Question about Intel D102GGC2 Motherboard
My mother board is D102GGC2 and i want to change my memory now, presently i have DDR2 533(4) now, i want to change it to DDR2 800? is there any problems, my mother board support?
    President:
  • 2,571 Answers
Nope, as long as it is the same or higher, it will default to the supported speed.
You could try some or the memory checkers online like http://www.crucial.com/?click=true
It can scan your system and recommend the best match
Posted on Sep 17, 2010
I have intel pendium d d102ggc2 motherboard. am using 512 mb ram ddr2 667mhz. Now i want to upgrade it and use 2 gb ram. please suggest.
Mother board d102ggc2
• Support for DDR2 533 MHz and DDR2 400 MHz DIMMs
• Support for up to 2 GB of system memory
Dec 27, 2012 | Intel D102GGC2 Motherboard
Im plannin 2 upgrade my RAM..My mother board(Essential series D102Ggc2) supports DDR2 800...my processor is Pentium D 820+ ...my query is: DDR2 800 is supported by Mother board but is it supported by my...
Your motherboard has the follwing memory support : DDR2 533/400 SDRAM 2 slots, Single-channel (2GB2 Max). As long as it is supported by your motherboard there would be no problem since your processor is also supported by the motherboard.
Please refer to the follwoing links from Intel:
1. http://www.intel.com/support/motherboards/desktop/d102ggc2/sb/cs-026580.htm
2. http://downloadmirror.intel.com/15112/eng/D102GGC2_TechProdSpec.pdf
3.http://cip-origin.intel.com/cd/channel/reseller/apac/eng/products/desktop/bdb/d102ggc2/feature/index.htm
Mar 06, 2011 | Intel Pentium D 820 Smithfield 800MHz FSB...
I want to upgrade my system ram size to 2gb...my system memory configuration as follows mother board: intel102ggc2 system bus speed :800mhz processor (p4):3.0ghz ram slots available:2 and presently i'm...
The below is the contents of Intel published for your board
Intel Desktop Board D102GGC2 Technical Product Specification
System Memory The board has two 240-pin DIMM sockets and supports the following memory features: • 1.8 V (only) DDR2 SDRAM DIMMs with gold-plated contacts • Unbuffered, single-sided or double-sided DIMMs with the following restriction: Double-sided DIMMS with x16 organization are not supported. • 2 GB maximum total system memory. • Minimum total system memory: 128 MB • Non-ECC DIMMs • Serial Presence Detect • DDR2 533 or DDR2 400 MHz SDRAM DIMM
hope it helps, if so rate the solution
Nov 16, 2010 | Intel D102GGC2 Motherboard
MOther board support req.
As of our current technology ALL Motherboard can support the most biggest hdd capacity which is 2TB (Terrabyte). You can even use a 10 TB single hdd on your motherboard if you have one.
Should you have any other questions just please leave a comment.
Cheers~
Jul 17, 2010 | Intel D102GGC2 Motherboard
On intel d102ggc2 one ram of 1gb detect but alongwith 512mb does not detect
PLUG BOTH THE MEMORY MODULES AND THEN OPEN THE BIOS SETUP CHECK IF BOTH OF THEM SHOW UP IN THE MENU IF YES THEN SAVE THE BIOS SETTINGS AND RESTART THE COMPUTER OR ELSE MAKE SURE BOTH THE MEMORY MODULES HAVE SAME FREQUENCY
Jul 09, 2009 | Intel D102GGC2 Motherboard
Can i connect one two 667mhz rams in INTEL D102GGC2 mother board?
Memory Two 240-pin DDR2 SDRAM Dual Inline Memory Module (DIMM) sockets Support for DDR2 533MHz and DDR2 400MHz DIMMs Support for up to 2GB of system memory
hope helpfull
May 29, 2009 | Intel D102GGC2 Motherboard
HOW TO FIND RAM CAPACITY OF INTEL D102GGC2
Intel D102GGC2 Motherboard Each memory slot can hold DDR2 PC2-5300 with a maximum of 1GB per slot.*
Maximum Memory Capacity: 2048MB
* Currently Installed Memory: 512mb Number of Banks: 2
* Dual Channel Support: Yes
* CPU Manufacturer: GenuineIntel
* Although the memory can be installed one module at a time, the best performance comes from using matched pairs of modules.
Your MotherBoard Supports up to 2GB of memory.
You have 512mb, you can add 512mb to the empty slot.
, however,It's a good idea to keep them the same if you can.
You can install memory that is: DDR2 PC2-5300 (PC2-5300 is 667Mhz) you can use 1gb memory in each module for best performance and matching pairs since your motherborad supports dual channel.you can use sound card and SATA hard disk for higher disk support
Mar 15, 2009 | Intel D102GGC2 Motherboard
Where does a garphic card fit
Your intel D102GGC2 motherboard has only PCIE slot (black connector- not the memory slot). Its located beside the buttton cell of the mother board. If your graphics card is PCIE, it would directly fit on the black connector.
Jan 03, 2009 | Intel D102GGC2 Motherboard
Intel D102GGC2 Motherboard Logo
53 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
