Question about Kenmore Dishwashers
Doesn't clean, lower arm seems really loose - Kenmore Dishwashers
  • Kenmore Master
  • 17,130 Answers
Even if this is loose the water pressure must be maintained. So checck if the pump is pushing the pressure if not remove and test outside to clean and reset.
Now the second part is to tighten the arm movement , must look into why the arm has come off and if there is a leak in this section reducing the water pressure. Nothing like a first hand view to decide.
Possible the rotation arm has wearing( if set is OLD).
Try for a replacement arm section if this section does not respond to fix.
Posted on Sep 17, 2010
Meiko 530F leaks from doors bottom corners while washing, any hints, water level senson seems fine
Make sure the jets in the UPPER arm are all clear, and that there's no debris inside the top turret. On the bottom arm, IF the lower turret has (or is supposed to have) a rotating baffle, make sure it's in place - this looks like a very loose washer on the lower turret, running in a groove ~ the plastic versions get lost, the metal versions slip down and don't do their job.
Clean the drain channels along the bottom of the door and especially around the hinges, you will probably need a thin bottle brush or a steamer to get into the nooks and crannies.
Feb 20, 2015 | Meiko Dishwashers
How to fix with pitchers
Remove the bottom cover panel, the rubber one. Take a photo of the inside of the machine. You'll see four little lever arms that all move together when you rotate the crank - the upper two arms rotate on screws. Remove those two screws and the upper arms will be free to move.
Now the really tricky part is getting the two lower arms free. There's one perfect spot where they come loose and the tobacco plunger (piston?) will be free to remove. At this point, you should also be able to remove the sliding guide that feeds tobacco into the cigarette tube.
It'll all go back together exactly the same way - again, it's really tricky to get those two lower arms to attach to the plunger / piston.
Aug 04, 2014 | Premier Supermatic Cigarette Making...
1996 crown vic- drivers side wiper arm loose, blade will not lay flat when cleaning
Sometimes you need to bend the arm to put more pressure on the glass.
Mar 29, 2014 | 1996 Ford Crown Victoria
Maytag jetclean dependable quiet plus doesn't clean dishes
It sounds like you have a faulty float switch. It's cutting off the water inlet before the tub is full.
May 26, 2012 | Maytag Dishwashers
My LG dishwasher soap dispenser does not empty entirely and leaves a residue on the door. It also doesn't seem to be cleaning as well as when it was new. It's about 2 years old. I was using a gel...
Make sure you're not loading the dishwasher with large items close to the soap dispenser. These can block the action of the dispenser door. Also, be sure the water temperature is 140 degrees for the best cleaning efficiency.
Another thing may be that your spray arm jets are clogged.
Depending on the model, the lower spray arm generally has a nut or thumb/butterfly screw (plastic) that you remove and then lift the spray arm off. I always soak mine in hot soapy water and then flush with hot water. If debris such as pieces of paper, bone, peelings are in there, you'll need to take a tweezer or toothpick to remove them from the jets. The upper spray arm usually has the same apparatus and you can follow the same procedure.
The upper spray arm receives water pressure from a tube that runs up the back of the machine on the inside. If the connection has been knocked out of line, the water can't flow through the tube to the spray arm. My kids used to knock ours loose when they loaded the lower shelf. Pull out the top shelf and see if the plastic connectors are in place. If not, snap them back on the shelf supports and this should align the tubes.
One more thing: the bottom of the door..on the INSIDE of the machine.It's amazing how much "gunk" settles and accumulates under there. I use an old toothbrush, moistened in soapy water to scrub the underside of the door. Then pour hot water on the area. Next run a regular cycle with NO items in washer and use 1/2 cup white vinegar...no detergent.
I hope these suggestions help your problem. If so please come back to Fixya and rate my advice!
Jul 21, 2011 | LG 24 in. LDS 5811ST Stainless Steel...
My Amana Softsound 2 isn't getting dishes clean - the lower arm doesn't rotate. We cleaned around and under the arm as much as possible, got some gunk out from under, but still not rotating, so...
Check the nozzles of the arm themselves. if you found lots of gookl there maybe some inside the arms blocking the spray holes which cause it to spin
Jul 15, 2011 | Amana ADW862EA Built-in Dishwasher
Hi...my Maytag Jet Clean doesn't seem to be actually cleaning anything. Especially the glasses and crystal. They are coming out with a sort of white film on them....lip prints still in place...still...
The upper spray arm attaches to a tube in the back of the dishwasher. If the support clamps come loose, the upper spray tube will not be flush with the tube and can't carry water to the sprayer arms. Also the sprayer arms can become clogged with paper remnants, bone fragments, or pieces of peeling. You'll need to remove the sprayer arm and flush it at your sink. If there is a jet that is clogged, tweezers will help remove the residue.
Also, make sure the water temperature is 140 degrees.
I hope this helps. If it does, please come back to Fixya and rate my answer
Jun 12, 2011 | Maytag Dishwashers
Upper rack is not cleaning. Greasy dishes on top seem that dishes are not being washed. Seems the upper water turning dispenser is not working, Bottom rack seems ok. I guess I only have half a dish washer...
Check the upper arm for free spinning, then remove the arm and check that the seam between the upper and lower halves has not split somewhere. Also check all the small holes for debris plugging. Run the machine in wash cycle for a little while with the upper arm off--that should flush out anything blocking the pipe up to the arm. If still nothing from the upper arm, tear down the lower arm assembly down to the deck while noting position of all parts removed. Clean the big screen at the bottom in white vinegar and hot water. Inspect the holes in the bottom for anything blocking them.
Aug 15, 2009 | KitchenAid 24 in. KUDS02FRSS Stainless...
Dishwashers Logo
44 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
