Question about Neff B7740N0GB Microwave Oven
Hello, Please can you help. My Neff B7740 Quantum speed microwave was supplied without a manual and I can not speak very good German. I just simply want to know who to change the langauge to English. Thanks
3 Suggested Answers
djhollewood
  • 54 Answers
SOURCE: Neff Microwave H6871 no instruction book - unable to operate it
This is more of an idea than solution but have you tried disconnecting the power supply and then plugging it back in? If the red led display lights up you will know it works. Otherwise I would say it's time to replace the microwave. If you don't have access to the power supply try flipping the breaker.
Posted on Jan 14, 2009
SOURCE: NEFF MICROWAVE OVEN BLOWS 10A INTERNAL FUSE
We had the same problem, got Neff service engineer to come out after taking out insurance. He said the megatron cracks which is a large magnet and causes the fuse board to blow and needs to be replaced. This occurs through lack of ventilation on instalation. Total cost £370 may as well get a new one. Plus our insurance wouldn't pay the cost and cancelled the insurance policy.
Posted on Jun 08, 2009
I am looking fro a Manual to print off for A NEFF Microwave Oven model HFT879. Can anyone help please?
Jon, everything I can find on it needs an "E-number" off the plate on the bottom of the unit. You then should be able to go to
https://portal.bsh-partner.com/portal%28bD1kZSZjPTAwOQ==%29/PORTALFRAME.HTM
and find your manual. It will be in PDF format which requires the free Adobe Acrobat Reader. Just google it to find a download site for it. Best I can do right now. Good luck.
Feb 25, 2015 | Neff Microwave Ovens
I have a NEFF H5972N0GB. I am trying to change the language from german to english. Can anyone help?
1. Press and hold the "M" memory button for 4secs approx. until "Sprache" appears in the first line, and "deutsch" appears the the second line of indicator screen.
2. Press the button with the two triangles on each other to highlight "deusch"
3. Use the function selector to choose the required language
4. Press the "M" once to save the selection
5. Language should now be in your required language
Apr 08, 2013 | Neff Microwave Ovens
Neff C57M 70S0 POWER FAILURE
Hello, welcome to Fixya!
The unit not powering on is an indication that it has a power fault.
First, remove the microwave's power cord from the wall, wait for about 30mins, then plug it back in. It may cool by then and might power on. If it doesn't power on, plug it into another outlet, to make sure there electricity entering into the unit.
If plugging into another power outlet doesn't power it on then the unit is most likely having a power problem.
When electric current comes from the power outlet into the microwave, it goes straight into the power supply board which then circulates the current into the unit. So if the microwave doesn't power on, the first thing is to make sure there is power entering into the machine.
So check the power cord, if it is a 3-pin plug, it must have a fuse in it. check the fuse if it is not blown. if fuse is intact, then power supply board should be checked.
If any machine or electronics device doesn't power on, it means its having a power problem. It might have worked fine in the past, but that's electronics for you. Power surge, irregular power supply, excess power supply, etc can affect the unit thereby not making it to power on.
This microwave must have a power supply board in it where power enters from the mains. A capacitor, fuse, diode, etc may have been defective on the power board and maybe that's why its not making the microwave turn on. There might also be some disconnection or something, inside the unit which is not making it to power on.
To actually find out what's wrong, you need to disassemble the unit with a screw driver and check what's wrong. You will be needing a meter and continuity tester in order to read the components on the power board, once you detect any bad component, you can make necessary replacement at any electronics accessories store within our vicinity.You might also find visible bad component without testing with a meter. This is the only way by which you can detect the problem.
Of course, testing the power board with a meter will require someone that has the ability. So it you can't, then you might be needing the help of a repairman or you can call a friend that has the ability to help you out.
I wish you the best of luck.
Regards.
Jan 04, 2012 | Neff H7871N2GB Convection / Microwave Oven
I live in Switzerland and have a new Electrolux EB SL6 built in oven. How can I get a user's manual in English?
Unfortunately, you can't as your model has never been intended for English-speaking countries. As far as I recall, it's only available in French, Italian, German and some Eastern European languages.
You will either need to ask someone locally to translate the key sections into English for you, or if you use the FireFox web browser you can add the excellent FoxLingo plug-in which provides translations from a number of sources. All of the software and the translations are free.
Aug 15, 2010 | Microwave Ovens
Neff ovens does it need to be hard wired or via a 13 amp plug
you dont say what model if microwave most models is 13a supply if single built in oven 13a also ok double oven needs 30a supply/ hope this helps
Aug 05, 2010 | Neff Microwave Ovens
Switching off after 23 seconds without heating
Hi Paul, did you get any answer for that?? My neff is giving me same problem.. if you know what is the solution can you please e-mail me to alinaseer1@hotmail.com? Regards
Oct 31, 2009 | Neff H5470 Microwave Oven
Mar 24, 2009 | Neff H5470 Microwave Oven
Jan 14, 2009 | Neff Microwave Ovens
Lost instruction manual as to how you reset time on clock
Go here to download to your manual:
https://portal.bsh-partner.com/portal(bD1kZSZjPTAwOQ==)/PORTALFRAME.HTM
Hope that helps! Should you have any further questions, please feel free to post them here.
P.S. – I would greatly appreciate a FixYa! rating if the solution I provided fixed or helped you resolve your problem.
Thank you for using FIXYA!
Cheers!
IrishDruid
Oct 30, 2008 | Neff H5470 Microwave Oven
Neffcombination built in microwave and grill
The options for language selection will be detailed in the setup menu in the manual. German and English are similar enough to work out the steps to return it to English. A manual can usually be acquired from the manufacturers website, or from download sites. (Internet search your brand and model number).:::Spiceweasel.au.
Jan 28, 2008 | Neff H5642 Convection / Microwave Oven
Neff B7740N0GB Microwave Oven Logo
114 people viewed this question
Top Neff Microwave Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a Neff Microwave Oven Expert? Answer questions, earn points and help others
