ok when asking for hot water ? expansion vessel ?
over heat limit stat on central heating circuit ? if hot water is ok and hot to temp when run for 5 minutes the expansion vessel is doing its job.remember hot water is the maximum demand for any boiler ,,heating is secondry?once you establish hot water at maximum rate then the only real problem is on you demand for heating??
Dec 10, 2012 | Water Heaters
On a back boiler central heating system my hot water works fine but cant get my central heating working i have changed the pump there are no motorised valves on the system i have checked the the expansion...
In most cases problems with the circulator pump boil down to two problems.
The most common is air in the lines causing an air lock.
The next problem is that the pump gets stuck and is not running even though itmay be hot and seem to be running. In this cause the pump can sometimes betaken apart, cleaned and it will work, but usually it needs to be replaced.
Here is a tip that I wrote that will explain circulator pump problems in moredetail.
Heating Circulating Water Pump Problems
heatman101
May 09, 2011 | Water Heaters
Where can I get the wiring diagram for the Laing Autocirc? I want to wire in a momentary switch so that when I am ready to get in the shower I hit the switch and the pump runs until the water is warm and...
If you have the same Autocirc product I have, then it cannot be taken apart. The timer seems to be connected and sealed together with the pump. If yours is different, answer back with the wires that you can see and we'll see if the timer can be by-passed.
http://waterheatertimer.org/Water-heater-recirculation-system.html
With the ordinary Grunfos-type pump that is not on a timer, you can add a switch and have the pump work on demand as you describe.
And they make a product that does the specific job you describe. It's called a Demand Pump. Link above shows two different types at page bottom.
I have not tested either Demand Pump shown. They operate on-demand ... when you activate the pump, the pump quickly brings water over from the hot water heater.
So the Demand Pump has a higher volume pump than the Autocirc or Grunfos.
I question a two things about the Demand Pump. 1) How will the increased pump pressure affect local pipes, especially supply tubes under a sink. 2) How HOT does the pump get? If pump gets hot, and it is located under bathroom sink next to paper goods, then that is a hazard. Some regional building codes don't allow ceiling light bulbs in closets because the bulbs get hot and start fires when people pack their closets full.
Oct 23, 2010 | Laing Thermotech Autocirc Undersink...
I have an ideal standard he30 boiler instaled about 6 weeks ago. the boiler keeps losing presure about half a bar every 2 days if i dont top it up it will trip the fuse on the fuse board acording to the...
All the combis I've come across merely fail to fire if the pressure is not up. not only do they not fire, nothing else works including the pump and in any event the pump should not overheat just on low pressure.
water loss - try turning off the valves on the flow & return pipes [3/4 inch ones] 1 valve per pipe . This will isolate the rest of the system - rads etc Note pressure over a time period. In this mode the hot water circuit will still work but do NOT use the heating circuit
1/2 bar over 2 days is not serious but it should be found
Once you have either mended the leak in the rest of the system or found there is not one, insist on a replacement boiler
In any event having looked at the reasons given for the fuse blowing, I would definitely get a replacement.
These problems should not happen on a new boiler
I list Worcester.-Ariston-GlowWorm-Ideal- and many others who would confirm this
Dec 24, 2009 | Water Heaters
Ideal c80ff
Oct 26, 2008 | Water Heaters
On-Demand Water Heater
An on-demand, or tankless, water heater is a system for heating water as it passes through the pipes, usually very near the point of use. Traditional tank water heaters bring the water to approximately 140 degrees Fahrenheit (60 C), in order to ensure the water supply lasts long after the heater turns off. Since this is obviously far too hot to be pumped out of a shower of faucet, cold water is added to the mix in the pipes. Coupled with the loss of thermal energy over time, the average tank heater has an efficiency of approximately 80%. On-demand water heaters have a number of advantages over their tank-using counterparts. While tanks often degrade over time and begin leaking, the apparatus used in an on-demand water heater is much less susceptible to the burdens of age, and will often outlive the house they're installed in. The amount of energy used is a fraction of that used in a tank water heater, due to increased efficiency and a much smaller window during which a heating source is in use. While tank hot water heaters can, and often do, run out of hot water after a number of showers, on-demand heaters provide a never-ending supply of hot water, ensuring that warm water is always available when needed. A tankless water heater can cost between $500 and $1500, and they most commonly use either electric or natural gas energy to heat the water. Most mid-sized households report an energy savings of approximately 25-45% for a gas or propane heater, and up to 50% with an electric heater, over using traditional tank heaters. Water is usually set to a maximum temperature of 120 degrees Fahrenheit (49 C), though many heaters allow for custom setting of the maximum temperature via remote control. Outflow rates range from 8-14 gallons (30-53 litres) per minute. Installation for most tankless water heaters is incredibly easy, involving simple plumbing. In the case of electric heaters, all that is required for a fuel source is to plug the heater into an outlet and begin heating your water. Some modern on-demand water heaters can incorporate a solar preheating system. This system uses a traditional solar heating system and tank to bring the water nearer to the desired temperature, saving substantial energy use in the final on-demand heating. A solar preheating system costs between $500 and $800.
Aug 27, 2008 | Stiebel Eltron CK20E Electric Tankless...
Water Heaters Logo
37 people viewed this question
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
