I need Service Manual Canon iR2520. Where i can buy it?
  • 8,404 Answers
Check with Canon at www.canon.com.
Posted on Sep 17, 2010
Canon ir 2520 hang or display sowing canon
hi. maybe there is a problem with the system booting section . try to perform a firmware upgrade
Feb 10, 2016 | Canon imageRUNNER 2520 Laser Multifunction...
Error code E000002 in Canon IR2520
Dear
it indicates fixing unit temp could not raised to predetermined value. The following steps may be taken to clear the error.
CLEAR>ENGIN>ERRLR; and then turn OFF and then ON the power.
2.Check connection of the Connectors (Thermistor Connector and AC Connector).
3.Replace the Fixing Assembly.
4.Replace the DC_CON PCB.
Thanks
Feb 13, 2015 | Canon Office Equipment & Supplies
I have a problem for my machine canon Image runner 2520 error code E000010
Hi
There appear to be several causes for this code and others with a second set of digits. The following site lists the error codes and possible corrections for your machine :--
Error Codes Canon iR2520
Each code can be viewed individually by using the drop down menu "Codes", and you can also get a Service Manual pdf (format) from this site for a small charge using the link near the top of the page.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Feb 11, 2015 | Canon Office Equipment & Supplies
Error Code: E000020 for CANON IR2520 Turn the main power switch (on the main unit's left side) OFF & ON, If the machine still does not operare normally, contact your service representative with
Hi there
On the page below I can find an error code E002-0000 for your Canon model, but not the code you specify, as all codes seem to be in the xxxx-xxxx format.
The page is here and carries all the error codes
Cheers
Nov 25, 2014 | Canon imageRUNNER 2520 Laser Multifunction...
Service manual for canon ir 2520i copier
hello, you can find the canon ir2520 series service manual in below link:
http://goo.gl/Mvn8Rx
thank you
Nov 25, 2011 | Canon imageRUNNER 5000 Copier
I reset my IR2520 canon password but I can't recall it. How do I reset it to the default password?
I forgot my customized IR2520 image runner password and I forget it, may someone help me?
Jun 14, 2011 | Office Equipment & Supplies
Canon ir2520 don't print PS files. The PS driver is installed.
Did you buy the option for PS. It may be loaded, but PS is owned by Adobe and you need to buy the rights to use them
Jun 02, 2011 | Canon PCL Printer Kit-AF1 - 2860B001
Solution for canon ir 2520 error code E000020
E020 0000
The path between the sub hopper and the developing
assembly is clogged with toner.
1.Check the rotation of hopper motor gear. (If rotating, false
detection by the sensor is doubted. Feed the toner to the
developing unit in service mode: CLEAR>ENGIN>TNRINST.)
2.Replace the Developing Assembly Toner Sensor (TS1).
3.Replace the Sub Hopper Toner Sensor (TS2).
4.Replace the DC Controller PCB (PCB4).
SERVICE MODE:
* 28 * or MENU and #
Jun 30, 2010 | Canon Office Equipment & Supplies
Open Questions:
572 people viewed this question
k24674
jasbo
jasbo
