Question about Microsoft Windows XP Media Center Edition 2005 for PC
My parents have a Gateway desktop with Windows Media Center 2005. It is plugged into a surge protector. Yesterday morning they experience two short power outages within one minute of each other. Now their desktop is in a continuous cycle of restarting. Safe Mode, Last known good config, etc does not work. What could be the issue?
    President:
  • 2,571 Answers
Unfortunatly, a surge protector is no use for power outs.
You need a UPS battery backup.
You may have damaged some system files.
IF you have a copy of your windows installation on disc, you could try a repair installation. You boot from the disc, do not choose repair windows. You click the install windows option, when it checks for previous versions of windows, if it can be repaired, it will as if you want to do a repair installation.
It looks just like a full install, but you do not loose any files or programs.
If it does not give you the option, then it is damaged too much, you would need a clean installation, you would loose everything
Posted on Sep 17, 2010
  • 903 Answers
When a desktop computer continuously restarts, it is typically an issue with the computer's power supply not being able to put out enough power to boot up the computer. (It takes more power to start the computer and get everything loaded than it does to keep it running.)
Usually this is caused by a faulty power supply, and the easiest solution is to replace it. New power supplies can be purchased for $30-$50... just make sure you get one that is compatible with your computer.
However, if you're having power issues as well, you might want to check the outlet where your computer is plugged into if you have a voltmeter or multimeter. If the voltage coming in isn't within the standard range (about 120 volts, plus or minus a few) the power supply won't be able to work correctly.
Your surge protector might also have been fried. Try plugging your computer directly into the wall outlet (bypassing the surge protector) and see if that makes a difference.
I have a HP Compaq Presario Media Center computer, it is plugged to a surge protector, the other night the electricity went out and my computer was turned on, and now I cannot get it to turn on at all, the...
try removing all power cables of your computer that are connected to the surge protector. reset the surge protector. wait for about 5 minuets before you turn on the surge protector. then plug all cables that your remove from your computer the turn on the computer.
Jun 03, 2010 | HP Compaq Presario Media Center SR1750NX...
I have a gateway desktop computer. Recently moved
Before you actually replace the power supply, check some other things first:
1. Wall socket
2. Power strip/surge protector
3. Power cable
4. On the back of the computer, where the power cable plugs into, is the red switch set to 115? It should be 115.
5. Make sure that the power cable is not connected to a regular extension cord. Power cable must plug directly into a surge protector that is not daisy-chained to another power strip, surge protector, or normal (household) extension cord. Surge protector must be directly plugged into wall socket.
If none of the above solve the problem, open up the case and ensure that all power connections are secure. Also check ALL other components' connections. Any loose connections can cause problems for you.
If everything is secure and the problem persists, replace the power supply.
Nov 27, 2009 | Office Equipment & Supplies
Can not start my computer
Plug the unit directly to the ac outlet if it is plug into a surge protector. See if it boots. Did you shut it down yesterday or was it left running? Any bad weather last night? You could try another computer memory and see it is the memory. Not sure what it could be at this point. What type of system is it?
It could possibly be a bad power supply.
I hope this helps.
Feb 17, 2009 | Acer Aspire™ T180 PC Desktop
Power issue
Sounds like your power supply may be shot on your computer. You can get a power supply tester and check it. Not sure what to do about the printer. If you had a surge protector in between your computer and ac. Plug the computer and printer back in to the AC outlet directly and see if that helps. Hopefully only your surge protector is damaged.
Please rate, Thanks.
Feb 09, 2009 | HP PSC 950 All-In-One InkJet Printer
When plugged, it shorts the surge protector and outlets.
I noticed that my refrigerator, kenmore freezer2_bing.gif, and stove were all not on. This has not ever been a problem before, so I unplugged the surge protector and reset the outlet. I then plugged the refrigerator2_bing.gif and the kenmore freezer to the surge protector and I noticed when I plugged the kenmore freezer it just shorted the surge protector. I then just plugged in the refrigerator and oven to the surge protector with no problems. I tried to plug kenmore freezer to other outlet and same result "a short
Nov 30, 2008 | Kenmore 14.8 cu. ft. / 419 liter Chest...
Last night I turned-off my PC througg Windows and when I pushed the power button this morning nothing hapened. There is no sign of "life" from the PC.
Check the power source to the computer (both ends of the cord), if a surge protector is in line with the power , remove it and plug the computer straight into the wall. also check the wall plug with a lamp or something to ensure power there. make sure the switch on the power supply hasnt been changed to the 220v side.
If no power at the wall- check your breaker box in the house
If it works plugged straight into the wall- check the surge protector
If power at the wall and plugged straight into the computer (no surge protector) and nothing lights up when you turn it on- have your power supply checked.
Oct 08, 2008 | Acer Computers & Internet
Storm last night, now Wii won't power up
Unplug everything! There is a "breaker" in the power supply and it may need to be reset. Just unplug all cables from the TV and outlets. Let it sit for a couple hours then plug everything back in and it should work fine. If not then the power supply has shorted out due to a strong power surge. You can claim it under your home owners insurance or call Nintendo and try to get it replaced. Thanks! Good luck and happy gaming!!
Aug 31, 2008 | Nintendo Wii Console
Computer power won't turn on
First thing to do is try to plug the pc in another wall socket to see if it goes on, If not, the MB could have gotten fried, even though the other plugs seem to work. Hopfully you just need another surge protector as that could have gotten damaged.
Jul 20, 2008 | Computers & Internet
Power outage, now pc will not power up at all.
sounds like the surge protector didn't protect. I would change the power supply.
Jun 12, 2008 | HP Media Center m7060n PC Desktop
Microsoft Windows XP Media Center Edition 2005 for PC Logo
47 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
