Question about Uniden Phone
Uniden power max 2.4 ghz
When I try to enter new phone numbers in, the message "memory full" comes up even though there is only 14 names & numbers entered. I press "phonebook" and the message comes up "phonebook - 14 and then second line is search, etc, and 3rd line is store" - I hit select and the message is "memory full" I thought I had room for 100 name/numbers. What gives? I went in and checked the names listed and there is indeed 14 names and numbers. How do I check and/or erase memory to find the other 86 names? Looking forward to your reply and thanking you in advance for your help.
  • Anonymous Dec 27, 2008
    I am having the same problem, only that I haven't stored any numbers in the address book yet.
I had the same problem but figured it out. For some dumb reason, Caller ID numbers count against your total phonebook memory. So if you just delete all your Caller ID numbers (press the "Caller ID" button and then the "delete" button) then you'll be able to store new numbers in your phonebook.
If I could get my hands on the Uniden engineer that is responsible for this, I'd smack him! :)
Posted on May 06, 2009
Tip
MOTOROLA TIPS
Motorola Secret Codes
IMEI number:
*#06#
Code to lock keys. Press together *7
Note: [] (pause) means the * key held in until box appears.
Select phone line - (use this to write things below the provider name):
[] [] [] 0 0 8 [] 1 []
Add phonebook to main menu:
[] [] [] 1 0 5 [] 1 []
Add messages to main menu:
[] [] [] 1 0 7 [] 1 []
Copy SIM memory (phonebook menu):
[] [] [] 1 0 8 [] 1 []
Eng Field options (main menu):
[] [] [] 1 1 3 [] 1 []
Slow (Frequency of search menu):
[] [] [] 1 0 1 [] 1 []
Medium (Frequency of search menu):
[] [] [] 1 0 2 [] 1 []
Fast (Frequency of search menu):
[] [] [] 1 0 3 [] 1 []
Enable EFR:
[] [] [] 1 1 9 [] 1 []
Function :
[] [] [] # # # [] 1 []
Change pin:
[] [] [] 0 0 4 [] 1 []
Unblocking using the "puk" number:
[] [] [] 0 0 5 [] 1 []
There are lots of similar codes exist. If you change the last number to 0 you can deactive that code. The 3 digit number at the middle are from 0 to 999. I put the most interesting codes. (EFR):Enhanced Full Rate Codec.
You can change GSM frequencies to 900/1800 by entering the enginnering model. Following the below steps:
enter menu and press 048263* quickly, then you will enter the secret engineering menu
under "Opcode"
input 10*0*3 for GSM 900
10*0*4 for GSM 1800
10*0*5 for GSM 1900
10*0*6 for dual band GSM 900/1800
10*0*7 for dual band GSM 850/1900
To add extra message space 4 your Motorola C350 C450 C550 or C650, press menu button, press 048263* quickly, then on the popup menu enter 47 press ok.press 50 and ok.press 1 ok.press 64 ok.press 1 ok.press 186 and ok.You will receive an extra 50 msgs memory space.Switch phone off and back on.(not tested)
Important!
Try these codes at your own risk! We don't accept any complaints.
Some of these codes may not work
on Sep 27, 2010 | Cell Phones
How do I delete messages on a Uniden Power Max 5.8 GHz
Since you didn't specify the model of your Uniden PowerMax 5.8GHz system I can only suggest you select it from the list beginning here to download a copy of the manual.
Dec 25, 2012 | Uniden 5.8GHz Cordless Phone
I have lost the instruction booklet booklet for my cordless power max 2.4 and would like to know how to listen to the messages remotely.
Select the model of your Uniden phone from the list beginning at
http://www.uniden.com/scat/cordlessphones_mnl
Sep 21, 2011 | Uniden 2.4 GHz Cordless Phone System
How do I call from away on vacation to see if I have any messages...I don't have the manuel ( power max 5.8 GHz)
call your home phone number. During the recorded greeting or series of beeps, press # and immediatly enter your security code (you can have 3 goes at doing this). The system should answer with the time and number of messages and help prompt - then starts beeping intermittently to let you know it is waiting for a command. Enter the command selected.
Mar 30, 2010 | Uniden 5.8GHz Dual Cordless Phone
I have entered a name in the phonebook and connected it to a tune so when that person rings the tune should play but it doesnt even though its all turned on and the tone has been confirmed whats wrong
When you entered the person into the phonebook on the phone, did you include the area code? It's wierd because it won't register who is calling if the phone number in the phonebook does not match exactly how it is coming in on the caller id. Try this, if it doesn't help let me know.
