Question about Canon PIXMA MP210 Photo All-In-One Printer
Not printing or scanning
When I try to print or scan it says printer not responding.
I had the same problem. You need to change the printer port setting to from COM1 to USB. Go to the "Control Panel" of the start menu. Select "Printers and Other Hardware", then pick "Printers and Faxes". Right click on your printer icon "Canon MP210 series Printer" and select "Propeties" at the bottom of the menu. You will see the tabs, "General","Sharing", "Ports", etc. Click on the "Ports" tab. Scroll down until you get the "USB Virtual printer port" with "Canon MP210 series Printer" name next to it. Click on that check box and you should be good to go.
Posted on Sep 28, 2008
  • 300 Answers
Are the cables connected properly and is the printer switched on? and are you selecting the right printer when you attempt to print?
Posted on May 18, 2008
Fixe_You
  • 1800 Answers
SOURCE: printer x6570 won`t print photos and data, or scan...
try uninstall the driver and insatll it after that reboot and connect printer!
Posted on Jun 05, 2009
SOURCE: Describe your kodak esp 5 pkodak esp 5 printer
me bashed it good
Posted on Aug 15, 2009
komguy
  • 2306 Answers
SOURCE: cannon MP145, I want to only scan not printing.
There is no solution for that, if you want only scanning, you need a separate scanner. This machine will only scan when all other errors are taken care of. And all inks are full.
Posted on Sep 18, 2009
MooMadCow
  • 38 Answers
SOURCE: Printer will not scan to computer.
You will probably have to go to this page to download the new Mac drivers for Snow Leopard to get the full functionality of your All-in-one printer back.
Print functions are generic enough where you don't need to have the most updated driver for it to work. But the scanning functionalities are more complicated.
Find the driver for your computer here:
HP drivers download for PhotoSmart C4480
Posted on May 28, 2010
Testimonial: "It worked! Thanks so much. "
  • 256 Answers
SOURCE: HP PSC 1510 All-In-One-Printer not responding
If your HP printer fails to respond to a job, check that all printer cables are connected properly and ensure that the printer is turned "ON."
If everything configured well then go to the computer's control panel from the start menu and click the "printers" icon and be sure that your printer is selected as the default.
If everything checks out in the control panel, right click on the printer icon and select properties.
Click on the details tab and make sure that the correct port is selected.
Double click on the printer icon and cancel all documents and try printing again.
Posted on Jun 09, 2011
Does not print
It could be a lot of things. Try to download an updated driver for your printer: http://bit.ly/TFAEDX
You can also try to update the firmware of your printer: http://bit.ly/PqTjBl
If those doesn't work, it would be best to contact our technical support team.
Dec 28, 2012 | Lexmark Pro915 Wireless All-in-One Inkjet...
I have a Lexmark 2600 all in one. When I changed the black ink #14 I got a realign message, printed the alignment page but get no response when I push scan button on machine. I can scan from the computer...
1. The software that came with the printer must be installed for the scan button, on the printer,to work. The software also has to be running.
2. If this is the case, and the scan button on the printer is the only thing not responding and it is still not working, then uninstall the printer software and reinstall follow the directions given with the printer. This usually intails:
Power on the scanner, un-plug the USB cable from it and begin a fresh install.
You will re-connect the USB only when the program tells you and not before. Let it finish.
REBOOT computer and window will find the new hardware.
Only do this if you already tried the "1." step first. Sometimes reinstalling the print software will resolve this issue.
Jan 30, 2011 | Office Equipment & Supplies
May 28, 2010 | HP PhotoSmart C4480 All-in-One Printer ...
My printer keeps printing the test page everytime its switched on, How do I stop this as wasting ink ?
Remove and reinstall the printer driver. Make sure you have the latest driver consistent with your operating system. www.hp.com/support
Feb 24, 2010 | HP PSC 1315 All-In-One InkJet Printer
Until a few days ago my Model X3550 operated perfectly, now the unit will not respond to print command, although it will still copy and scan and perform all other functions. Simply will not print, get...
unplug printer. uninstall the printer drivers. restart computer. when desktop comes up, plug in USB for printer. Windows should recognize the printer. If not, try a different USB cable.
Feb 04, 2010 | Lexmark X3550 All-In-One Printer
Printer x6570 won`t print photos and data, or scan...
Jun 05, 2009 | Lexmark X6570 InkJet Printer
Not printing and no responding !Hardware is ok.
plz try by changing the usb port and cable if the result is same then scan your pc for viruses by a updated anti-viruse software
Mar 19, 2009 | HP Officejet Pro K5400dtn Printer
Not responding to PC instructions to print data
You need to load the PRINTED ALIGNMENT PAGE on the scanner glass, then press on "OK" button. It should start scanning the alignment page. That way, you are completing the PROCESS of ALIGNMENT.
Thank you so much.
adonscott
Jul 01, 2008 | HP PSC 1315 All-In-One InkJet Printer
My kodak printer easyshare 5100 not responding
maybe..the scanning is most likely from something else..try new drivers first
http://tinyurl.com/6qcpgy
Jun 29, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Canon PIXMA MP210 Photo All-In-One Printer Logo
114 people viewed this question
old marine
old marine
