Question about Sterling Plumbing 1500D-31S VISTA PIVOT SHOWER DOOR
Sterling frameless bypass shower doors inside door wont stay closed even though have it on th best option setting to do so
    Problem Solver:
  • 6 Answers
Some times it's possible to tweak a roller track (barely bend) at the proper spot to prevent the roller from back tracking past that spot.
Posted on Sep 19, 2010
I have just had the Sterling Plumbing Finesse Frameless Bypass shower doors installed in my new bathroom, model 5425-59S-G05. I do not like the clear doors and want to replace them with Lake Mist which is...
Home Depot will likely only sell the whole kit, not the individual doors off the floor. You may be able to special order just the doors through Home Depot or you may have to contact Sterling directly and order the doors through them. The doors hang on rollers from the top track and will come off simply by lifting them up off the track and out. Make sure to wear a good pair of rubber coated gloves as the doors can be quite slippery.
Jun 29, 2010 | Sterling Home
Looking to buy (gasket) for edge of glass
This is not a specialty store. This is a general internet forum. And people who answer are scattered across the planet. Try checking for a local plumbing store and call them.
Apr 09, 2010 | Sterling Plumbing 1500D-31S VISTA PIVOT...
Lost installation paperwork for Vista Pivot II shower door by Sterling
call 800-sterling they can send u out a new set or any other questions u have sterling is a kolher company
Nov 26, 2009 | Sterling Plumbing 1500D-31S VISTA PIVOT...
I have a frameless pivot shower (doors are 182 x 34 cm each), and pivot hardware needs replaced. i have part numbers, but do not know the brand name. 30095PPC plastic pivot part
Finaly a found a supplier, www.novellini.nl
The parts are:
De benodigde artikelnummers zijn:
1 x R02YOB2G-40 (set scharnieren t.b.v. één deur) à € 23,80 incl. btw.
De prijs van de bovenstaande set onderdelen is € 23,80 incl. btw.
Verzendkosten zijn € 7,50 incl. btw.
Oct 19, 2009 | Sterling Plumbing 1500D-36S "VISTA PIVOT"...
Spartan brand curved glass shower door installation info needed.
curved cut glass will not always be the exact dimensions though they may look identical there should be several set screws on both the door glass frame and the shower glass frame that can be loosened and reset to make the door fit and close and open more properly without seeing the showwer itself i can not tell you exactly where they are but they should be either visible or behind a facade piece of metal frame
Aug 27, 2009 | Sterling Plumbing Sterling& By-Pass Shower...
Need shower door replacements parts
Supplier in the Netherlands, www.novellini.nl
For the 30095PPC are the next parts:
Jul 25, 2009 | Sterling Plumbing 1500D-36S "VISTA PIVOT"...
Frameless shower door sticking to the opposite wall when closing
you can fix this problem by loostening the clamp screw and putting locktite sealer(you can purchase locktite from hd or lowes locktite is not the only product you can call a glass supplier and as for recommendation) Be sure to read the directions on the tube I use it to seal joints on refrigeration threaded parts. Make sure it will adhere to glass and metal also review the clean up solvent when you do this place a wood wedge at the bottom of the glass dooor and the threashold to support he weight until the sealer driese
Steps
1 Place wood wedge/block under door where non hinged side meets wall
2 losten top hinge(inspect bottom hinge to make sure it is snug and the glass dor is all the way into the hinge
3 You may have to remove the top hinge completely to get enough of the locktite on the metal and glass place the locktite on the hinge flat plate and the glass
4 recheck gap where door meets wall( I sometimes use paint stirs(wood) as shims to keep space between door and wall consistent
5 tighten top inge screws( you can put locktite on the screw threas also
6 Clean excess locktite and wait suggested time by instructions on tube
Good Luck!
Dec 31, 2008 | Home
Sterling Plumbing 1500D-31S VISTA PIVOT SHOWER DOOR Logo
459 people viewed this question
Top Sterling Plumbing Home Experts
Donni Steen
john h
Mike
Are you a Sterling Plumbing Home Expert? Answer questions, earn points and help others