Nov 04, 2009 | Lands Phones
Forgot how to add new phone numbers and names to my phone
Creating Phonebook Entries To store names and numbers in your Phonebook, please follow these steps: When the phone is in standby mode, press [phonebook icon] (on the left side of the four-way key). To create a new phonebook entry, press the NEW soft key. Edit Name appears. Enter the name for this entry (Edit Name). Use the keypad to enter a name for this entry; the name can contain up to 1 6 characters. (See page 1 1 for instructions on entering text.) If you do not want to enter a name for this entry, your phone will store this entry as No Name. Press the OK soft key when you are finished. Enter the number for this entry (Edit Number 1). Once you have stored a name, EDIT NUMBER1 appears next. Use the number keypad, [right] or [left] on the four-way function key, or the DELETE soft key to enter the phone number 1 ; the phone number can contain up to 32 digits. If you need the phone to pause between digits when it’s dialing (for example, to enter an extension or an access code), press [redial/pause] to insert a two-second pause. You will see a P in the display. You can also use more than one pause together if two seconds is not long enough. Each pause counts as one digit. Press the OK soft key when you are finished. EDIT NUMBER 2 appears next. Use the same procedure when entering the phone number 1 to enter the phone number 2. Press the OK soft key when you are finished. Assign a personal ring tone for this entry (Personal Ring). You can attach a personalized ring tone to each phonebook entry; the phone will use this ring tone when this person calls. Move the cursor to highlight one of the 20 different ring tone options. As you highlight each ring tone, you will hear a sample of that tone. When you hear the ring tone you want to use, press the OK soft key. If you do not want to use a personal ring tone for this phonebook entry, select the NO SELECTION option, and the phone will use your standard ring tone setting. Assign this entry to a Speed Dial number (Speed Dial). Your phone has 1 0 speed dial numbers, 0 to 9. Move the cursor to select the speed dial number you want to assign to this phonebook entry, and press the OK soft key. Select NO SELECTION if you do not want to assign this entry to a speed dial number. Press the OK soft key. You will hear a tone confirming that the new phonebook entry has been stored, and DONE! appears in the display. Note: When the shared memory is full, the oldest Caller ID message is overwritten.
Jul 19, 2009 | Uniden 5.8GHz Dual Cordless Phone
How do I save telephone numbers to a uniden powermax 5.8 ghz cordless telephone
Phonebook (Storing Phone Numbers, Names, Distinctive
Rings and Speed Dial)
You can store names and numbers in your phone’s phonebook, search for names
alphabetically, and dial phonebook entries with just a few key presses. You can
store up to 100 numbers in the base and up to 100 additional numbers in each
registered handset.
The phone uses the same memory to store phonebook entries and Caller ID
messages. If the shared memory is already full, the phone will not store any more
phonebook entries. You will have to delete some of the Caller ID messages before
you can store a new phonebook entry.
1) When the phone is in standby mode, press phonebook.
2) Press the STORE soft key, S t o r e / E d i t N a m e appears.
3) Enter the name (up to 16 characters) by using the
number keypad (see the "Steps for Entering Names and
Special Characters" on page 44).
If a name is not required, go to step 4. <No Name> will
be used as the name.
4) Press the OK soft key to store the name;
S t o r e / E d i t N o . appears.
5) Use the number keypad, */tone/<, or #/> to enter the
phone number (up to 20 digits).
If you make an error, use the DELETE soft key to erase
the incorrect digits. When you are finished, press the
OK soft key to store the number.
6) If you store the phonebook entry from the handset,
D i s t i n c t i v e R i n g appears. Press volume up/down to
move the pointer to one of the Distinctive Ring options
and then press the OK soft key.
7) S p e e d D i a l appears. Press volume up/down to move the
pointer to select the Speed Dial location (10 locations:
SPD1-SPD0).
8) Press the OK soft key. You will hear a confirmation tone, and D o n e ! appears in the
display. EASY DOES IT! :)
Jul 08, 2009 | Uniden TRU9466 Cordless Phone
Can't enter phonebook numbers - Says memory full
Clear out your caller ID, These phones use a shared memory, once the caller ID is cleared, you should be able to store names/numbers in the phonebook.
Feb 17, 2009 | Uniden TRU8885 Digital Answering Machine
Uniden Phone Logo
327 people viewed this question
Top Uniden Lands Phones Experts
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
