Question about Kidde 1275 Hardwire Smoke Alarm with Hush Feature and Battery Backup, Contr
How do I stop the three pulse alarm pattern, I have checked my house and their is no danger.
    Scholar:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 93 Answers
You should check all the units when this occurs (this is an actual alarm sound) to see if one of them is different than the rest, either by flashing an led, turning on a red led, etc. The one that is different is the one with the problem; replace it. If your units are more than 10 years old you need to replace all of them by code (NFPA 72), just so you know. Good luck!
Posted on Nov 19, 2014
Smoke not going up chimney
damper closed in chimney or blocked chimney
Jan 04, 2017 | Cars & Trucks
2008 electra glide battery draw, test light pulses, now bike wont crank over
The pulsing could be the alarm module. When bike is turned of, you will get small draw for a minute or so and then it should go very low, below a miliamp or so. This is the alarm module setting itself. Check for this. Is battery gone flat while checks were being made? Make sure ignition switch is on when disconnecting battery if alarm (Stock HD) is fitted. If not, alarm module gets confused and can cause problems. The corrct procedure for disconnecting a battery from an alarm fitted HS is - alarm off, ignition switch on, pull main fuse (Maxi Fuse), disconnect battery. To fit, ignition stitch off, connect battery then install main fuse.
Nov 01, 2013 | Harley Davidson FLHTCUI Electra Glide...
We just bought a Mini Plus B31 coffeemaker and the cord will not plug into a standard three prong outlet. Other appliance cords do plug into the same outlets.
if you have a four pin plug, check that it is not three phase for heavy electrical use. ask your electrical supplier if your house has three phase, if your house had electric storage heating there is a chance it had three phase to balance the electrical supply to the property this can be dangerous so check please (some old boilers were two or three phase years ago)
Jan 18, 2012 | Dryers
Code 266 and 263, alarm sounding
This is urgent to check immediately - From what I can tell in the manual you are having high levels of CO detected. This is the parts per million reading in your home. See page 6-3 in manual - this the link - -
http://www.detectorsandalarms.com/images/pdf/Manual_KN-COEG-3_900-0113en.pdf
On page 4-2 it says:
If the alarm sounds for carbon monoxide:
1) Operate test/reset button;
2) Call your emergency services ( fire dept. or 911);
3) Immediately move to fresh air - outdoors or by an open
door/window. Do a head count to check that all persons are accounted for. Do not reenter the premises nor
move away from the open door/window until the emergency services responders have arrived, the premises
have been aired out, and your CO and Gas alarm remains in its normal condition.
4) After following steps 1-3, if your alarm reactivates within a 24 hour period, repeat steps 1-3 and call a qualified
technician to investigate for sources of CO from fuel burning equipment and appliances, and inspect for
proper operation of this equipment. If
problems are identified during this inspection
have the equipment serviced immediately.
Note any combustion equipment not inspected by the technician and consult the manufacturer's instructions,
or contact the manufacturer's directly, for more information about CO safety and this equipment. Make sure
that motor vehicles are not, and have not been, operating in an attached garage or adjacent to the residence.
! WARNING:
Actuation of your CO and Gas alarm indicates the presence of
Carbon Monoxide (CO) or explosive Gas which can KILL YOU.
PHONE NUMBER
PHONE NUMBER
When the CO and Gas alarm senses a dangerous level of CO, the unit will emit a loud alarm pattern and display the concentration
of CO in parts per million (PPM). The alarm pattern is 4 short beeps - followed by 5 seconds of silence - followed by 4 short
beeps repeating. (Note: When the unit is disconnected from the 120V power supply and is on battery backup, the alarm pattern will
continue for the first 4 minutes after detecting CO and then the cycle will repeat every one minute). Know how to respond to a CO
or Gas emergency. Periodically review this user's guide and discuss with all members of your family.
4-
Oct 03, 2010 | Kidde Nighthawk Combo Gas/co Detector
Kidde pe 120 photoelectric sensor smoke alarm emits 3 "beeps" with a pause and then repeats until the 9vdc battery is removed. The house is not on fire and the 120vac power is connected. What might be the...
The 3 beeps, known as temporal pulse, is indicative of an alarm condition. If it stops without a battery, then the unit either does not have power or is otherwise defective.
Jun 03, 2010 | Kidde PE120 Hardwire with Battery Backup...
2000 malibu starts & then shuts off
are your injectors being fired by the computer.remove one of the injector connectors and using a low impedance test light or a small dash light bulb check for pulse or blinking light while cranking.
Feb 21, 2010 | 2000 Chevrolet Malibu
My first alert smoke detector went off at midnight last night. It is doing the three beeps, pausing and then another three beeps. This happened for about 3 minutes, stopped and then started again...
Change brand new battery,every three months.Take some rubbing achahol clean the test button metal contact inside the detector.Well works correctly after these steps.
Dec 15, 2009 | First Alert SA302 Dual System Smoke...
Printer error
If all the three lights are on, then the issue is with the board (formatter board to be precise). Press the green button to check if there is a difference in the light pattern, the first light pattern is called primary light and after pressing the green button, the format changes to secondary light pattern, please find below the link to check the different light pattern for primary and secondary light pattern.
HP LaserJet 1160 and 1320 Series Printers - Printer Light Patterns (Error Messages) http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&objectID=c00230632&prodTypeId=18972&prodSeriesId=410622
Rgds,
Nikhil
May 16, 2009 | HP LaserJet 1320n Printer
Warning Lights on dash: ABS, BRAKE,STOP,CHECK MANUAL
your abs unit is failing and needs replaced ...the procedure for testing is to backprobe green wire in abs connector and watch voltage wave pattern on a scope ....it will show voltage does not go from 0 to 12 but only 4 to 12 volts that verifies problem is abs controller.
Mar 20, 2009 | 1991 Volkswagen Passat
2000 F 250 WILL NOT START CRANKS OVER ONLY.
you should have the pcm scanned for dtc's... probably a bad crank or cam sensor
Oct 14, 2008 | 2000 Ford F250 Super Duty Crew Cabs
Kidde 1275 Hardwire Smoke Alarm with Hush Feature and Battery Backup, Contr Logo
233 people viewed this question
Top Kidde Home Experts
Tre Elkins
 Mikey
Mikey
Are you a Kidde Home Expert? Answer questions, earn points and help others
