Question about Cell Phones
My sonyericson k618i will not switch on the indicator light flicker red a few times the same as i try charging it, it's not indicating that it's charging
    Sergeant:
  • 226 Answers
Could be one of 2 issues
either, ur battery is deeply discharged, or your software is corrupt
nick
Posted on Sep 17, 2010
We just received a camera clock and we cant get it connected to WFI. We have been working on thisfor hours, the only time we can work on this is evenings.
WIFI connection method:
1. Switch the power button to turn on, then long press the play key until the blue light on(30 seconds later, blue indicator light start flickering, then the clock camera is turned on , and then red indicator light will flickering, which means the clock camera WIFI signal is opened)
2. turn on the WIFI on your smart phone . Run APP software that you have downloaded and installed
Dec 12, 2017 | Car Audio & Video
Camera won't charge red light is on but the green light doesn't come on . What is my problem ? Could it be the battery
hi Kenny.
With most cameras, an amber, yellow, or red light indicates a battery that's currently charging. A blue or green light usually means the battery is charged. A blinking light sometimes indicates a charging error; other times, it indicates a battery that is still charging.or faulty battery.
have you tried,take the battery out and then put it back in?.
make sure the battery is seated.and its making a good contact.
Dec 01, 2017 | Green Cameras
My optoma758 projector switches of after a few minutes&the lamp light flicker red@1second
Warning Indicator
? When the "LAMP" indicator lights solid red, the projector
will automatically shut itself down.
? When the "TEMP" indicator lights solid red for about 60
seconds, it indicates the projector has been overheated. The
projector will automatically shut itself down.
Under normal conditions, the projector can be switched on
again after it has cooled down. If the problem persists, you
should contact your local dealer or our service center.
? When the "TEMP" indicator lights solid red, it indicates the
fan failed. Please contact your local dealer or our service
center.
Dec 05, 2016 | Office Equipment & Supplies
Left indicator light flicker too fast
If the right side works properly, switch all indicator bulbs one at a time. test with each bulb change. Untill you find the one that makes it flash at the rite timing. I had a bad rear bulb. The brake filiment was laying on the tail light filiment. This made the blinker timing bad.
Jan 26, 2014 | Hyundai Tucson Cars & Trucks
The light on my chest freezer will flicker on and off when I open the door. It will only remain on when the door is in a certain position. How do I fix this? Secondly, the red "on" light on...
Both light flickering probably indicates a problem with the plug or the cord. If it was just the inside light I would suspect the door switch, but both light would indicates an open short in the wires or plug.
Check the plug connection at the wall and see if it is loose. While unplugged check the cord for any nicks or cuts. Plug something else into the same wall receptacle , like a light and see if the power to the receptacle is ok.
If none of the above work then it is time for a qualified repair person.
J
Feb 20, 2018 | Woods Chest Freezer C1501W3
My plantronics explorer 260 won't turn on. Also when I go to charge it the charging light stays on for about a few min. and then shuts off but i still can not turn it on. Please help
Here are a few steps to review before coming to the realization that your battery could be wasted. Give them a try and see if it helps any.
1) While your headset is charging, the indicator glows red. When your
headset is fully charged, the indicator turns off.
2) Turn off the headset: Press and hold the call control button until the indicator glows red. You will hear descending tones. When power is off, indicator stays off.
3) Turn on the headset: Press and hold the call control button until the indicator glows blue. You will hear ascending tones.
Good luck from Headsets Direct!
Feb 24, 2011 | Plantronics Explorer 232 Bluetooth Headset
My glowbouy flashes green and red...what does this mean
According to the owners manual for these swimming pool lights, this is what each colored indicator means. Hope this helps.
Solid green
The battery pack is fully charged.
Slow flashing green
The battery pack is almost fully charged.
Slow flashing yellow
The battery pack is half charged.
Medium flashing yellow
The battery pack is less than half charged.
Fast flashing yellow
The battery pack has almost no charge.
Fast flashing red
A charging error has occurred and the light should be unplugged and then plugged back in. If the Fast Flashing Red persists after several attempts, the battery condition is questionable.
Also in the trouble shooting guide, it mentions this:
Problem: Red Indicator Light Is Flashing While Charging
Solution:
A red flashing indicator light when charging indicates a selftest
error condition. Unplug the product and plug it in again.
Try this several times; if the indicator light continues to flash
red, unplug the GlowBuoy and take it to an authorized service
depot.
Oct 22, 2009 | NRS CANTAR GLOW BUOY FLOATING POOL LIGHT...
Indicating steady red light can not charge
Rub the terminals of the battery with your fingers and than again put it on charging .... before doing that remove the battery from the cell for an hour..
May 21, 2009 | i-mate Ultimate 9502 Cell Phone
Cell Phones Logo
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
