Question about Maytag NMPEB08F2A Air Conditioner
Stand up airconditioner
The air conditioner is pushing cold air, the one plastic vent is pushing hot air, cool light is on temp is set to 61, does this hose need to be vented out side
  • ruthwiitala Jun 30, 2008
    I have the Danby portable 3 season air conditioner, model DPAC120068.
    Hoses are vented outside through the window. The Exhaust hose gets
    very hot. Unit does not cool the room because of the increase in hot air.
  • 828 Answers
To your question the answer is YES, generally vented to the outdoors through a window. Generally speaking there are two hose connections for cooling the refrigeration end of the A/C. one should supply cool air from outside and the other should discharge the hot air outside. If not vented to the outdoors your build heat instead of cooling.
Posted on May 17, 2008
Our airconditioner is not pushing cold air but it is running....the vents have little air coming o ut but not a lot and the house is not cooling.
Check the filters . It sounds as though its iced up. had the unit been running for a long period of time? If so you might see ice on the indoor coil . If so shut down the cooling leaving the fan on to help deice the unit . If it ices up again then you may have a fan that is running slow or a coil that is plugged with lint due to inproper filter service .. check the coil for ice and let me know.. Jon
Aug 07, 2011 | Goodman CKL36AR36 Air Conditioner
The compressor is running but not cooling.
Try the following to begin operating the air conditioner: 1. Plug in the air conditioner. (To prevent electrical hazards, do not use an extension cord or an adapter plug.) 2. Set the exhaust vent to the CLOSED position. 3. Press “On/Off” button to turn unit on. 5. Press Mode “COOL” 6. Press “TEMP/TIME” up or down V to the desired set temperature. Review the “Air Conditioner Features” section for other settings
Jul 10, 2008 | Frigidaire FAS185N2 Air Conditioner
Unit is running but it is pushing hot air. I just changed a very dirty filter.
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
Aug 01, 2011 | Weather King 10AJA2501AH Air Conditioner
Does not seam to be cooling enough, clean filter, have temp on 60degrees, cooling is on high, does not open to outside, air coming out is barley cool not cold
heatman101
Jul 13, 2011 | Airtemp B6Y12F2A Air Conditioner
My carrier puron is running but the air comming out of the vents is cool bit not cold. what could be the problem?
heatman101
Apr 02, 2011 | Heating & Cooling
Dont seem to get cold air, what is the best symbol to use? There is sun, snowflake, rain drop and few others either way it takes forever to get the house cold and sometimes it just simply just does not...
To get cold air set temp 23 degree and mode "cool".
Now symbols:
1. fan leaves - Fan only
2. Rain drop- Dry mode
3. Snow flake-Cool mode
4. Sun- Heat
5. A or AU- Auto mode.
Dec 30, 2010 | Heating & Cooling
Rent a house with a daikin brc1c51/61 with no instructions on how to work control panel for cooling/heating
Symbolsin remote: To get proper cold air set temp 23 degree and mode"cool". To get heat set temp 30 degree and mode in "Heat"
Now symbols:
4. Sun- Heat
5. A or AU- Auto mode.For further details, plz:
www.devicemanuals.com/guide/.../Daikin-manuals.html
Blowing out hot air
check for the clogged evaporating coil
Jul 20, 2010 | Sharp CV-P10LC Portable Air Conditioner
Cant keep cool
You need to check that tour filters are new. Then check that air is coming from the vents and is at least 15 degrees cooler than room temp. If no air coil is frozen, or blower motor and run cap are not working. If frozen than turn system to off and fan switch is on until you feel air through vents.
You'll need to make sure the outside unit is runing and the larger copper line is cold like a can soda. If it's cold but is freezing up, it needs to have a charge added. If its running but not cold and the fan is not running or the compressor isn't running it could have a blown capacitor. If its not running at all check. the circuit breakers and reset them. And a good idea to keep the outside unit washed with water,and that it is clear of weeds and stuff.
Jul 10, 2010 | Goodman CLQ36AR49 Air Conditioner
Not cooling
you may be low on refigerant
Jun 27, 2010 | Hampton Bay HBLG5004 Air Conditioner
Maytag NMPEB08F2A Air Conditioner Logo
175 people viewed this question
Top Maytag Heating & Cooling Experts
Bill Long
Donni Steen
Are you a Maytag Heating and Cooling Expert? Answer questions, earn points and help others
