Question about Whirlpool Washing Machines
Whirlpool 2298 automatic top loader machine is 30 years old. just after the suds return and up to three times through the wash cycle the pump switches on and for about 10 seconds empties water through the drain pipe. My first reaction was that there was something wrong with the timer, but replacing it with a second hand timer made no difference. There must be something else that controls the pump activity. Any help would be much appreciated. David.
Hi David,
sorry I can't solve your problem, but I wish to thnak you for your post. I have the same problem and pulled the timer out to give a clean with no luck. I did find evidence of a short circuit on one of the elements so something did happen. I have bee trying to locate a new/used timer - but no luck.. You would think that Whirlpool when making such excellent products would provide the service these long lasting devices deserve.
Neil
Posted on Jan 06, 2011
  • Barry Squires Apr 16, 2011
    That sounds to me like one of the solinoids above the gear box is stuck. when the machine starts its cycle there is a set of coils (1 on either side of a bar joint to the gear box. they move much like the agitator) these solinoids are controlled by the timer, when the it is time for the pump to kick in the solinoid snaps into the bar and pushes the bar into the gearbox engaging the pump. if this is stuck or loose from the solinoid it would cause the shaft to engage the pump and drain the tub. hope this makes sense, i realy like the old machines, i have one of these and it is actually older than me.
Dismantle whirlpool top loader washing machine
you are using too much detergent, use less and it will keep it from getting "suds lock"
Oct 24, 2013 | Whirlpool Washing Machines
Whrilpool front load washer keeps flashing f 02, how do i fix this
SUD lock can often occur on a front loader that is being used with regular soap, front loaders require HE soap, if the incorrect soap is used a suds lock will stop the pump basicly pumping air
Dec 20, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I have a Whirlpool 9500TC Front Loader Washer. Can't wash garments due SUDS Display. Can't use any washer functions due to SUDS display.
Run a cycle with white vinegar this will clear the suds. Make sure you are using HE soap if not the unit will over suds.
Another common issue is the drain pump filter. If it gets clogged the sud error will come up as well. If you have water inside the pump may need to be cleaned. Simply remove the three screws ont he bottom of the lower access panel and then twist the handle on the filter. If water is inside the washer, it will come out when the filter is pulled out.
Good luck with your washer repair friend.
May 19, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I have a whirlpool duet 2 1/2 years old I t has started to make a loud buzzing hum sound (that sounds like old top loader mixing valve malfunction?) and has error code 5d what is this ?
Actually, your error code is "Sd" and indicates that the washer thinks that there are too many suds in the basket / drum.
Your buzzing sound is also likely to be the water inlet valves, common to top loaders as well, as the washer is adding additional water to rinse excessive suds out. Check your supply hoses for kinks, connections for scale buildup inside, as well as the screens on the inlet ports of the washer itself.
A kinked or restricted drain hose can also throw an Sd error code as well.
Jun 22, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool dryer error code
Your TECH SHEETS mention "Sud" If too much detergent was used. Why? You get that computer thinking suds is in there and the machine is gonna go into a tailspin. Because of the low amount of water
used in HE machines, it is important
to use an HE detergent (low sudsing)
which is specially formulated to work
best under these conditions. The two
most important considerations of a front loading washer are sudscontrol and soil concentration.
First, the tumbling action in an HE machine generates
more suds than a top loader. Tumbling the clothes in and out of the water breaks the water surface
causing air to be trapped in the solution,
creating suds or foam. Multiple problems
can occur from oversudsing, such as
flooding from suds overflowing out of
the machine, formation of a suds cushion
during the tumbling action which reduces
mechanical energy,and “suds lock” which prevents
the machine from effectively spinning out the
water. In the situation of suds lock, the
machine tys to FIX the foaming poroblema by
stopping the cycle momentarily to allow
the suds to dissipate and then adding cold
water. This routine the machine goes
through to correct for over-sudsing results
in loss of energy and water savings and
can significantly lengthen the cycle time
(sometimes by as much as 2x). HE detergents
prevent over-sudsing and allow for better rinsing of suds. HE detergent matters in soil management also. Though HE washersuse about 1/3 of the water of a
top loader, the concentration of soil in the
load is much higher due to the larger
loads. To handle the higher amount of
soil, many HE detergents are specially
formulated with soil suspending ingredients
to prevent soil from re-depositing
onto clothes. Only use detergent with HE marked on it. Use the correct amount.
—Run the unit through a Rinse/Spin cycle.
—Run a Normal cycle without adding any detergent.
This should clear the unit of the excess detergent.
1. Check the drain hose and make sure it is not plugged
or kinked.
2. Unplug washer or disconnect power.
3. Check wire harness connections to the drain pump,
4. Check/clean drain pump filter of foreign objects.ec9f016.jpg
5. Plug in washer or reconnect power.
7. Check the pressure switch.
8. Verify CCU operation by running a Diagnostic test or any
cycle. Your tech sheet will be behind the bottom panel and will resemble THIS Suds is on page 6
Jun 01, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I have a Whirlpool duet HT front loading automatic washer, it's not draining & last time it did this a repair man came and showed me how to get underneath and drain it, but I don't remember how
The following link explains how to access the drain pump on a Whirlpool Duet front loader to clean out the trap:
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If you are experiencing drainage issues and cleaning the pump does not work, you may have to replace the drain pump. You will usually experience an "F2", "SUD" or "F21" error code (depending on model number) for a drain blockage problem. Since this error code occurs when the drain cycle exceeds 8 minutes, if the pump motor or impeller becomes damaged, the pump will not pump at the required volume and the error code will continue to occur. Replacement pumps can be purchased on line at:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between these sites, so shop all of them for the best deal.
NOTE: Make sure you also check the drain hose and the inlet hose that runs from the bottom of the wash tub to the drain pump. Small articles of clothing can commonly get lodged in this area.
If you have any questions, please let me know. I hope this helps you.
Nov 01, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
Whirlpool Calypso Washing Machine
Have you changed detergent? Have you installed a water softener or has your water source changed? Either of these could cause increased sudsing. Suds could be splashing. I have has suds on the lid when I used regular detergent, not HE.
May 11, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Washer draining problem
I am sorry The model I was refering to was not yours... you have an OLD belt driven model there is a panel on the back (2) 5/16 screws to see the pump the best way to replace that hose if you have to is disconnet the fill lines pull the machine out from the wall and lay it on its back for easy access..
Feb 19, 2008 | Washing Machines
Crosley Front Load Washers FL Error
Flood Condition F L “FL” flashes if any overfill condition occurs. This condition occurs when excessive water in
the tub causes the overfill switch to trip. The control must realize that the trip was due to an
overfill condition instead of a suds lock condition in order for “FL” to be displayed.
With an overfill condition, the beeper repeats a warning every 10 seconds with no time out.
The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch
resets or power is discontinued to the unit.
Press STOP/CANCEL to clear the display.
Feb 18, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Washing Machines Logo
57 people viewed this question
Dan Webster
Dan Webster
Sal De
