Question about Dell Latitude D600 Notebook
When i am installing os my hard disc formet corectly and copy all boot file but my laptop not boot from hard disc it autommeticaly again boot from cd and start copy again cd
    Brigadier General:
  • 10,406 Answers
After all the copying has completed, remove the CD and let the computer reboot from the "new" files on the 'C:' disk-drive.
Posted on Sep 17, 2010
When pressing F8 on a dell inspiron 1525 I can't get into setup for the advance boot options menu. I am trying to overcome a "NTLDR is missing" issue
HI,
If you're trying to boot from the DVD/CD(OS disc) try tapping on F12 to go to the boot menu and then choose your DVD/CD drive to boot from the OS Disc. From there, you can use the OS Disc to repair your computer. Here's the step by step instruction once you've booted from the OS disc:
1. Insert the Windows bootable CD into the computer. 2. When prompted to press any key to boot from the CD, press any key. 3. Once in the Windows setup menu press the "R" key to repair Windows. 4. Log into your Windows installation by pressing the "1" key and pressing enter. 5. You will then be prompted for your administrator password, enter that password. 6, Copy the below two files to the root directory of the primary hard disk. In the below example we are copying these files from the CD-ROM drive letter, which in this case is "e." This letter may be different on your computer.
copy e:\i386\ntldr c:\ copy e:\i386\ntdetect.com c:\ 7. Once both of these files have been successfully copied, remove the CD from the computer and reboot.
If this does not resolve the problem, you might need to reinstall windows.
Hope this helps!
Sep 11, 2011 | Dell Inspiron 1525 Notebook
Tip
Install Windows 7 or Windows Vista on a Pc Without DVD Media
For user who doesn’t want to waste a DVD disc to burn the ISO to physical media, and does not have WinPE (Windows PE) startup disc, here’s a workaround method to install Windows Vista and Windows 7 into physical computer’s hard disk drive or partition (volume) directly with ISO without writing or burning to disc. The without-disc installation method is useful especially during beta and RC period of new operating system in the making, where the new build and new versionis launching and publishing every now and then. This tutorial guide assumes that the new Windows 7 or Windows Vista will be installed and replaced the original existing operating system currently installed. The instructions can be modified slightly (mainly on hard disk partition used) to fit into need of readers who want to have a dual-boot, multi-boot, or simply just to upgrade install to new OS.
1. Install a virtual CD/DVD drive on existing Windows operating system.
2. Mount the Windows Vista or Windows 7 installation DVD ISO image using the virtual drive.
3. Copy all files inside the virtual CD/DVD drive mounted with the ISO into any folder on any partition or hard disk drive not going to be used to install the Windows OS. For example, copy into E:\Windows7.
4. Copy the bootmgr and boot folders nested inside the copied folder (i.e. \Windows7) to root directory of system boot drive, typically C:\.
Note: For Windows Vista, users may need to use this step: Copy the bootmgr folder from E:\Windows7 to C:\ root directory, copy E:\Windows7\boot\boot.sdi file to same folder in C:\boot folder, and then copy bootsect.exe from the E:\Windows7\boot\ folder to C:\ drive.
Note: boot folder in system boot drive is hidden system folder.
5. Create a new folder named sources under the C:\ root folder.
6. Copy the boot.win file inside \Windows7\sources folder to the source folder created in the system boot drive, normally C:\.
7. Open a command prompt as administrator.
8. Run the following command (change the C to your drive path letter if applicable):
C:\boot\bootsect.exe /nt60 C:
For Windows Vista users who copied bootsect.exe to C:\ root folder, use the following command instead:
C:\bootsect.exe /nt60 C:
A successful message is the command completes successfully.
9. Change the name or label of the boot system partition local disk to BDCP or any name you prefer that easier to remember and type (in DOS command promot, use label command).
10. Restart the computer.
11. After booting up, the system will start the corresponding Windows installation process. Select the applicable language to install, time and currency format (regional settings locale) and keyboard or input method in the installation wizard dialog.
12. On the next screen, user will be presented with option to Install Windows. DO NOT press on Install Windows button, instead, click on Repair My Computer link on the bottom left corner.
13. In the Windows Recovery Environment (WinRE) System Recovery Options dialog window, click on Command Prompt to open a DOS Prompt window.
14. Run the format command to format the primary hard disk or partition to clean state:
format c: /q
Note: /q switch, which perform quick format can be omitted to full format. And if existing hard disk partition is of FAT32 filesystem format, use format c: /q /fs:ntfs to convert the file system to NTFS while formatting. Before formatting begins, the command may prompt for hard disk drive or partition label name, if so, enter accordingly (i.e. BDCP).
15. After format completed, start the Windows Vista or Windows 7 installation process again by manually running the setup.exe located in the copied. Note that the setup.exe is not the one located on boot system drive which copied at later step, as the boot drive has been formatted. For example:
E:\Windows7\sources\setup.exe
16. Continue with installation procedures by following on-screen instructions as per normal practice.
on May 19, 2010 | Computers & Internet
My system doesn;t boot up and I don't have the CD to boot up my system. When I brought the powerbook G3 it didn't with the CD. Please where can I get it from? I am in Ghana now. Thanks Ishmael
If you have another Macintosh that is working correctly, you can copy the contents of that hard-drive, including the Operating System onto an external hard drive.
To do this, install Carbon Copy Cloner on the working machine and plug in an external hard-drive. Then run Carbon copy cloner and make the source the computer's hard drive most likely named "Macintosh HD". Then choose to have your external hard drive be the drive where all of the data is copied. Then run the program and let it copy all of the files.
Once this is done, remove the external drive from the computer and plug it into your G3. Turn on your G3 while holding the Option (alt) key and then double click on the hard-drive image that is named whatever your external hard-drive is named.
