Question about Sony Ericsson K750i Cellular Phone
Now in my set, when I switched on that, screen dispays only white brightness, and it also blinks continuously. so tell me how it can be repaired
  • Nikolce Blazevski Sep 17, 2010
    hi sounds as if you could possibly have liquid damage. if you remove the battery, there should be some little square stickers, should be white, but if there is liquid present, will turn red.
    Problem Solver:
  • 17 Answers
You need to reprogram your phone that's the only solution,maybe your using your phone with aminimal memory and it reaches 0 kb......no more space.thats why it would not work properly.next time set it up properly use a memory stick....store all your files in it not on the phone memory because it is limited.
thanks,
nelwin/philippines
Posted on Sep 22, 2010
LG 47LV5500 UA.AUSYLUR power board problem likely,,set won't power on
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Jun 07, 2016 | LG Televison & Video
How do I fix an lg42ld450 tv that has a blinking red light and a blank screen?
http://electro-medical.blogspot.com/
Mar 30, 2016 | Televison & Video
TV Vizio VF551xvt. as you turn it on it "blinks" (the screen will turn on and off quickly). the logo stays white as if the tv was on but the screens stays off. how can I repair it?
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Jan 29, 2015 | Vizio VF551XVT 55 in. HDTV
Broksonic Flat Panel TV, tried to turn back on TV and Green LED light is blinking and screen pops up a few sec with white and colored lines and the turns off
Blinking codes details to many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty.
Oct 21, 2014 | Broksonic Televison & Video
42" zenith lcd the green light flashed 18 times then white screen for an instant then sits also takes a long time to power off then.
Sounds like main board fault. These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Oct 13, 2014 | Televison & Video
Blinking screen off
First, restart your iPad.
If the blinking continues you will have to take it to an iPhone/iPad specialty repair shop because the problem is it has probably been slightly damaged some way and the blinking screen means that the screen has been damaged in one area
Sep 02, 2014 | Apple iPad (16 GB) WiFi Tablet PC
HP Pavilion DC6, Radeon Graphics card. How do I adjust contrast?
Start / Control Panel / Display / Settings / Advanced / Graphics Media Accelerator / Graphics Properties / Schemes
lots of clicks! This should get you what you want. You'll probably have to experiment with settings a little to get what is truly comfortable to you.
If this is helpful, please take a sec to rate me. Thanks!
Don
Mar 16, 2012 | HP Pavilion dv6000z Notebook
Samsung NC10 Screen goes white when plugged into Charge
I too had this problem with my NC10, and i found that on the back, the little slider holding on the battery casing was not in the locked position. As soon as I locked the slider, the problem was solved and has not occurred again.Might not be the case for all these posts above, but worth checking your before having to get involved with customer services etc.
Aug 24, 2009 | Samsung NC10-14GW Notebook
Laptop screen
adjust your screen brightness, PLEASE SEND ME A PHOTO OF YOUR LAPTOP TO:
completleywacked@gmail.com yeah i know it's a weird e-mail adress but yeah.
Jun 21, 2008 | Acer Aspire 5610-4648 Notebook
Thermador model sc272t oven 2 doors have dim display
there is a dispay kit you can order from bosch to fix this problem. it will come with a new display board and power control which is located behind control panel as well
Nov 18, 2007 | Thermador SC272T Electric Double Oven
Sony Ericsson K750i Cellular Phone Logo
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Sandeep Shenoy
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
