Question about Wurlitzer Jukebox 1015 One More Time 100-Disc CD Changer
One more time vinyl wurlitzer juke
Only front box lights come on. After inspection found fuse si5 blown. also D6 & D7 blown apart. Check caps and bridge(GL1) and they tested good. Bridge puts out about 68vac and 29.5vdc. However i am only getting 9.3vdc to the s&cc. I check volts at D6 & D7, anode side, getting 11.7vac, the at the cathode side and getting 9.2vdc. i'm guessing i have the wrong diodes. Currently have 1N5397 diodes installed. Please let me know if these should work and the problem is somewhere else, or they are wrong and what are the correct ones. any help would be greatly appreciated, by the way when you flip the coin switch the LED-M flashes. TVTHUNDER@AOL.COM
    Champion:
  • Wurlitzer Expert
  • 211 Answers
Assuming I am looking at the same diagram for a 'Compact' amp....the circuit you are looking at is unrelated to GL1.
The two diodes rectify 10VAC from the transformer to a rectified +12V DC which supplies the mechanism. To blow both diodes I can only assume that you have a dead short to ground or -Ve somewhere.
Check both diodes and fuse are good with the mechanism plug disconnected. You should get 12vdc at the cathode of the diodes.
I don't know about the diodes you are using but 1N4001 or 1N4002 or 1N4003 should work fine.
The 12VDC comes out on pin 2 and pin 4 of the mechanism plug. Make sure the diodes are the RIGHTway round or you'll end up with MINUS12V.
Dave.
Posted on May 25, 2008
Where can I hire a repairman to fix my Whirlitzer juke box?
go google and type in--- service agents for wurlitzer juke box ---
find and agent closest to you and call him on the phone
Dec 23, 2016 | Audio Players & Recorders
Rockola Model 490 2 Super Sound Juke Box wont power on
(1) Make sure the wall outlet has power. (2)Make sure the power switch is "on" (3) check the fuses. If you discover a blown fuse, be sure to replace the fuse with the correct value. If it blows again, you may have a more serious problem.
May 26, 2013 | Audio Players & Recorders
I have a Wurlitzer Juke Box (One More Time, 1015, Vinyl) & need to replace one of the florescent bulbs in the turning, side cylinder. Someone said to turn the color cylinder a quarter turn & it...
The actual light tube slides sideways into the socket and then is rotated 90 degrees so it clicks (quarter turn). It is physically impossible so wurlitzer added a black plastic cap at the top and bottom of the tube with a bit sticking out that you can use to turn the tube. So look at the very top and bottom of the actual light tube and try turning the black part.
Aug 05, 2010 | Wurlitzer Jukebox CD Player
I NEED A REPAIR MANUAL FOR A WURLITZER SL900
You are going to need to search european websites to search for this German Wurlitzer model I have checked on the Stanmann website and the manuals go up to the SL800 however I would email Hildegard Stanmann for advice or place a request for a manual on their forum on their site.
http://www.jukebox-world.de/
Regards
Alan Hood
Apr 13, 2010 | Wurlitzer Jukebox CD Player
I have a wurlitzer super star juke box. the
I think I can clear things up for you. The free play switch you're referring to is just to add credits. If you want continuous free play, I sell you a jumper plug to bypass the credit unit, commonally called BOAC, if you have a 3600 series Super Star. Please email tech@wurlitzer-ohio.com.
Mar 11, 2010 | Wurlitzer Jukebox 1015 One More Time...
Wurlitzer juke box "Rave ON"
IF U REQUIRE THE SERVICE PROGRAMME EMAIL ME I HAVE IT ON DVD DISC philhemmings@hotmail.com
Jun 22, 2009 | Wurlitzer Jukebox 1015 One More Time...
Wurlitzer OMT CD Jukebox
It's a blown fuse on the amp.
You have to undo the cover plate at the top and then flex it to unhook the bottom. Once it is off you'll see the fuses.
Jan 01, 2009 | Wurlitzer Jukebox 1015 One More Time...
Wurlitzer Juke Box One More Time Elvis Presley Edition
Check the fuses in the small pcb in the middle of the front door. If they are ok. it's the amp end of things.
Jun 20, 2008 | Wurlitzer Jukebox 1015 One More Time...
Wurlitzer 1015 OMT Disc spins, then stops....
When the disc is taken from the carousel and put on the player how long does it take for it from the time it is placed onto the player to being returned to the carousel? Also is the cd spinning when its on the player or not spinning at all. The answers to these questions should help in pinpointing the actual problem.
Mar 16, 2008 | Wurlitzer Jukebox 1015 One More Time...
Wurlitzer 1015 problem
Most likely the main fuse inside the wurlitzer itself - situated screwed into the lower right hand side of the amplifier panel.
Aug 16, 2007 | Wurlitzer Jukebox 1015 One More Time...
Wurlitzer Jukebox 1015 One More Time 100-Disc CD Changer Logo
Top Wurlitzer Audio Players & Recorders Experts
jasbo
jasbo
Donald Chadwick
Donald Chadwick
Level 1 Expert
Are you a Wurlitzer Audio Player and Recorder Expert? Answer questions, earn points and help others
