Question about Microwave Ovens
My whirlpool WHKM-D10 water cooler is leaking from the inside and dripping out the vent on the left side of the machine.
2 Suggested Answers
SOURCE: I am unable to use
Go to www.super-electric.com and send them a message about your problem. They have parts. I can't tell you if they will help you or not, I have just emailed them today as well. I have both sides of my 1 year old water cooler leaking, model W074DRF11BQD. (from Zellers) I have hardwood floors and I would rather throw this unit away than risk water damage. If anyone is reading this and thinking of purchasing one of these Bellagio water coolers, spend your money elsewhere - THEY LEAK!. My husband is very handy and has just spent 2 hours on it with NO success. The parts are defective - this unit is NOT full of complex working parts. One plastic part causes pressure on the valve and causes a leak(s). After light usage and nothing damaging it, 8 months old one side went and the other side has been leaking for a couple of days and we are just coming up to a year. If anyone else had this problem and fixed it, I would love to hear the solution.
Posted on Jan 17, 2011
I've got grease dripping down from the top left inside corner of my otr microwave. I've cleaned the grease filters. Is it a problem with the vent to the outside?
Without a long explanation as to why but they will get a build up. At this juncture i would be prudent to just clean it well. Because it will require you to remove the outer cover, you must disconnect it. Be careful when you do this, no metal objects. It has parts that store electric. Once you open it you will see the build-up. Do not open the metal box, it is the part that stores the electric.
Nov 10, 2013 | Whirlpool 1.6 Cu. Ft. Over-the-Range...
My freezer is icing up and water is dripping from the ice. I'm having problems closing the door as a result, and removing frozen food.
Try this, If it is an upright fridge, remove the flont lower vent grill. Ten to one the coils are covered with dust and cobwebs. Not implying anything, mine was horrible. Vacuum all the stuff that has accumulated untill the coil is nice and clean.. Unplug the unit so you don't get into the moving fan blades and don't reach into the space, There are hot componants. Good Luck, Ned
Aug 23, 2009 | Microwave Ovens
I want to defrost my GE chest freezer but i do not know where the drain is
Since you did not include a model number this is my best guesses:
http://manuals.appliancesonline.com.au/kcm2100wc/kcm2100wc.pdf (Page 1 w/pic)
and
http://www.appliancesdirect.com/InstallationPdf/49-60442.pdf (page 7 no pictures)
For Complete Defrosting
Turn the temperature control to the
OFF position and unplug the freezer.
Remove all food and place it in
corrugated boxes, insulated bags,
picnic coolers, etc. Use towels and
newspapers for insulation as needed.
With the door/lid open, use pans of
hot water to speed loosening of frost.
Remove large pieces before they melt.
Chest models have a defrost water drain
at the front.
NOTE: Water may drip from the back flange of
the lid cover during defrosting. This is normal.
Ice builds up in the lid insulation when the lid is
open for adding or removing food, and melts
during the defrosting operation.
Sponge excess water from the bottom
of the freezer as it collects to prevent
overflowing.
After defrosting, clean the inside of the
freezer (see Care and Cleaning).
Replace the drain plug inside the
cabinet and the cap on the defrost
drain. Fold over and dry the gasket
on the hinge side of the lid.
Plug in the freezer. Return the
temperature control to its previous
position and return food to the freezer.
Hopefully with this information you can find the drain. If not go to www.ge.com and click on service and support to download your manual. (Model number required)
or contact them here:
800 GE CARES
(800.432.2737).
Thanks for choosing FIXYA,
Kelly
Jul 24, 2011 | General Electric Microwave Ovens
I have a cv615 Miele Coffee Machine. The water reservoir was not inserted properly and water leaked into the bottom of the machine (drip tray). We got the Water System Fault message, so we removed the...
just use your hair drier to dry out the remaining water.Before doing anything remember to unplug the device.Remove the tray and other such attachments and let it to dry by itself for a day or two.this should solve the problem.never plug in the device till then.
regards.
plz. rate this
Jul 04, 2011 | Microwave Ovens
My refrigerator has a leak behind the drawers on the inside . I have since had to put a towel at the bottom of the drawers or it will start leaking down the front and onto the floor every couple of days....
Moisture condenses out of the cold air inside the fridge. Many refrigerators have a drain tube in the bottom to allow the condensate to run into a drip tray under the refrigerator (behind the trim panel on the bottom) where it evaporates. Over time this tube can get clogged by food particles and the water backs up, eventually running over the bottom edge onto the floor. You can use a straightened out coat hanger or other stiff wire to clear it out. This should get the water back into the tray where it belongs.
Jan 21, 2011 | Microwave Ovens
My Whirlpool over-the-oven microwave generated a "pop" sound and red flash last night -- it seemed to come from the left side, where there is a grid of small circular vent holes -- while warming...
Sorry to read about your problem, I hope this helps you out.
This can be normal, if you have grease or food stuck on the side walls, just clean entire oven area,
some cooking containers are more apt to causing sparking than others.
If it does it again, i would suggest you call a service company, But your unit can be replaced for around $150.00. So I dont know if it would be worth it.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Dec 30, 2010 | Microwave Ovens
I am unable to use the Bellagio water cooler now as the cold water dispenser is leaking. There is a constant drip so I had to remove the water bottle, then drain all the water from the reservoir. I have...
Dec 26, 2010 | Microwave Ovens
My microwave does not vent out moisture well and leaves a lot of moisture accumulating into water at the bottom of the oven and on the door and sides. The vent is not blocked. It just doesn't clear...
The fan that cools the magnetron also helps exhaust water vapor. Does the fan sound as strong as it used to? Is the vent at the back of the microwave clean? Sometimes lubing fan motor bearings with light machine oil will speed up the fan. You would have t remove the cover to gain access.
Jun 20, 2010 | Panasonic NN-H504WF Microwave Oven
Whirlpool MH2175XS microwave/hood combo with oil leak, etc.
This is a very wierd problem that we have been dealing with for years, and never seem to get a correct answer. Have actually seen green slime like oil inside the units before. From what we have heard, is that this oily substance is actually coming out of the blower fan assembly inside the unit. Its like bearing oil from the center support shaft. Will go away over time, but the fan may or may not go bad. Good luck with the mystery oil.
Jun 11, 2009 | Whirlpool MH1150XMQ Microwave Oven
VENT CAME ON BY ITSELF. WHIRLPOOL MH6130XEB-2
The hood / vent fan is controlled by the keypad, but it will also come on when the temperature of the hood area / stove top gets too high.
If it does not go back off by itself after a few minutes, then you probably have a shorted hood fan thermostat.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jun 24, 2008 | Whirlpool Microwave Ovens
Microwave Ovens Logo
707 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
