Question about Samsung RB2155SH Bottom Freezer Refrigerator
My refrigeraton is not getting as cold as it should,bot the freezer is.Refrig temp 64 degrees.
  • Samsung Master
  • 43,501 Answers
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Sep 18, 2010
Fridge and freezer at 50 degrees with settings on max cold. I can hear compressor cycling and all power is on. Suggestions?
Your Refrig/freezer should be set as follows:
Refrigerators: 36 to 40 degrees. Ideal temp is 37 Fahrenheit. Note: A temp above 42 degrees promotes bacteria.
Freezer: temp should be -5 to 6 degrees Fahrenheit. Ideal temp is 0 degrees.
Then check the door seals around the edges to see if any splits, tears or cracks have messed up the seal. This will cause your compressor to constantly run as it's trying to cool off the warm house is being sucked into the freezer (or Refrig). A sure sign the door seals are damaged is lots of ice in the freezer door area or water pooling in the bottom area of the refrigerator.
Wait about 4 hrs after you readjusted the Refrigerator/Freezer settings so everything settles down. If you still have problems then the coolant may need to be serviced (topped off) or the motor serviced/checked.
Don't procrastinate because a water heater and Refrig/freezer are the 2 largest energy users in your home- they run 24 hrs a day.
Hope this helps...
Nov 23, 2012 | Whirlpool 25.6 cu. ft. Side-by-Side...
No Temperature in Refrig
It indicates that there is problem with your thermostat .
How old is your refrigerator ?
Are you facing this problem frequently ?
SAM ANDERSON
Sep 30, 2008 | Amana ABB1924DEB / ABB1924DEW / ABB1924DEQ...
Kenmore Refrig Model 596.50699000, not getting cold as should. Frost forming on top row of coils only?????
Clean the condenser. Probably below refrig. Reset all settings to mid point and check to see if you have a restricted drain tube.
Jun 17, 2012 | Kenmore Side by Side Refrigerator
Problem getting into diagnostic mode
refrigerators are not supposed to be set below about 40 degrees . foodistobe kept cold not frozen there
Apr 27, 2012 | GE Refrigerators
Frigidaire refrigerator with a broken freezer
He is correct. The temp in the refrig controls how often and for how long the refrig runs. Lets say the temp in your garage is 34 degrees, and you have your refrig set to 36 degrees: The refrig will never run, the fresh foods section will cool to 34, and the freezer will warm to 34. Even if the temp is 45 in the garage and you set the fresh foods to be 33, the refrig will not need to run long enough and often enough to keep the freezer temp cold enough. You will most likely need to have the ambient room temp at least 55 degrees to get satisfactory refrigerator performance. Insulating the refrig will not help. (by the way, outdoor beverage vending machines use an internal heater in cold weather to prevent liquid beverages inside from freezing,..... so using that info, you could put a low wattage heater in your refrig to make your refrig run enough to make the freezer section work. The %&#* with that, just move it into the house!)
Feb 06, 2010 | Frigidaire FRT17B3A Top Freezer...
Frigidaire top-mount refig. freezer won't get cold ,temp.stays around 26 degrees, refrig. don't keep milk cold enough
check that the evaporator fan motor ,located in freezer is working.it circulates the cold air.also check that the coils behind freezer back panel are not iced up,this would indicate a lack of defroting due to,timer,heating element,or bi-metal.lastly when the refrig is running those coils should get frost over them all,if not you may be low on refigerant
Jan 20, 2010 | Frigidaire FRT17G5CSB Top Freezer...
Can this refrigerator be used in an unheated garage?
Yes, You can use most any refrigerator in an unheated area. Just be aware that if it is in a below freezing area for a long period of time that the cold may penetrate enough to get the refrigerator temperatures below freezing also.
Nov 18, 2009 | Refrigerators
GE PROFILE REFRIGERATOR-PSC25MSTA NOT WORKING
check to see if the fan by the compressor is working when the compressor is running if not you have the problem control board .....replace board
Jun 30, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
My whirlpool refrig wont cool down the freezer.
Reach into your freezer and feel the back wall. If it is VERY cold then likely your freezer coils are frozen over which prevents the unit from cooling properly. There is also a Defrost thermostat that helps control freezer temp that you'll need to have checked. This is a last resort but if it's a newer frig, the computer control board would be the culprit if the others are OK.
Nov 29, 2008 | Whirlpool Refrigerators
Samsung RB2155SH Bottom Freezer Refrigerator Logo
113 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