Once your system boots up from the external hard drive, run Carbon Copy Cloner again and repeat the process again except have the source be your external drive and have the internal drive in your G3 be the disk that has all the data copied to it. Once this is done, turn off your computer, remove the external drive, and then boot up your computer again.
You will have an exact clone of the computer that you copied the data from and will just simply need to adjust the account settings as such as you see fit.
The external drive process can be skipped if you have a firewire cable. Simply connect the firewire cable to both computers and when you turn on your G3, hold the "T" key. This will turn your G3 into an external hard drive and you just have to carbon copy the files straight to your computer's internal hard drive.
If you do not have access to another computer mac computer, then you will need to go to the Apple Store and see if the Genius Bar can install the default operating system that your computer came with.
If for some odd reason you have the contents of an Mac OS install disc copied onto a flash drive or external hard drive, you can boot from that and use it in place of a disc.
Apr 15, 2011 | Apple PowerBook G3 Mac Notebook
Unable to install OS, installation is reaching up to 92% and display is goes off, after some time display comes and shows text saying windows copying files on entire screen in bulk
Your OS installer CD is damage. Just get new installer CD. Because it has to many scatches and he cannot reach some files on it. I tested it before when reinstalling my computer that it ask for certain system file missing.
Jan 03, 2011 | Acer Aspire One PC Notebook
What does it mean when it says NTLDR is missing?
It's me that windows NT loder LDR is missing
if this file (NTLDR) is missing windows can not boot
so you have to make an upgrade or reinstall your operating system
vote please :)
Dec 26, 2010 | Acer Aspire One Netbook
I cant get my ibook g4 to run it turns on with blinking folder
Blinking ? mark folder means that your OS can't be found. Take out your RAM underneath the keyboard and re-insert and try again. Nothing? Install a different new RAM chip and try again. Nothing? Install your disc 1 install disc, power down, wait a few seconds, now press the power button to turn on, now press and hold the option button, until your disc 1 shows up, select it, and bring your pointer to the right arrow on the screen and press enter. Now your booting from the disc 1. Go to disc utility folder at the top of the screen and select your hard drive and then select repair disc permissions. Then shut down and reboot when finished. Nothing? Your hard drive is fu.k.d-Try re-installing the OS. Nothing? Your hard drive is really fu.k.d-You need a new hard drive. Installing a new hard drive in the iBook is a *****. You may want to pay someone to install a hard drive or you can just get a new laptop.
Mar 09, 2010 | Apple iBook G4 Mac Notebook
Can't boot OS because of file missing
You will need to reinstall the file from an OS installation disc. You may have to reinstall the entire OS. If you need to, you should be able to keep any documents and other data you have on the computer, so long as you are reinstalling the same OS. If you want to upgrade to a different one, however, I would recommend that you use another device to boot your computer (a cd, external hard drive, or flash drive with the same OS you have on you computer), and copy all the desired data from you computer onto another storage device before upgrading. It is complicated to just replace the file manually, and it still requires a resource with the file on it (such as the installation disc), so your best would be to just reinstall the OS, or changing the OS.
Mar 02, 2010 | IBM ThinkPad R30 2656 Notebook
I have a mac book pro that has xp as the only os. I tried to reboot xp again and it wont install fully. My question is how do I remove xp a reinstall os x?
  1. Insert OS X disc
  2. shut down computer
  3. hold down the "c" key
  4. power on the computer
  5. wait for the computer to boot from the disc
  6. click install
  7. go to the top and choose Utilities
  8. open Disk Utilities
  9. ERASE the hard drive, choose Mac OS Journaled as file system.
  10. Go back to the install menu
  11. follow the prompts
  12. that's it! :)
Nov 20, 2009 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Hello, I'm trying to update the bios on a Gateway solo 1450 laptop.Ive copied the files to a floppy disc but the computer won't boot with the disc in the drive. The message insists I remove any discs from...
you need to make a boot disk then copy the bios files onto the disk if you can not make a boot disk you can go to bootdisk.com and there you can find the correct boot disk for your OS.
Oct 30, 2009 | Computers & Internet
Windows xp pro will not boot with new hard drive
Its hard to tell just like this without having the computer in hand to check and test the jumpers and connection and all, but quick like this i think it might be a trojan virus that corrupted the boot sectors of the old hard drive, and when you copied the stuff from the old to the new, the virus followed and infected the boot sectors of the new one too. Try to reformat completely using the original windows install disk, and not the system restore/reinstall disk and reinstall windows after the format with the original windows disk again. If I was right, it should boot up OK with a fresh format and reinstall with the real windows CD, then install a virus scan and a spyware scan and scan and clean the old drive completely 2 or 3 times to be sure theres nothing bad left on it, then try to copy the whole disc, but skip the Windows repertory, the Program Files one too and the Documents and settings one also, cause those 3 are the ones most prone to corrupting a fresh install even if there is not any viruses in them. If it does not boot up OK after formating and reinstalling Windows though and says it's unbootable, then either there is a config error in the BIOS of the laptop, or the IDE controller that drives the disk is defective. If it's the BIOS settings, it's gonna be easy enough just changing the settings and won't cost you too much, and if its the IDE controller... then that's another story cause it's integrated in the motherboard like any other computer, so basically another computer will cost less than a new motherboard for a laptop. So if that is the case and the IDE controller is shot, you can still try to use an external USB drive to run the computer but not all computers support booting from the USB though, so before buying a brand new external drive, check the BIOS first to see if it does support USB booting.
Jul 08, 2009 | Compaq Evo N610C Notebook
Dell Latitude D600 Notebook Logo
21 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
