Sir, I have been using a QSD2316L for about 2 years in a small antique store, and it has been a very good deterrent, anyhow at closing last night, the recordedr started beeping, and on the monitor it said there was a problem with camera 2. Well after getting my manual out, and trying to get in touch with you, I waited about 35 minutes, in about 10 minutes the beeping stopped. Is this something I should be concerned about, or what. As I am in Pa, and I know the time difference, if you would like to call with an answer, the number is 814 653 7700. thank you, Jim Heitzer
There could be many causes for a small leak, including foreign debris, small crack or loose hose. Using just water with no antifreeze can damage your radiator in sub 32 temps so always mix with coolant/antifreeze. One temp solution is buying stop leak from a auto part store, another remedy I've heard work is putting black pepper (finely ground) in your system to stop small leaks and it actually works. Good luck.
The average lifetime of a tent is 7-10 years when using it 2-3 times a year, each time between 3-7 days. Taking good care of the tent is a major factor in its lifetime.
Clarence, your mini-cooper may just need a new thermostat. if the thermostat in your car is the original, then 4 years is a goodly amount of time for any thermostat to last. Thermostats fail in 2 ways: (A) stuck open, which causes engine to warm really slowly, and (b) stuck closed, causing overheating and causing the heater to blow cold air - since the heated coolant can't get past the closed thermostat to circulate through the heater core (a small radiator-like device used to heat the interior of your car). Your car's thermostat has failed in mode (B). Your cost: $5-$15 at any auto parts store. Project complexity: any handy person could teach themselves to replace a thermostat.
well, they could have. but before you throw it out, go to the hardware store, and buy a new pull switch. either that, or just run it with the high and low speeds. It shouldn't hurt it at all. But, if there is any clicking sounds, or wierd noises coming from it , DON'T USE IT!! it may catch fire. but it did last a long time. 20 years is good for a modern celing fan. though I like my antique 1907 westinghouse 72 inch 2 blade fan. It hasn't died yet!!!
hi try to reset ur camera...To do such reset, turn on the camera and
hold the menu button down for longer than 5 seconds. A message should
hopefully come up on your LCD asking if you want to reset the camera.
Select Yes... thank u!!! rate me!!
your has been totally leaked . it can only be corrected by replacing the battery. try replacing the battery.
it has been off for last 2 years . May be the collected layer of dust has acted as insulator and is not allowing the current to pass through it. Pls visit any servicing shop and tell them to clean it form inside.
thankyou for using fixya dont forget to rate the solution
