Question about BenQ Computers & Internet
My screen has power and is connected to the computer, the monitor no longer turns on by itself, and when inturn it on manually it just shuts off after about a second or 2. I've never had this problem before and don't know what to do....
  • 732 Answers
After you do some fixya profile/testimonial reading here at fixya and do a visit to YOUTUBE, you will know what you will do to fix unit. Your unit no different than any other brand of CCFL back-lit lcd monitor in it's basic design and mode of operation!!! Always state the TYPE of unit!! CRT or LCD?? 12fixlouie
Posted on Sep 17, 2010
My screen keeps going blank yet i can almost make out the images.
personalize settings , also battery/ power options will solve ur prob : )
Apr 27, 2010 | Dell E152FP 15" Flat Panel LCD Monitor
Monitor just turns itself off after 2 sec.
disconnect all the cables except the power cable and then turn the monitor on you would see a test screen if it still happens your monitor is faulty and better buy a new one as repairing is usually expensive .
Apr 16, 2010 | HP w1907 LCD Monitor
Monitor remains on however, screen is only on for a second
If the monitor does not detect a connect to the computer itself, it will usually shut itself off, or at least go into power save (amber) mode. Make sure the monitor is connected properly into the back of the computer.
Feb 15, 2010 | Computers & Internet
MY SAMSUNG SYNCMASTER MONITOR SCREEN DOES NOT COME ON WHEN I TRY TURNING IT ON. HOWEVER THE POWER BUTTON BLINKS GREEN. ANY ADVICE? THANKS SAMSUNG SYNCMASTER Monitor (black) 739S O seen at the back
The cable connecting to the PC might be loose, or the part entering the monitor could be.
Try turning the monitor on, and after a few seconds, turn on the computer. You should be able to see the BIOS POST screen text flashing by. If you can't, there is something wrong in your hardware settings.
If you can, however, that's the OS resolution set too high: the monitor shuts down to protect itself. Boot in safe mode by pressing the F8 key immediately after powering up, then lower the video resolution in Control Panel display settings to something safe - 1024 x 768 usually does the trick. At that point you can reboot in normal mode and raise the resolution again to the maximum supported by the monitor (check the manual for that).
Oct 31, 2009 | Computers & Internet
The monitor shuts off. Turning the power off
the monitor is going into power saving mode ... it can happen if it is not receiving any signal from the pc ( pc is not running or booted properly, bad video cable connection monitor to pc) or the pc is itself in suspend/standby mode.
Aug 08, 2009 | Princeton Digital Computers & Internet
While trying to change channels, my t.v. displayed ''no signal'' and then shut itself off. Now, when I turn it on, it says no signal and turns itself off after a few seconds.
Turn the television on and as soon as the screen turns on repeatily press the input button or change the input to whatever input you are using from a source device. As long as you change it to anything other than RGB.
Your television is essentially a big computer monitor with multiple inputs and a tuner. When using your computer and shutting it down the monitor will go in a power save mode. You don't need to shut off your monitor due to this power saving mode. When you power up your computer your monitor automatically turn on.
With the VIZIO and the RGB (computer) input the television will act just like a computer monitor. When you have a computer connected it will power down automatically when you shut off your computer. When you turn your computer on the VIZIO will automatically come out of standby mode. This is through RGB only.
This is normal operation for the VIZIO but can see confusing when nothing is connected to the RGB input. If you change your television input to RGB it will sense no signal on the input and will go into standby mode after about 5 - 10 seconds. If you were to send a signal to the television through RGB it would automatically kick on.
Apr 05, 2009 | Vizio L37 Television
My new 21' flatscreen monitor keeps shutting off :(
Usually when an LCD display shuts off on it's own this can be a power supply issue. I would say if you checked all the connections you may want to contact the manufacturer. If it is only a few months old then you should be able to get it replaced under warranty.
Also, you may have an auto shut off feature enabled on the display itself. You may want to go through the display's menu to very that this is not the case.
Mar 08, 2009 | HP Pavilion F1703 17" LCD Monitor
Montior Repeatedly Shuts Off/Goes Black
i have the same problem .
already know what it is .
its the cfl power inverters which are build into the power supply
easy way to see is let the computer start up hold a flashlight up to the screen you should see your desktop .if so its the inverters/powersupply .
just started looking for a replacment for mine the closest i have found is around 25 bucks plus shipping wont know if it will work till monday when i can call them to match up the one i have
Jan 27, 2009 | Sceptre X9G-NagaIV 19" LCD Monitor
Turns off and on by itself
Ok so its connected to your pc?
check settings on the monitor itself [if you'restill able to do that]
disconnect all your usb devices restart your computer and try again.
Is it in a cold room ? that might be the problem.
Is it in the same powerbar as your computer ?
I'm not sure but if your power outlet where you connect it is simply looped to the rest that are in use [lazy electrician] then it might turn off because a power shortage.
Good luck
Dec 21, 2007 | Acer 19" LCD Monitor
HP mx705 17 in.CRT Conventional Monitor vertical goes bad
While it is sounding like a hardware problem. I'll throw in my 2 cents. Have you check the cables from the power to the source and from the monitor to the computer. Just make sure those aren't loose. One other thing...you mentioned you turn off the computer "afterwards" then it fixes itself. Is the fix for longer than it turns on at first? or does it stay on longer then goes out? Let me know what happens. Good Luck, Tim
Mar 14, 2007 | HP mx705 17" CRT Monitor
Computers & Internet Logo
79 people viewed this question
Top BenQ Computers & Internet Experts
JP Services
JP Services
Tony
Tommmix
Level 1 Expert
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
