Question about Sony Playstation 3 (PS3) Console
There is no picture when switching the playstation on but we can hear sound. We have checked the leads and they are all in properly. Connecting it to a friends tv and works fine on our tv and there xbox works properly.
  • 4,102 Answers
Hi, you may have a problem with the lead give it a good wiggle all the way from the ps to the telly if that dont work try and borrow a friends lead to rule out the lead being the problem, if it still dont work then try the following to reset the console.
This is how to fix it:
1)turn your ps3 -off- by the switch at the back
2)turn it back -on- again by the switch at the back only
(there should be a red light now)
3)now -hold- your thumb on the power button located on the front for a few seconds until the ps3 turns itsself on and off.
(during this process there will be about three beeps spaced apart,and after that the light will return to red)
4)finally hold your thumb on the front power button again and you will hear two beeps then a double beep.
-IMPORTANT-
After you hear the double beep take your thumb off the button before it shuts itself down again.
5)once you have done that you should see the picture.
if after doing the above it still dont work then this would indicate it has over heated so try the following.
1 switch the ps3 off and leave it off for at least an hour
2 remove all leads from ps3 and tv
3 make sure the ps3 is not being used on carpet or on top of dvd player or sky box as this will cause it to over heat very quick
4 make sure all the air vents are clean and have no dust vac them out if needed.
5 make sure the ps3 has got good air flow around it and not stuck inside a shelf thats blocked off at the back as this to will cause it to over heat.
6 now plug it back in and give it a try.
if it still dont work then this would indicate the gpu chip has over heated and has probably fried.
if you have any warranty left on it take it back as this fault is covered by warranty.
i fix these for about 25 pound plus parts so you need to shop around and see if you can get it repaired, their is no guarantee the repair will work as their is always the chance that it has over heated that much that it has cracked the solder joints that hold the chip onto the circuit board.
im in uk and we do offer a repair service so if your in the uk and would like it repaired you can give me a shout back or if you need further assistance just give me a shout back.
let me know how you get on ok
plz rate this solution as i have a whole page of unrated posts, thanks
Posted on Sep 17, 2010
All picture and no sound
Rick:
simply unplug--then replug--your HDMI cable. Or also go into the audio setup menu and reapply the "automatic" setting for HDMI to get the sound to work. I don't know if Sony can do anything about this or not in a firmware upgrade, but what it can do is try to simplify the labeling on some of the sound settings.
Let me know
Dec 26, 2007 | Sony Playstation 3 (PS3) Console
My ps3 turns on but I can get sound or a picture. I have the connected properly...help!
Switch the console off, then press and hold the power button until you hear a second bleep, this should reset the graphics output
May 02, 2011 | Sony Playstation 3 (PS3) Console
Bought my ps3 when it came out been really good till naw . it will switch on disc will go in everything sounds like it works but i get no picture tried a new scart lead and still nothing.
  • If the video output settings on the PLAYSTATION®3 do not match those of the cable or TV in use, there may be no picture. If the screen goes blank, turn off the system.
  • Then, with only the PLAYSTATION®3 and the TV connected, touch the system's power button for more than 5 seconds to turn the system back on. The video output settings will automatically be reset to the standard resolution.
  • This is from playstations website Hope this helps.
    Nov 22, 2010 | Sony Playstation 3 (PS3) Console
    I have sound but my picture wont show up
    Try resetting the video settings on the PS3.
    Hold down the power button on the PS3 until you hear a beep. Release the power button and press it again.
    That should have reset the video settings and allow you to set them again.
    If by chance you still can't see the picture check that the video leads are connected properly. If you have checked them and still no picture then there could be something wrong with the console itself.
    Regards.
    Oct 20, 2010 | Sony Playstation 3 (PS3) Console
    HAS SOUND BUT NO PICTURE, IT IS NOT THE TV CAUSE THEY ARE PRETTY NEW. ALSO HOOKED UP A PLAYSTATION AND IT WORKED.
    I had a similar problem. Don't worry, it's probably something really simple.
    1) First check you component HD AV cable:
    Is it properly plugged into the back of the XBOX? Push it in with a bit of force until it snaps into place
    2) Check the Red, White and Yellow leads. Are they going to the right connections?
    3) If you are using the Scart connection or a connecting your XBOX to your TV via a DVD player check all the Scart connections to see if they haven't come loose and if they have, push them firmly back in.
    One of those is likely to be the problem.
    Oct 05, 2009 | Microsoft Xbox 360 Console
    I have no picture/sound with the av conn nor sound hd leads
    i had the same problem today. All i did, was hold the ON button for 5 seconds. It shoulld adjust the cable settings. Hope i helped. Worked for me
    Sep 02, 2009 | Sony Playstation 3 (PS3) Console
    Start up screen
    have you tried it on anoother tv?
    you see the cable connecting from the tv to the ps3?
    make sure the yellow onw is working properly
    Yellow=Viewing
    Red=Right Sound
    White=Left Sound
    Dec 14, 2008 | Sony Playstation 3 (PS3) Console
    Picture but no sound?
    Make sure the Red and white conectors are in the scart propperly
    and that the lead from the playstation is plugged into the playstation properly
    Dec 14, 2008 | Sony PlayStation 2 Slimline Console
    DVD playback no playback
    Sounds like the scart lead is not in straight. Scart connectors have the audio pins at one end, and the video pins at the other. If the lead isn't in straight then you often get sound and no picture and vice versa.
    Check the connection by pushing the scart lead in securely. (Both DVD and TV end of the lead)
    Failing that could be a dodgy lead.
    Mar 17, 2008 | Philips DVDR3380/05 DVD Recorder
    Sony Playstation 3 (PS3) Console Logo
    26 people viewed this question
    Top Sony Video Game Consoles & Games Experts
    shaun taylor
    marley mcelhinney
    juanmireles1
    Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
