Question about Gateway FPD1975W 19" LCD Monitor
This is the third time I,m trying to get an answewr to this problem . I followed the sugestion the first time and it didn,t work. Let's try again. I have a gateway computer in the upper right corner in a grey box there are these letters GJ912DW Ver.110 HSD190MGW1A Very anoying. Please help. Thank you, ME
  • Louis Ebert Sep 17, 2010
    mepayaso, You didn't tell us enough about the rest of "what you see or don't see" on the screen of your ccfl lcd monitor! Did you try to swap-in a different "known-good" lcd monitor to your pc to see if problem disappears??? What software operaring system is pc running? How old is unit? Have you done a system restore to your pc? Did unit work ok during the month of August? Leave additional comment so we can help with finding solution for you. 12fixlouie
    Brigadier General:
  • 10,406 Answers
If you change the Windows "wallpaper", does that text go away?
If you connect the LCD monitor to a different laptop/desktop, does the text still appear?
If you connect a different LCD monitor to your computer, does the text still display?
Posted on Sep 17, 2010
Canon troubleshooting
Hi Nolan,
Error code 5200 indicates that print head temperature error occurs. This error usually occurs in case of ink low or third party or refill ink usage.
I hope the following link will answer your question clearly. :)
Canon Printer Error 5200
Jan 11, 2014 | Office Equipment & Supplies
Acer g31t-m5 v1.0 motherboard bios not found . plz sugest me wht to do
hello,
try the following things:
1.remove the cmos battery that is on the motherboard
2.wait about 5 min
3.insert it again(battery)
4.now it should work
Oct 08, 2013 | Computers & Internet
Galanz microwave Code 310
This how i fixed with mi open hand i hit the number pad , 3 times hard like i dont care anymore and yeaaaaa it work like new again
Jul 03, 2013 | Microwave Ovens
Snow Cone Machine Won't Work
Nostalgia does not have repair parts, return the machine to where you bought it.
Mar 10, 2013 | Nostalgia Electrics Kitchen Appliances -...
My computer will not shut off when I'm finished with it???
Use a third party windows power options controller, if this doesn't work then some windows files are corrupted or deleted.
May 14, 2012 | Microsoft XP Computers & Internet
MY TV REMOTE IS NOT WORKING ?
Check the battery of your remote.Try to replace new battery.If didn't work.Try to open and clean the contact of the bottun of the battery.If didn't work, its need to replace the crystal of the battery.Try this sugestion.Thanks
Aug 26, 2011 | Sony KDL32EX700 32 in TV
I have changed one of the cartridges(colored one) in my canon mp450,after inserting it,the printer flashed U140 saying that the ink cartridge cannot be recognized. what shall i do to correct this...
Hi there, Try the following. Remove all the cartridges. Then switch Printer off.. Wait a minute or 2 then switch printer on again and install the cartridges again. Also make sure that on the cartridges the little golden contacts are clean.
If that didn't work try doing the following. It will reset your printer.
1: Power off printer
2: Hold Resume button then press and hold POWER, the beeper will sound once.
3: Hold POWER and release RESUME
4: Press RESUME twice
5. Release Power button
6: When the indicator lights steady, press RESUME three(3) times. The indicator should be orange.
7: Press Power to set data
Jul 29, 2011 | Office Equipment & Supplies
How many times I click my windows media player, it didn't appear. I don't knnow why..!
Have you installed any third party players? Did you try to make any changes to the computer prior to this issue? Are you getting any error messages or error codes? You may try the following steps to rebuild the Windows Media Player Library database and check if it works. To do this, follow these steps: 1. Click Start, click Run, type %LOCALAPPDATA%\Microsoft\Media Player, and then click OK. 2. Select all the files in the folder, and then click Delete on the File menu.
Note You do not have to delete the folders that are in this folder. 3. Restart Windows Media Player. If this does not resolve the problem, clear the Windows Media Player database cache files. To do this, follow these steps: 1. Exit Windows Media Player. 2. If you are running Windows Vista, click Start, click Run, type %LOCALAPPDATA%\Microsoft, and then click OK. 3. Select the Media Player folder, and then click Delete on the File menu. 4. Restart Windows Media Player. For more information, you may refer the following article: http://support.microsoft.com/kb/925718 You may try to install quicktime and then media player might use the codec to play .mov files. Note: Using Third Party Software, including hardware drivers can cause serious problems that may prevent your computer from booting properly. Microsoft cannot guarantee that any problems resulting from the use of Third Party Software can be solved. Using Third Party Software is at your own risk. You may refer the following link for more information:. http://www.apple.com/support/quicktime/ Convert music, videos, and pictures from one format to another http://windows.microsoft.com/en-US/windows-vista/Convert-music-videos-and-pictures-from-one-format-to-another File types supported by media center http://windows.microsoft.com/en-US/windows-vista/File-types-supported-by-Windows-Media-Center Hope this information is helpful Good Luck
Jul 09, 2011 | Microsoft Windows Media Player
My 2000 chevy express won't start due to security system. How do I reset it?
this is a 30 minute procedure. make sure you have a battery charger on it. to begin, insert the key into igniton, attempt to crank the engine, do not start. leave key in the on position. if the system is working properly after 10 minutes the security light should go out. turn key off for 5 seconds and then back on and attempt to crank engine again, do not start, after 10 minutes the security light should go out. repeat the above steps a third time. after the third time. turn key off and then start the van, if system is working properly it will learn the passlock again and car will start. if this does not work, try it once more making sure you followed these steps. any variation from these steps will stop the learn process. if it stiil does not work, then you either have a bad passlock module or sensor.
Mar 06, 2011 | Chevrolet Express Cars & Trucks
Gateway FPD1975W 19" LCD Monitor Logo
139 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
