Question about Panasonic NN-C980 Convection/Microwave Oven
Model NN-C980B/NN-C980W: when new,the turn table only work when door is closed; past month: turn table operates even when door is open, and changes direction when light force applied to the plate; yersterday: after entering proper info , turn table stopped turning and microwave disengage after 3 seconds. control panel is working. ty
MicrowaveSvc
  • 9047 Answers
SOURCE: MICROWAVE TURNS ON WHEN DOOR IS OPENED.
This is usually caused by either a bad door switch, a loose door switch mount, or a problem on the control panel.
Even though a door switch clicks, it may still be bad inside.
Door switches are most often damaged by opening the door while it's cooking (instead of pressing Stop / Clear first) or food
/ grease debris in the switch.
If you or a friend decide to look into it, we have critical information on safety, disassembly and door switches at our site, linked here on Fixya: http://tinyurl.com/yzjozk
Posted on Nov 05, 2007
MicrowaveSvc
  • 9047 Answers
SOURCE: operates for 3 seconds on microwave then stops
If the digital programmer circuit / controller does not get a feedback signal from the inverter for a period of 3 seconds, the controller will stop the cook cycle.
It could possibly be as simple as a loose connection in that area. The repair shop your friend used may not have been Panasonic-authorized.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
I would recommend that you contact your nearest Panasonic-authorized servicer.
Posted on Sep 16, 2008
rhozel2010
  • 269 Answers
SOURCE: NN-C980W Microwave start and stop after 2 seconds.
H!, its either you have a defective magnetron, hv transformer or a leaky capacitor.
Posted on Sep 15, 2009
joust
  • 7 Answers
SOURCE: Panasonic NN-C980B stopped working. Blown fuse.
Sometimes when the mag shorts it takes out the inverter. I would measure the mag leads to ground and they should be open or 20M or so. If you have both a mag and inverter bad it's probably time for a new oven.
Posted on Jun 02, 2010
SOURCE: Panasonic NN-T994SF Microwave Oven quits after 15 seconds
my microwave shuts off after a few seconds. is there a fuse that needs replacing?
Posted on Nov 24, 2010
Microwave Inverter NN-ST651BB 1200W Works fine but the turn table still turn when I open the door.
Does the turn table ever stop? If not you need to either replace the oven or have it repaired, it is likely cheaper to just replace it.
Dec 06, 2016 | Microwave Ovens
Why does Panasonic nn-sn651 usually work; but sometimes, turntable won't start ?
This is an inverter model so there is no diode or hv capacitor.
You must adt. the door latch switch assembly to make sure that the door hooks make contact with the switches. Common problem is that the assembly is bent and must be perpendicular to the door.If it is bent the switch will not make contact with the door hooks.
Place a dab of lithium grease on the tip of the door hooks to ease closing the door. This is the cause of the bent switch assembly!
Aug 31, 2014 | Panasonic 1.2 Cu. Ft. Mid-Size Microwave -...
My nn-s963bf starts operating when door is opened
The electronics have lost their marbles. When a nuker door is opened the safety switch connected to the door is designed to turn the unit off and not on. You just better work fast when you put stuff in or take it out!!!!!!!
Nov 24, 2013 | Panasonic NN-S963BF Microwave Oven
Apr 19, 2010 | Panasonic NN-C980 Convection/Microwave...
Sep 15, 2009 | Microwave Ovens
Panasonic NN-S567BAS Receiving power, No Waves
I would still suspect the top door switch. You would need to operate the switch to see if it clicks both ways and ultimately a test with a meter is required. If you don't have a meter, you can connect wires to a battery and a flashlight bulb, etc., and use that as a continuity tester. On the door switch, COM is common, NO is normally open, and NC (if present) is normally closed. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info (as well as a text file which helps in diagnosing and repairing door switch problems) at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find thew whole service manual (in sections) and order parts by entering your model number (without the dash) here: http://www3.sears.com If it's not the door switch, I would suspect the control circuit board (the one behind tghe keypad) and we repair these nationwide for only $39.95.
May 31, 2007 | Panasonic NN-S431WL 1000 Watts Microwave...
Panasonic NN-C980 Convection/Microwave Oven Logo
112 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Jerry Greenberg
Jerry Greenberg
SHARCNET-USA
SHARCNET-USA
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
