Question about Whirlpool Duet GHW9150P Front Load Washer
What color of my short - Whirlpool Duet GHW9150P Front Load Washer
  • 176 Answers
I thikn blue
Posted on Sep 17, 2010
COLOR WHEEL NOT SPINNING ORANGE LIGHT BLINKING
Hi
Blinking light is a sign of some short circuit overloading the power supply. This fault should be traced mainly in the supply line for short. This task require to be serviced by a keen electronics hobbist or a tecnician.
Sully
Sep 28, 2013 | Sony KV-36XBR450 36" TV
After turning the tv on the colors are reddish and slow to conform to the normal color tones. i have a 36" toshiba flat screen tv
My first concern would be that, the picture tube is going bad. The problem you describe, tell me one of the color guns is shorting. In this case I would think the green gun is shorting. There are three color guns in the neck of the picture tube. They are red, green, and blue. Most of the time the green will short as it is powered heavily in most TVs. The next thing to check, is the small board connected to the picture tube. Look for any and all bad grounds on this CRT board. This is another big problem in all Tube type TVs. On this small board there will be three color output transistors, and resistors. These will many times run very hot and will create bad grounds over time. Check and resolder as necessary. If the CRT board does not fix your problem, replace the TV. Picture tubes are very expensive and will not be feasible for replacement. Search for a new TV. Thanks for asking and show all hands of support!
Jun 26, 2011 | Toshiba 36A43 36" TV
If you have 3 white and 3 black as well as a ground,how do you hook it up ?
If I understand correctly, your are replacing a GFCI receptacle with another GFCI receptacle
And your existing GFCI has 3 black and 3 white wires
And there is not a switch involved in the changeover.
I downloaded the manual from Lutron
http://classic.lutron.com/CMS400/techinfopage.aspx?id=22163
Every wiring diagram in manual shows:
Black wires connect to brass-colored screws
White wires connect to silver-colored screws
The brass and silver colored screws are typical of all residential receptacles. The color-code tells the electrician which terminal gets the black and white wires.
Are you having a problem putting 3 wires onto 2 screws?
It is a common problem.
You can buy a short piece of white and black wire at hardware store
Lets work on the black wires as example:
Strip back insulation on short piece of black wire
Hold together two of your black wires and start twisting them together
Now add the short wire to the two black wires you started twisting
Now twist together the two blacks and short black
So three wires are twisted together and you have a short lead that can connect to screw on GFCI
Put a wire nut over the twisted wire
Now you're ready to connect other end of short black wire to brass-colored screw
This reduces the number of wires that connect to screws
http://waterheatertimer.org/How-to-twist-electric-wire.html
http://waterheatertimer.org/How-to-select-right-wire-nut.html
Oct 20, 2010 | Lutron NTR-20-GFCI VAREO 20A GFCI...
Printer light blinking
Customer Support SUPPORT"; //--> print.jpg Print | email.jpg Email | --> pagelink.jpg Link null.gif KnowledgeBase 433-75x75.gif Product
Product
--> Lexmark Z615 Country / Region:
Country / Region:
--> United States Language:
--> Language:
English Need to download
a driver?
--> Save my information--> Lights Flashing on the Lexmark Z815/ Z816 Color Jetprinter ID: ENUS17112 This document does not apply directly to your Lexmark Z615
  1. First count the number of times the light on the front of your printer flashes.
  2. Then refer to the table below for information about the error condition and recommended recovery procedures.
    Number of Flashes Error Condition Error Recovery 2 Carrier Stall:
    The movement of the print cartridge carrier has been obstructed. Remove any objects blocking the carrier path.
    4 Print Incomplete:
    The print cartridge carrier stopped in the middle of a print job due to obstruction. Remove any objects blocking the carrier path.
    12 Cartridge Short:
    The printer has detected a short circuit in a cartridge.
    1. Turn the printer off.
    2. Open the front cover.
    3. Turn the printer back on.
    4. Remove the color cartridge.
    5. Close the cover. If there are no flashing lights, the color cartridge is short-circuited.
    6. Remove the black cartridge and then reinsert the color cartridge.
    7. If there is no error indicated by flashing lights, the black cartridge is short-circuited.
    8. If you continue to receive an error indicated by flashing lights, both cartridges are short-circuited.
Apr 22, 2009 | Lexmark Z640 InkJet Printer
Color not right
HI
you have defective RGB Circuit The Red, Green, Blue, You have shorted Green Circuit in Crt circuit this needs to diagnose to locate the shorted parts...
Thanks!
Apr 12, 2009 | Zenith B27A11Z 27" TV
Printer "HP LaserJet Color 1500L"does not work
I thought the problem. Short-circuit in bus management. Short circuit in electronics management (Dc Controller ОЕМ -RG5-6959). Dc Controller switched OEM-RG5-6959 with a new one.
Apr 09, 2009 | HP LaserJet 1500L Color Printer
Installed a lexmark z12 printer but not the power light but the light next to it keeps flashing and it wont print
  1. Turn the power OFF.
  3. Turn the power back ON. The print cartridge carrier should move to the install position located in the middle of the printer.
  4. If it does not, close and reopen the cover:
  5. Remove the color print cartridge.
  6. Close the cover.
  7. If there is no error indicated by flashing lights, the color cartridge has short-circuited.
  8. However, if you continue to get an error, repeat steps 1-3, and then go to step 9.
  9. Remove the black print cartridge and reinsert the color cartridge.
  10. If there is no error indicated by flashing lights, the black cartridge has short-circuited.
  11. If you continue to receive an error in both cartridge scenarios, both print cartridges have short-circuited.
Dec 01, 2008 | Lexmark Office Equipment & Supplies
Color wheel replacement
closed position is short. Check color wheel ribbon connector, contacts face to back of set.
Sep 13, 2007 | Samsung HLN617W 61" Rear Projection HDTV
Color
It needs repaired. I can think of many different possibilities causing the problem: 1. Shorted video luminance driver transistor. Should be under $200 total repair if you take set in. 2. Shorted green kine bias transistor. $200 3. Failed jungle ic. $250 4. Shorted green gun in the picture tube. More than you paid for tv set... Rca picture tubes commonly run 25% more than the tv set did new!!!!!!!
Nov 27, 2005 | RCA F27625 27" TV
Whirlpool Duet GHW9150P Front Load Washer Logo
12 people viewed this question
Dan Webster
Dan Webster
Sal De
