Question about Minolta EP4000/5000 CS/PRO Copier
Copyer minolta cs pro ep2080 code c0500 - Minolta EP4000/5000 CS/PRO Copier
  • 1,110 Answers
This code means that you have a failure of a part in your fusing unit. The fusing unit is the assembly that gets hot and "fuses" the toner onto the paper. It is located right where the paper exits the copier. The most common part failure in this unit is the thermal fuse. As it's title suggests this part is a fuse which is suppose to blow if the fuser overheats. They usually just fail due to age. There are 2 other possibilities although not nearly as common as the thermal fuse. The other 2 possible failures are the thermister which reads the temperature of the unit and the heater lamp which actually provides the heat.
The thermal fuse is a cheap part at around $5.
You will most likely need a service person to come out and diagnose the problem and repair it. Unless you are mechanically inclined and have a service manaul you might have a hard time getting the fuser out of the machine and dis-assembled in order to replace the parts. There is also a specific reset procedure that must be followed in order to clear the C0500 from memory after repairs are made.
Good Luck and Thank You for using Fixya.
Posted on Sep 17, 2010
Replace wiper cs pro ep2080 ?
Do you mean cleaning blade for the drum?
Jun 20, 2014 | Minolta EP4000/5000 CS/PRO Copier
My copier give code c0500
C0500
Warm-up failure
- The surface temperature of the Fusing Roller does not reach a given level even after the lapse of a given period of time during a warm-up cycle. Please change upper roller
Feb 15, 2014 | Minolta EP4000/5000 CS/PRO Copier
Code c0500
C0500 is a problem with the fixing unit. Check the fixing lamp & thermal fuse and thirmistor.
Oct 03, 2013 | Minolta EP4000/5000 CS/PRO Copier
Minolta EP2080 malfunction detected ... code C0500 .... this is an old machine ... anything we can do here ourselves to clear the error code?
the laser unit of the machine is faulty.either the polygon motor in the laser unit is not working or the laser diode is not working.anyways u have to replace the laser unit to make it work and it is costly so better buy a new machine
Aug 15, 2011 | Minolta EP4000/5000 CS/PRO Copier
C 50
There is no C50 code on this machine. All Minolta fault codes on the 4000/5000 series machines are a letter followed by 4 numbers. So the code would be like C0050 or more likely C0500. Let us know the actual code so we can be of assistance.
Thank You
Sep 14, 2010 | Minolta EP4000/5000 CS/PRO Copier
Minolta CSPro 3000 Copier/how to enter service mode
Press Stop - 0 - 0 - 1 or it maybe User Funciation then meter count - Stop - 0 - 0 -1 , it's been years since I worked on them
Feb 06, 2009 | Minolta Di3010 Copier
Code C0500
hold down exposure key (<) while turning on power, u-1 will display. prss start, select clear mode, prss clear/stop
Dec 15, 2008 | Minolta EP1030/1030F CS/PRO Copier
Problem in minolta cspro 2050
What code are you looking for??? I'll tell you what it means for FREE.....
Aug 19, 2008 | Minolta EP4000/5000 CS/PRO Copier
ERROR CODE CO5OO FOR MINOLTA CS/PRO 2080 ????
This is a lamp error, check that is not burned, or the thermal fuse.
1. Press the soft initialization on the right side of the control panel.
2. When the dot appears on the LCD after reboot, press the number 3 key.
3. The mode will change to the initialization screen.
4. Choose the selection for trouble reset.
5. After reboot the code will be cleared.
Warning: Be advised that with fuser codes, some RISKS are involved, PLEASE SEEK PROFESSIONAL HELP to reduce these risks.
Thank you and good luck!
Jun 18, 2008 | Minolta EP4000/5000 CS/PRO Copier
Ep2080 minolta cspro
Ep2080 minolta cspro error code comes up with c0500
Dec 06, 2007 | Minolta EP4000/5000 CS/PRO Copier
295 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
CheckitRight
CheckitRight
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
