I have an Akai GX-400D.ss. The function buttons...'REC'-'REV'-'STOP'-'FWD'-'FFWD' do not operate. The relays have been cleaned and contacts are operating. All other operative functional buttons, toggles, switches etc seem to be working normally.
sandrew
  • 2961 Answers
SOURCE: Function Key Problem
your keyboard driver may be corrupt, go to my computer, right click>properties>hardware tab>device manager and go down list to keyboards, click '+' sign, right click on your keyboard and select uninstal. Restart your notebook and the keyboard and drivers will be reinstalled automatically and should be as normal, but check for any updated drivers at Sony:- http://www.vaio-link.com/downloads/preinstalled/preinstalled.asp?site=voe_en_GB_cons&m=2303
Posted on Jun 20, 2007
skotkolr
  • 558 Answers
SOURCE: Starter relays does not operate. Cannot turn starter
Clutch pedal rely switch, like brake light switches can go bad.
Have a great weekend.
Posted on Apr 17, 2009
  • 19 Answers
SOURCE: all functions have ceased to operate - the reset
Pooky
Indeed the buttons (pushers or pusher contacts) may have been jammed internally. The are a small piece of metal which is pushed my a cylindrcal rod (which you are pushing the outer part of it into the pusher contact).
Sometimes the pusher contact may have come out of alignment. or did you change the battery yourself? did you a/c it properly? (metal tweezer from the a/c with the battery)?
Hope this helps or sheds so light on your situation
Posted on Jul 14, 2009
jr fix it
  • 5 Answers
SOURCE: System seems to operate fine but no sound
there is something that is called a relay in side of the set when u open it u will see it were u put the speaker wires behind that two black boxes those are the relay look between them n see if any thing had burn if so u need to change that part of reach me at 742-2520 if u want
Grubhead
  • 5126 Answers
SOURCE: akai gx-625 reel to reel tape deck has no sound
This could be a head fault? Another possibilty is the preamp stage. You will need to look for something that would take out both channels. Such as an IC.
Posted on Sep 11, 2009
My 4th channel on my akai gx 400d ss is not working. Lights up.
Clean the heads real well then after that it is a matter for the Technician to work on.
Dec 30, 2016 | Audio Players & Recorders
AKAI REEL TO REAL MODEL 1700 OPERATOR'S MANUAL
Here you are Andrew. That is a blast from the past!!
Service Manual and Owner's Manual!
Akai 1700 Manual Stereo Tape Recorder HiFi Engine
Jan 23, 2016 | Computers & Internet
How to connect a GX-280D-SS to amplifier
Line outs to tape in or Aux in that is all that is too it.
Feb 18, 2014 | Audio Players & Recorders
Camera chewing tape when in " REV " mode, then E03 on display
the capstain of the mechanism needs to be change and it can also be the pinch roller.the fastest solution is to change the mechanism ofthecamera
May 27, 2013 | JVC GR-DVL160EG Mini DV Digital Camcorder
Need a starter for 3 phase motor with only two buttons, one for farward & another for reverse.button should be bell switch type, when presssed and hold, motor should run and should stop when released.
You will need a fwd-rev starter (has two contactors) You can buy any brand. You should have three buttons fwd stop rev
You could wire it so the fwd latches until stop is pressed, and the rev button momentairly so it stops when finger is removed.If you buy a brand with a general purpose (NEMA 1 ) enclosure you could put buttons in the cover, some even have buttons made for their covers.
Aug 11, 2010 | Garden
Akai gx-77 real to reel
Mechanism is in need of major cleanning and lubrication. You might also consider replacing belts and rubber pulleys
Jul 12, 2008 | Audio Players & Recorders
Faulty TRV-35H
general cleaning start with forward and rev button with good contact cleaner and then go inside use air blower or compresed air(radio shack)check:lever which make the movement of forward and backward confirm it is clean-check of selonid and it is return spring has a good tension change it if it is weak or broken.apply a light grease over all moving parts.
best wishes
Dec 11, 2007 | Elmo Projectors TRV-35H Slide Projector
Accessing the menu and timer recordings
Oh boy! Most late VCRs must have a functional remote to get to the advanced functions such as setting time, programming, etc. The front panel buttons only have stop/play/rewind/ffwd/eject and so forth. Either obtain an exact remote, or one of aftermarket universal remote boxes which have menu functions.
Nov 14, 2007 | Curtis CMV41001 VCR
Not Able to Record/Playback
can't record on the my Olympus VN-1000
+ I press rec button and it just shows rec in display (no recording time is shown ONLY rec)
+ there is no play back  or stop function
+ i can only stop  rec by removing batteries (stop or play will stop rec only ONCE - but there is no  useful function - such as play or stop or rec.)
+ I tried all trouble shooting tips in manual  with no effect
+  i cleaned the spring contacts inside battery compartment that interface with the  batteries
+ it was barely used - and has not been used for a 1 year ( no batteries were inside it )     it was inside a drawer
THANK YOU
Jun 16, 2007 | Olympus VN-1000 Digital Voice Recorder
How do I use the memory stick?
Recording Still images To The Memory Stick M.REC mode (Memory RECORD mode) 1. Set the mode switch to MEMORY CARD. 2. Set the power switch to CAMERA. 3. Press the PHOTO button. The still image is recorded to the Memory Card. To View photos on the Memory Card M.PLAY mode (Memory PLAYBACK mode) 1. Set the mode switch to MEMORY CARD. 2. Set the power switch to PLAYER. The last recorded image appears. If there are no recorded images on the Memory Card, NO STORED PHOTO! or NO STORED MPEG4! will display on the screen. 3. Using the (FWD) and (REV) buttons, search for the desired still image. * To view the next image : press the (FWD) button. * To view the previous image : press the (REV) button. * Pressing (FWD) when you are on the last image will take you to the first image and pressing (REV) when you are on the first image will take you to the last image. * Keep pressing (FWD) or (REV) to search for an image quickly.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
160 people viewed this question
 Grubhead
Grubhead
