Question about Hitachi 53UDX10B 53" Rear Projection Television
Power won't stay on MdL 46EX3B/4K
I hope this flies, this site won't let me post the accurate model # 46 EX3B/4K. Power comes on for about 2 seconds and clicks off. It use to do this intermittingly and would play fine, now it won't power up at all.
  • 43 Answers
Check the curcuit board where the power supply is sometimes these sets get so hot the solder melts causing short curcuits,be very carefull as tvs can hold high voltage for many years and should be discharged first,there may be signs or arcing near power supply hope this helps...
Posted on Jun 22, 2008
Philips 46PFL5706/F7 46 LCD TV. When you turn it on you have power. The Philips logo appears for a second then goes away. Screen is black after that.
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement.
Sep 30, 2015 | Philips 46PFL5706 - 46" LCD TV -...
The TV has power but there is no sound or picture. What could this be?
Check and replace the damaged component/s at its main board. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
Oct 03, 2014 | Sanyo DP46849 46 in. HDTV
RCA 46LA45RQ tv turns on with sound and after 1 second the picture goes out. The blue power light stays on and the audio, but no picture.
Back-light inverter board fault. Replace it. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magzine" will make surf easy Pull up older posts. Surf the site with patience.
Apr 17, 2014 | RCA 46 46LA45RQ LCD TV
Hitachi 46ex3b/4k turns on,sound, no picture black screen!
First check for a faulty capacitor on the power supply board as it sounds like that could be the first place to start. Before you touch any capacitors PLEASE find articles on the internet concerning discharging them as one stray discharge incorrectly could not only destry your tv but hurt you or even KILL!!! Ignore any articles that tell you to use a screwdriver. Good luck.
Oct 01, 2008 | Hitachi 46GX01B 46" Rear Projection...
Power keeps surging and won't stay on
I will need the model number of your set in order to make any suggestions as to what possibly could be causeing the problem
May 17, 2008 | Hitachi Televison & Video
Power light keeps flashing on and off
What make and moel set do you have? Most sets hav a daignosis code built into the flashing power light.
Feb 03, 2008 | Hitachi 46F500 46" Rear Projection...
Hitachi 46 inch projector tv
Lenticular and/or fresnel screen in backwards!
Oct 09, 2007 | Televison & Video
Power problem rca 32v434t
RCA 32V434T likely has a bad flyback--#271996. RCA 32F531T flyback no longer available,#262343 Fix one,dispose of other.
Sep 26, 2007 | RCA 32F531T 32" TV
Projection tv
Yes if still comes on, then loose connection on board probably around power supply. Resolder loose connections, make sure all plugs are tight.
Sep 02, 2007 | Hitachi 46BX01B 46" Rear Projection...
Chirping noise and flashing front power light.
Theres a short somewhere in the set. Most likly the HOT is shorted or the vertical IC has caused this in the past. In one case I had shorted convergence IC cause this symptom.. This set is solid state and there are no user serviceable parts inside so please call a trained tech to assist you with this problem Good Luck
Aug 17, 2006 | Hitachi FDX Series 43FDX10B 43" Rear...
Hitachi 53UDX10B 53" Rear Projection Television Logo
54 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
